Dynex 19 inch tv used as pc monitor; the pc display is bigger that the width of the viewable screen which cuts off about 1/4 inch on each side making it difficult on some things to shut down since the large red X is hidden. Is there a control to adjust horizontal width like on a regular pc monitor. I found the horizontal position adjustment but can't find the width size adjustment. Thanks, Harry
  • 12,061 Answers
\http://www.retrevo.com/support/Dynex-DX-LTDVD22-TVs-manual/id/23122dj497/t/2/
Above is a manual link. usually you use multiple presses on the buttons to get to the menus. One button, is menu, the others are for up.down & left/Right. The same as for Horz Posn. You press the menu, use the L/R buttons to go to the menu item, then up and down to + or - the setting.
have a look at the manual.
Posted on Apr 23, 2010
Desktop only partially viewable on monitor
How to fix it depends on what operating system you use. For Windows right click on the desktop and choose Screen Resolution. Look under "What display should I use" and follow the instructions or simply drop the resolution down one step
Mar 18, 2014 | ASUS Computers & Internet
How can I connect my Dynex DX-32L151A11 32" LCD
The main set up is that you need to set your PC video resolution to the native resolution of this TV in PC mode otherwise the pictures will look real bad and not clear. No driver needed.
To use the TV as a monitor will not be as good as the PC monitor due to limited resolution the TV can display.
Here is the user manual:
http://www.dynexproducts.com/cms/documents/DX-32L151A11-37L130A11_10-0567_WEB_ENG_V1_Final%20lr.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Jan 01, 2011 | Dynex 19 in. LCD Flat-Panel HDTV
Does a dynex tv connected via vga to PC come up as a genaric monitor in windows display panel? Is this normal? or is there a way to make it identify it as a large screen tv for better resolution range?
If windows cannot identify the monitor that you have connected it will show up as a generic monitor. If you are able to find a driver for the monitor then windows will show that particular monitor instead. If Dynex has a website you can check there to see if they have a driver for your TV, or you can check under there support section to see if they suggest anything that might help.
Mar 02, 2010 | Dynex 19 in. LCD Flat-Panel HDTV
Dynex 19Inch Vga no signal
You may need to set up the video card to see the TV so you can display the computer on it.Somewhere in the setting for your video card should be settings for that.
Jun 01, 2009 | Dynex DX-LCD32-09 LCD TV
Computer monitor does not use whole screen
Use the controls on the monitor to adjust the screen width.
Mar 30, 2009 | Computers & Internet
The viewable area is bigger than the screen. I
You probably need to go into the control panel and change the resolution for your display
Mar 12, 2009 | ViewSonic VP920b 19" LCD Monitor
19" hansol 920p monitor
To my knowledge, it is not the zoom that has to be adjusted but rather the horizontal width, zoom would expand all (to, bottom & both sides) whereas your only concern are the two sides.
Should the horizontal width not fully expand, then there is an internal problem with the horizontal deflection circuitry which could either be the yoke, a capacitor or shunt diodes. In certain instances, a below normal voltage at the mains or the internal power supply could also cause this.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 21, 2008 | Hansol Multitech 920p 19" CRT Monitor
My new 19 inch 1952 LG monitor stretched my display picture from what I use to have on my 17 inch. How do I adjust the height to width ratio for a picture that isn't distorted?
Right-click your desktop, click properties
go to 'settings' and select the 19 inch monitor
now change the resolution to the format you want to use.
Set it to something like 1600x1200, or 1024x768
Apr 04, 2008 | Computers & Internet
ACER AL2223W
right mouse click on the desk top screen go to properties, go to settings, see if that helps
Nov 26, 2007 | Acer AL1916W 19" LCD Monitor
Dell m992 monitor screen width
The link below is a Digitally signed M992 monitor driver. http://support.us.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R44148&formatcnt=1&libid=0&fileid=51992 Also try upgrading to the latest ATI software and drivers. You can also try and change the frequency refresh rate to 75mhz. It in the Control Panel under 'Display' and tab 'Monitor'. It shows a list for frequencies you can try.
Oct 02, 2007 | Dell M992 19" CRT Monitor
Televison & Video Logo
232 people viewed this question
Top Televison & Video Experts
