Question about Dishwashers
Spray arms appear not to rotate - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote about my experience with something like that...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Apr 23, 2010
Dishes are cloudy and have soap residue. Have cleaned upper &lower spray arm often, as good as posible (find holes plugged). water level & temp. seems normal . Water intake screen appears clean
Clean the spray arm jet holes if they are blocked. Check whether you have filled the rinse-aid dispenser.
Check whether arm turns freely when rotated by hand manually.
May 26, 2010 | Maytag MDB9600A Jetclean II Built-in...
Baumatic BD1631 dishwasher isn't washing the top tray. The rotating sprays are clear and hoses appear ok. The 'salt needed' warning light is on even though I've filled it with salt. Any ideas?
Try rotating the arm manually. Check whether its freely rotating. Clean the rotating axis area.
Check whether the pressure reaching the top spray arm hose.
May 21, 2010 | Dishwashers
Both spray arms of my DU943PWKQ0 do not turn or spray. The motor is moving and the it drains without problem. During the wash and rinse cycle I can hear the sound of water, however it doesn't clean at...
Try rotating the spray arms by hand. It should rotate freely. If possible clean the arm rotating place by removing them.
Arms rotate by by pump pressure only. finally check the water pump also.
May 18, 2010 | Whirlpool DU943PWK - Multiple Color...
High pitch electrical sound and silver spray bar under bottom dish rack doesn't appear to be rotating on wash cycle; also 2 inch round washer under where arm screws in disk has broken, could this be it?
i would replace the lower wash arm hub and mounting components and check the silver arm for debris plugging the wash water spray holes while its off to replace the hub
Mar 13, 2010 | Dishwashers
Top spray arm does not rotate, is mechanically
try checking the water holes in the arm, as when they spray out the arm turns. If they are blocked in any way it does not turn, try using a needle to check they are clear.
Aug 07, 2009 | Electrolux Kenmore 24 in. Built-In...
Spray Arms won't rotate
good day,
hope this link below will solve your problem.
kitchen appliances
Jul 16, 2009 | KitchenAid Architect? II U SERIES KUDS03ST...
My Bosch dishwasher model #SHU43C05UC/14 drains well and has enough water(I replaced the inlet water valve already),but not washing the dishes clean especially the top rack.What could be wrong?
open machine when running and check both spray arms rotating - you will get a bit of water out. if spray arms not rotating, usual cause is debris in the arms. the spray arms only rotate by water jetting from angled jets at the end of the arms. take them out and make sure all debris removed
Jul 14, 2008 | Dishwashers
I replaced the spray arm seal, but the arm still wont spin. I get water but not enough pressure to turn the top arm. The bottom arm works fine. Should the top arm turn easily when pushed by hand. It...
arms should turn freely. spray arms are only rotated by water spraying out from angled jets at end. check for blockage in spray arms - sweet corn and rice are the worst offenders. take spray arms off and run water in centre hole and see it runs out of all the jets freely
Apr 08, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
Dishwashers Logo
119 people viewed this question
Top Dishwashers Experts
