Question about Carrier 38CKC042 Air Conditioner
Model no. 38DXA330713. The condencing unit is continually going even though the system inside has been turned off. The only way to stop it is turn the power off.
  • Carrier Master
  • 43,501 Answers
The contactor for the compressor outside is welded together...after may times of arcing the contacts get too hot and then get stck to gether then the unit will not shut off...
replace the contactor and you will be good to go...
heatman101
Posted on Apr 23, 2010
How can I stop the oven igniter continuing to spark after the oven has lit
This should not be a problem as the setup is it doesn't know which gas knob has been turned on, therefore the oven and grill spark to ignite either .
Hope this is helpful
Regards
John
PS if I had known the make and model number you can probably get a manual online.
Oct 31, 2014 | Ovens
How do you replace the door switch in a Kenmore 70 Series 68702 electric dryer?
What is the model number of your unit? Look inside the door area.
Nov 19, 2012 | Dryers
What would cause the compressor to not turn on with a Carrier Model FY4A? The fan continuously runs but the A/C wil not turn on. The thermostat shows that it is cooling but the unit does not turn on.
Check power to outdoor condenceing unit. if no power reset breaker or change fuses.If they blow again you have a short in the unit. If you have power to unit and is still not comming on call a service provider!
Jul 31, 2011 | Carrier Heating & Cooling
Fan stops and heater continues to heat.
Hi, If the main fan stops blowing air but the burners continue to stay on and not shut off, this is dangerous. It sounds as though the fan control combination limit switch is faulty or stuck. The burners should shut off before the fan. If this unit only has a high limit for safety, it should shut the burners off when it reaches a predetermined temperature to keep the unit from burning up. That's why these safetys are in place. If your furnace has the combination fan/limit control, and it is stuck or has failed, this will cause the burners to run. I would turn the main gas off until the problem is found, or kill the power. Can you give me the age of the system, and model, serial numbers and the name of the heater? This would be of help. I would be very careful if you use it if its very cold where you are, and turn it on and off as needed. Do not go to sleep with it doing this for your safety,please. Get back to me if you will.
Sincerely,
Shastalaker7
May 19, 2010 | Heating & Cooling
Ouside unit runs continuously, even if system is off
the contactor is stuck you might try killing the breaker to the condensing unit if it stops then it is the contactor
Oct 10, 2009 | Heating & Cooling
No air blowing inside the house thru vents;starts fine than stops
You are likely low on charge and the unit is freezing up. You need some with gauges to check. You should not try to run this unit until then or it will burn out the compressor.
Jul 18, 2009 | Ruud Central System Air Conditioner
My Heating system
Can you provide me with a make of the furnace and a model number if possible. They will be found on the heating system cabinet inside the unit, not on the thermostat.
Jan 16, 2008 | Honeywell Programmable Thermostat Heater
Carrier 38CKC042 Air Conditioner Logo
127 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
