Question about Microsoft Windows XP Home Edition
Limited or no connectivity
Everytime i turn on my modem to connect to the 'net, i get a message that the connection has "limited or no connectivity' issues. This only started about a week ago. Before that, it connects just fine.
When i get this message, i just go to the control panel and click "repair" to repair the connection. After that it works just fine. I just dont want to do this everytime i connect to the internet.  Anybody can help me with this?
Im using a cisco 2100 cable modem, with pctools firewall plus on a WinXP home service pack 3.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 169 Answers
Hi
limited or no connectivity issue comes on a computer when modem and computer are not talking to each other in a proper manner .in this case the ip address of the computer turns to be 169.215......... which is a false ip first of all try to power cycle the complete system and while doing this flip the cables .once you have done that turn on your computer and check that it works or not .if not please try to trun off the firewall .even after doing this if it doesnot works then you need to hard reset the router and then you need to confgure it back again of the same problem comes please try to get back to me on fixya and i would love to solve your problem
Posted on Apr 23, 2010
Comcast installed Arris TM602G/CT Modem yesterday. Attempted to link modem to MAC AIRPORT wireless router. Have net access with my PC cabled to modem. If I hook the modem to the AIRPORT, the PC indicates...
first its a mac so no wonder its broken second its not your modem it would be your router settings. you may want to restore your device back to its defualts then try again.
Apr 13, 2011 | Computers & Internet
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Cannot connect to the internet
Limited or noi connectivity means your connection is not setup properly. The best method is to let the computer set it up for you (by DHCP). Right click on the connection you are using, in "network connections" Click "Repair". This command asks the computer to reset your ip by DHCP. Your connection should now have full connectivity.
Mar 19, 2010 | AT&T Computers & Internet
2 wire gateway..trying to go wireless....shows excellent signal but limited or no connectivity.
1. Try to determine whether you can connect to the Internet
Start -> Control Panel -> Network and Internet Connection
-> Network Connections -> Right Click Local Area Connection
-> Properties -> Internet Protocol (TCP/IP) ->
Use the following IP Address,
IP Address: 192.168.0.2,
Subnet Mask:255.255.255.0,
Gateway: 192.168.0.1
2. Reset modem and rebooted the computer
3. Check cables if they are properly installed unplug and replug
4. If issue where not resolve contact your ISP service to check if it's the connection or hardware issue " ISP service has a tool that can run a line test determining where the broken connection is."
Nov 15, 2009 | 2wire (1000-000057-000) Modem
Modem is plugged directly into laptop but still not able to surf net. when looking at network connections it says it is connected but there is no sign of connection meaning the laptop cannot browse...
Re-boot your modem. unplug it wait about 10-15 seconds, plug it back in and it should get your laptop's address. Did you have the modem connected to another device? for example a Desktop pc or a xbox360 or ps3. if you did, everytime you switch devices, you need to re-boot your modem.
Sep 14, 2009 | Arris SURFboard SB5120 Modem
Msg. conntected with limited access
Try this.
Unplug the Router.
Unplug the modem.
Wait about 15-20 secs.
Reconnect the modem.
wait about a minute or until all the lights are solid on the display.
Reconnect the Router.
Wait about another minute until everything is given time to start up.
Try connecting again.
If it still does that, it may be a problem with your computer that your trying to access with wirelessly.
My mother had that problem on one of her laptops, it turned out that her particular installation didn't support WPA or WEP incryption. I did a full reinstall and now it works.
If you want to avoid a full reinstall you can try uninstalling the wireless network card, then reinstalling it.(Make sure you go to your manufacturers web site first to download the proper driver for your model)
I hope this helps,
Simon.
Nov 19, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Cant connect thru DSL(LAN)
hey there i am having a problem with my Vista home premium. = false
I cant connect or get my broadband connected to DSL. = true
but everytime i use my fone as a modem i can surf the net. = true
how come i cant do this with the DSL Line?
1. Your DSL line requires a special kind of modem a DSL modem not a phone modem.
Thank you for choosing FixYa!
Az. Wizard Division.
Sep 23, 2008 | Microsoft Windows Vista Home Premium with...
LIMITED OR NO CONNECTIVITY
the setup will not really work because of the message that you are getting. LImited or no connectivity means that you computer recognized the connection but its not getting an ip address to the router. Have you tried turning off the router and leave it off for a minute or two and see if you resolve this issue? Is your power light solid green right now?
Aug 14, 2008 | Linksys Wireless-G WRT54G Router
Motorola SB5101
ya u should have a router instead of a modem because modem provide only one ip address>and there is no DHCP server in the switch or hub>so buy one router which has 4 ether net port and connect it directly to the modem and connect ur two pc's behind the router then both will get a seperate ip address from the router both will go online
the connection is
modem-->ether net cable to the inter net port on the router-->and two ether net cable from both pc's to the 1 and 2 ether net jack on the router reboot all the devices>and modem+router+pc's then it will work>rate me solved if its helps thx
Nov 14, 2007 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Microsoft Windows XP Home Edition Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
