Question about Air Tools & Compressors
Where can i buy a replacement hose and attachments for a vector air compressor VEC256? CONNECTION TO VALVE WORN OUT.
  • 2,841 Answers
Any place that sells air compressors and accessories will have the parts you need. Just take the old parts with you for a replacement.
Posted on Apr 24, 2010
Testimonial: "quick and logical."
My pancake air compressor will not build up any pressure
first control non return check valve on the tank second the hose connections and pressure line tirth cilinder membrane or piston ring worn if an oilless compressor Usually under pressure control a pressure reliever which must be forced out of pressure, it may be that the pressure gauge does not close off
Jul 14, 2017 | Air Tools & Compressors
My Porter Cable pancake air compressor is getting too hot and melting my air hose
ASSUMING THIS IS AN ELECTRIC MOTOR DRIVEN SINGLE STAGE COMPRESSOR, IF THE COMPRESSOR USES OIL IN THE CRANKCASE, THE PRESSURE SWITCH SHOULD CUT OFF AT 125 PSI AS THE ACT OF COMPRESSION HEATS THE AIR QUITE HOT. THERE IS ALWAYS SOME OIL THAT PASSED THE PISTON RINGS IN THE COMPRESSED AIR. IF THE COMPRESSED AIR GETS HOT ENOUGH, THE OIL VAPOR CAN IGNITE AND THE FLAME CAN CARRY TO THE TANK FOR AN IMPRESSIVE EXPLOSION. THIS ORDINARILY DOES NOT HAPPEN BELOW 175PSI OR MORE.
OILLESS COMPRESSORS CAN BE SET TO 150 PSI. WITH EITHER TYPE OF COMPRESSOR, THE HOSE SHOULD BE ATTACHED TO THE REGULATOR OR THE REGULATOR STACK, NEVER TO THE COMPRESSOR, AS THE COMPRESSED AIR LOSES MUCH OF ITS HEAT WHILE IN THE RECEIVER. IF THE WHOLE TANK IS GETTING HOT ENOUGH TO MELT A PROPERLY ATTACHED HOSE, YOU HAVE A DANGEROUS SITUATION, CHECK THE OPERATION OF THE PRESSURE SWITCH, UNLOADER VALVE AND RELIEF VALVE. THE RELIEF VALVE SHOULD OPEN AT NO MORE THAN 150 PSI, THE UNLOADER VALVE OPENS WHEN THE PRESSURE SWITCH SHUTS THE MOTOR OFF, AND SHOULD ONLY HISS FOR A FEW SECONDS AS IT DUMPS THE PRESSURE ONLY IN THE COMPRESSOR AND THE LINE FROM THE COMPRESSOR TO THE TANK INLET CHECK VALVE. IF THE UNLOADER VALVE HISSES MORE THAN A FEW SECONDS, THE TANK INLET CHECK VALVE IS LEAKING AND NEEDS TO BE SERVICED, CLEANED OR REPLACED. IF THERE IS CARBON BUILD UP IN THE VALVE, THERE IS EXCESS OIL PASSING THE COMPRESSOR PISTON RINGS, REPLACING THEM MIGHT FIX THAT IF THE CYLINDER OR RING LANDS ON THE PISTON ARE NOT TOO TAPERED OR WORN.
Jan 25, 2016 | Porter Cable Air Tools & Compressors
I have a Black Cat portable air compressor model BC2502. It doesn't build air just runs
Ron:
You have an air leak somewhere. I use a pump-spray bottle with a soap and water solution while the compressor is running. Spray the soap solution on each end of the copper tube leading from the compressor motor to the air tank and look for bubbles. Correct any bad connections (tighten and/or replace any packings) Spray each hose coupler with the solution and look for bubbles. If there are no leaks, you may have to remove the cylinder head and check the valves in the valve body between the cylinder head and the cylinder. You will need to buy replacement gaskets if you remove the head from the cylinder.
May 23, 2014 | Air Tools & Compressors
Porter cable FR350 round head nailer type 2 fires when it is connected to air hose and won't fire afterward
Various nailers will fire on their own when connected to air if the orings have become hard or worn and internal trigger valve parts worn-out (mostly Dewalt and P/C). You could buy an oring kit or purchase trigger valve seperately. Replacing trigger valve and lubing the headvalve with white grease will most likely solve the problem. After repairing the gun, be sure to remove the nails from the mag after each use to prevent possible discharge of nail. Good luck
Oct 21, 2012 | Air Tools & Compressors
I have a Vector #VEC021C Jump Start System with a compressor. The compressor hose seams to be missing a part. How does the end of the hose connect to a tire valve? My unit hose seams to have nothing to...
Most things have manuals online you can download for free. It does sound like your missing a part.
In case you don't know a PDF (Portable Document Format) is an interactive manual.
This link shows the part (to fill a tire) that should be on yours
http://auto.manualsonline.com/manuals/mfg/vector/vec012pob.html
On this page - click where it says "Download as PDF" and save it to your computer.
You can then open it with a PDF reader such as (Acrobat Reader DC).
P.S.
I just did a search in Bing for your System.
The search term I used was ( Vector #VEC021C Jump Start System - Manual )
Nov 14, 2017 | JUMP START SYSTEM
I have an 80 gal Craftsman air compressor who just shut down, the pressure is dropping, it made a smoke smell and it blew my circuit breaker. I tried starting my circuit breaker but it kept flipping off....
Usually related to the in-tank check valve. Follow the discharge hose from the pump to the tank. At the tank the hose attaches to a brass valve (or metal valve). This brass fitting is the check valve. It's purpose is to hold air in the tank and not allow the air to load the compressor when motor is trying to start. Easy to test. Use another compressor to pump air into your tank thru the quick disconnect or remove the safety valve and install hose there. Pump in about 75 psi and looks for leaks with soapy water. Remove air inlet hose from check valve and check for air leaks. If leaking, replace with generic valve available at www.grainger.com or order from sears parts. If no leaks then suspect unloader is not working at the pressure switch. If both the unloader and check valve is ok then test capacitor for reading within 95% of rated valve. Good holidays
Dec 14, 2010 | Craftsman Air Tools & Compressors
My Air Mate MK190 compressor does not pump up preasure.
Check the pitcock valve to make sure it is closed. This valve is used to drain moisture in the tank and could be damaged or open. Make sure the safety valve is not stuck open (it is spring loaded and has a ring attached to it). Last is to check the tube connections from the tank to the compressor housing (be carefully, the tubes and housing could be hot). Do you hear any air leaks? You can use some dish soap and water to drip some on the hose fittings and valves to help see the air leaks. Other than that, it sounds like the motor connection or piston.
Jul 01, 2010 | Dewalt d55151 factory reconditioned emglo...
The air compressor attachment broke. Is there a
I purchased a replacement part (air chuck) at Wal*Mart. Lubricate the end with soap so it will slide inside the hose and then secure it with a small hose clamp. And, as previously stated. In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. www.blackanddecker.com/CustomerCenter/Default.aspx
Mar 07, 2010 | Vector 1 Million Power Series Spotlight &...
The compressor continues to run but no air enters the tire, the tire just seems to get more and more flat.
Hi, I suspect the plunger for the valve stem connector on the pressure head is not depressing the air release pin in the head of the valve stem.
I have a Black and Decker and have to use a valve stem seat removal tool to quicky unscrew about 3 to 4 turns the stem seal and then connect the air hose head. After the tire reaches the correct air pressure I have go thru the tighten the valve stem seat drill.
You can buy the vavle stem seat tool at any auto parts store. I keep mine with the compressor.
I don't want this to sound bad but... is the air hose supply vavle turned on? Some have a slider button on the valve you have to push to charge the hose. If the hose is charged then see above.
Thanks for using FixYa.
Kelly
Feb 10, 2010 | Campbell Hausfeld 02-Gallon Air...
Replacing rubber hose on air compressor
You should be able to replace it, but it will require disassembling the unit. I do not have a diagram for you, but it shouldn't be too hard.
If you need more help, post a comment.
Thanks,
Tim
Apr 10, 2009 | JUMP START SYSTEM
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
