Question about Rockford Fosgate Punch 301S Car Audio Amplifier
Due to no electrical safety fues on the amp my channels burnt up because the speaker blew can i buy channels for my amp or do i throw it away I own a punch 301s 900watts
  • 86 Answers
Your amp can be repaired by a professional to hard for someone without electronics training. you may find it is to expensive to repair. new will probably be your best bet.but do find out about repair before buying new. I have a local shop here that has a 60 dollar fee to look at it then if parts are needed they have an hourly rate plus parts. good luck
Posted on Apr 23, 2010
2010 VW CC factory stereo amp popping sound
If the amplifier itself is making the popping sound I suggest you disconnect it immediately, as it could be an electrical short within the amp. If the popping sound is actually coming from the speakers, it could be due to a crossed wire, blown amp channel, or blown speaker. If you posses the technical know-how, you can test the amp channel and speaker by connecting a different speaker to the channel responsible for the popping sound. If the new speaker makes the same popping noise then it is most likely a blown channel. I hope this helps =)
Sep 24, 2013 | JVC AM FM CD DET FACE CAR STEREO
Why does only one speaker channel play? Did i blow a fuse if the speaker wires touched?? Where are they located?
If its the stereo = Blew a channel, Get a new one.
If its the Amp = open it up , there should be 2/4 little white fuses,,
find the one with a light Brown/Black burn mark, remove and replace bad fuse.
If amp is all Digital Buy a new one..
Your Welcome
HotRod42069
Jul 16, 2011 | Car Audio & Video
My amp blew the 20 amp fuses. Replaced and they blew as soon as the radio kicked in. Took the back off to look for any burnt connections or blown open/expanded capacitors or resistors. It smells like...
Remove all the wires from the amp including the remote turn on wire. Once you do that, after about 30 seconds the amp will reset. Hook the power up first, then the ground then the remote. Turn the unit on and check for power WITHOUT the speakers hooked up. If you get no power by now it's a good chance that the amp is cooked. If you do get power, try hoking up your speakers first on one channel then the other channel and then bridged. If it cuts out or off when you touch the speaker wires to one channel or the other, then that channel is no good. Hope this helps.
Mar 17, 2011 | Kenwood KAC-728S Car Audio Amplifier
Guitar Amp Troubles.
Either the speaker is blown or the audio power amp section blew.
Paul
Jun 12, 2009 | Audio Players & Recorders
Logitech x-530 5.1 Speakers Transformer blew
at the cost of some equipment today they are throw away when the dont work and buy new. if its a small transformer you might try radio shack multi volt unit . bring in old transformer so the can match speaker side of wire.
Dec 06, 2008 | Logitech X-530 Computer Speakers
Amplifier main channel non operational.
first pull out the power transistor then biased the output terminal. base,emitter have dc volts .4 to .5 collector to emitter have full voltage. if this voltage are in ur pre amp buy new trasistor
Sep 09, 2008 | Audio Players & Recorders
Output board for Altec Lansing ADA995
I had the same problem. One day I heard two pops and the speaker, including the power light, were dead. Neither Dell nor Altec Lansing support them. They're throw-aways, unless you know a genius electronics technician.
Dec 24, 2007 | Audio Players & Recorders
Amp trouble
You proberbly just blew that channel on your amp, maybe you should just take it in o a sound shop and ask them to fix it, the problem shouldn't be big enough for you to throw away the amp...
Apr 25, 2007 | Kenwood KAC-X501F Car Audio Amplifier
Mtx blue thunder pro3002
Take this apart and look at the magnet wire windings look for any thing broke or burnt. If not it is very likely it is more cost effective to buy new.
Feb 01, 2007 | MTX Thunder 2-Channel Amplifier 502 Car...
Rockford Fosgate Punch 301S Car Audio Amplifier Logo
162 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
