Question about Coleman Mach III Air Conditioner
Have atwood furnace and coleman mach thermostat and it would not shut off. I unplugged power to rv and had to hit battery disconnect so that it would stop.waited few minutes...turned on...heat would not come on but blower ran until I had to unplug and start over. Is it my thermostat?Then abut 3 hours later went through the whole process again...heat came on..all well....then heat shut off...blower kept going and could hear clicking noise from furnace, (trying to light) and would not work.
  • Coleman Master
  • 6,674 Answers
It may be your thermostat, but try this first to see if time delay relay may be sticking. When it won't shut off, turn propane off, and go outside and unscrew the 2 screws that hold your cover on, and lower the cover down. Look straight ahead, attached to the housing of the fan up near top you'll see a square relay (time delay relay) with 4 male spade connectors, and wires attached to each. It's usually held on with 2 Philips screws. Give it a little rap with the handle of a screwdriver or similar a couple of times, and see if fan stops running. While your there as well, pull the wiring connector off the ignition board, and put back on a couple of times, to clean the connections. Now try it again, and let me know what happens.
Posted on Apr 26, 2010
    Scholar:
  • 63 Answers
I have an Atwood AirConditioner/Furnace on the ceiling of my Everest 5th Wheel that would not shut off yesterday, and then when I pulled the 12v fuse(which turned off the refridge&furnace) left it off a while, then plugged back in, after replacing the batteries to the remote control, and seemed to run fine. I am not sure,but I suspect the low batteries in the remote were the problem. Also, the remote might have accidently been set to the "I FEEL" setting, which drains the battery. The whole system was designed and made by money-hungry demonic nitwits who cannot write a good user/repair manual, but we can get thru these problems together on forums like this!
The RVparts place suggested in LV has a good website for parts and prices! Thank you all!
Posted on Mar 20, 2011
Brand new Coleman Mach 8 RV aircon worked yesterday but today blue on light just keeps flashing and no compressor working
If you Google airxcel.com, you should get some options. to get either their literature or tech support and they should be able to help you.
Nov 07, 2015 | Coleman Mach III Air Conditioner
How do i bypass the furnace and still use the duotherm 57915.531
Do you have the digital thermostat? You can tell the thermostat you have no furnace. You should be able to disconnect power at the furnace, but the 12v power for the circuit board is provided by the furnace circuit on some systems so make sure you disconnect the wire going to the furnace and leave the wire feeding the circuit board.
Oct 06, 2014 | Coleman Dometic Duotherm Rv Air...
Why did my RV rooftop a/c shut off when I unplugged the furnace?
Yes you do so it only runs on ac ,but when you said rooftop unit do you mean condenser or does unit have evaporator fan too
Jan 20, 2018 | Coleman Mach III Air Conditioner
Coleman mach 6759C707 quit on us, only the fan is running. What do i need to replace? The compressor? WHat part number?
my coleman 7330 fan only runs when ac unit is on and then sometimes shuts off and then restarts
Aug 18, 2011 | Coleman Mach III Air Conditioner
Coleman Mach a/c will not turn on. But the furnace will turn on when switched to cool high and no a/c or blower. What can be the problem?
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jun 29, 2010 | Coleman Mach III Air Conditioner
Coleman roof top a/c, is the heat controlled by thermostat
hi
on the new colman units (trane) the heat is control only from the t-stat.
i will reccomand a programble t-stat for the new unit.
thanks
Nov 02, 2009 | Coleman Mach III Air Conditioner
Coleman Mach III Air Conditioner Logo
882 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
