Question about Whirlpool Dryers
My dryer shows F 70 on the panel - Whirlpool Dryers
    President:
  • 949 Answers
For a Whirlpool dryer F70 is an electronic control issue. It can be as simple as the wire came loose off the control in the top console or as complex as both control board and console electronics have failed. Here is what the manufacture says:
F:70
F:71
No
Communication
Between
Electronic
Assemblies
F:70 / F:71 flashes when there is no communication between
the machine control and the console electronics.
■ Check console electronics harness connections to the
machine control.
■ Replace the machine control electronics.
Posted on Apr 23, 2010
I swapped my wire from 3 to 4 wire on my kenmore 70 series dryer and now my dryer wont turn on. The breaker didnt trip and it worked at old house with 3 wire config. Any suggestions?
Bad news. You may need a new timer! Sorry. ( It happened to me)
Check with an electric meter your 4 pronged outlet for your dryer. The straight lugs holes should both show 110 volts. The "L" shaped and the round lugs should show "ground".
Now, go to the dryer back . There are 3 screws or nuts in a row for the incoming cord. The outside two screws or nuts are for the 110 volt service. On a 4 wire cord, these are usually red and black. The middle screw or nut is for the white ground, the green or blue wire goes to the body of the machine, not to the screw/nut panel.
I hope this helps. My error cost me a 90 dollar timer which I fried by mistake.
Be blessed.
Jun 14, 2013 | Dryers
Kenmore 70 series electric dryer not heating
You either have :
-A bad heating element
-A bad thermal cut-off
-Thermostat
OR
-A bad fuse.
May 12, 2012 | Kenmore Dryers
My 70 series dryer the heating element is not working. I checked the heating coil for continuity and it is holding 12 ohms, the fuse has continuity and it has power. Flipped the breaker to se If that was...
your voltage is not right as it should be 220 volts, check the outlet to see if you have 220 if you do then its the cord, if not then it is either the outlet or the breaker-panel, to check panel remove panel and test both legs of the breaker you should have 220 if not then replace the 30 amp breaker. Tim
http://www.ehow.com/how_7403710_replace-kenmore-70-series-dryer.html
May 27, 2011 | Kenmore Dryers
How do you turn off the dryer signal on kenmore 70 series dryer
On a 70 series dryer, the knob on the far right of the panel controls the signal. You can turn it left or right to set the signal to "On" or "Off."
If you've set it to Off and the signal still comes on, that switch that sits behind the knob is bad. It's the same switch that controls when the dryer starts. You can either try to repair it (by bending the contacts back into their original alignment) or replace it. A new switch is less than $10, and you can get one many places online, including from PartSelect.com:
http://www.partselect.com/PartDetail.aspx?inventory=345390&SourceCode=3
May 20, 2010 | Kenmore 63942 Dryer
63942 Dryer: how do you turn off the dryer signal on kenmore 70...
Hi, you can turn the signal off by using the start button on the dryer (located on the right side of the panel under the words "Push to start dryer"). Turn the knob to the left to turn the signal off, or to the right to turn it on. Each side should be labeled, but the lettering may have worn off over time.
If you've turned the knob to the left and it still signals at the end of a cycle, the switch that controls the signal may be broken.
May 18, 2010 | Kenmore 63942 Dryer
Kenmore propane dryer 70 series does not lite
Assuming the gas is on. The most likely problem is a bad ignitor. Remove the bottom front panel(pop 2 clips at the top of lower panel with a flat screwdriver) and turn the dryer on Look for the ignitor to glow. If the ignitor does not glow test leads to ignitor for power if you have power replace it. If the ignitor glows then you are not getting gas check to make sure the gas supply is on.
I hope this helps if you need further assistance please let me know.
Apr 14, 2010 | Kenmore Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Kenmore 70 series dryer leaving brown marks
you can get the parts direct from www3.sears.com and to replace it you pop up the top, take 2 screws out holding front panel onto cabinet and take off, take belt loose from idler and motor and slide drum out ,, go back same way / thanks
Jan 13, 2009 | Dryers
Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Apr 29, 2008 | Kenmore 63942 Dryer
Dryers Logo
82 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
