Question about Casio FR-2650A Calculator
The paper feeder works when used, but doesn't work when calculating. Any suggestions?
  • 1 more comment
  • SteveErdody Apr 23, 2010
    It doesn't want to feed when printing.
    I don't know if you received my reply. The feeder is not working very well right now. Could there be a paper size issue?
  • SteveErdody Apr 24, 2010
    My Casio FR-2650A calculator is not feeding the paper properly. It works occasionally with feed button, bit doesn't move when calculating.
  • 1,284 Answers
Hi, this could be caused by rubber that has become clogged with paper fibers or has gotten hard.
If you open the machine and look for the drive mechanism you will likely recognize the part responsible for advancing the paper.
Alcohol can complicate things sometimes as it can dry out the surface that you want to have slightly tacky. I would try lighter fluid (naptha) and a lint-free cloth or paper towel to scrub the surface of the roller to remove built-up fibers and it may also remove some dead rubber that will show up as a black deposit on the cloth.
Parts for these trusty companions has become increasingly scarce since they are passing out of use with time and the advent of disposable printers. Most of those folks using these machines are reluctant to replace them but that may be your only recourse.
Take care
Posted on Apr 23, 2010
  • 10,865 Answers
Hello. Sorry for your trouble. Do go to this link http://www.casio.com/support/authorizedservice/ and find the casio service center closest to you. You need a repair and these centers have the parts and the know-how to do it right the first time. Joe
Posted on Apr 24, 2010
  • 2,335 Answers
Do you mean that the paper feeds off the roll when you press the Arrow button, but that it doesn't want to feed when printing/operating, and just prints on the same line over and over?
Or do you mean that the unit isn't printing at all.
Just trying to qualify and understand your situation as best as possible.
The paper feeder does not work. It hums and shows error.
DEBBIE LOOK IN THE OPERATORS MANUEL OR CALL CASIO CUSTOMER SUPPORT
Jan 21, 2016 | Casio Office Equipment & Supplies
The feed button does not work at all
Maybe it needs to be cleaned and possible build up of small pieces of paper are stuff in feeder and you can not see it. Or it is just worn out the gears.
Sep 29, 2014 | Casio HR-100TMPlus Calculator
I have a Canon MP210 scanner/ printer that is telling me I have a paper jam but there is no paper in the machine. I've turned off the power and turned it back on, I've looked for a small piece of...
Your printer might be out of paper.. so try this..... press Black/Color button... if it doesn't work turn off your printer and press paper feeder on the back side and press the power button with holding the paper feeder. Don release it until the process of printer is complete... thanks
Aug 26, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
ImageRunner 1023iF auto-feeder stops mid-way through document. Pick-up and feed Wheel continues to spin for a moment, then stops and gives "Check Document" error. I have fed a card through the...
It can be the problem in sensor flapper on ADF tray ( small nose that is pointing out ). Maybe it doesn't works fine or in the middle of the copy from adf the paper is too far away from the sensor.
Also can be the problem of ADF pickup clutch or You are using unappropriate paper type- try with normal A4 80g/m as original to copy from adf.
Hope that something of this helps You!
Jun 02, 2011 | Canon imageRUNNER 1023iF Black and White...
Check paper error persists despite no paper in feeder or paper jam. cannot use auto document feeder due to this error. can i reset the sensor or do something else to clear the error?
I had one of these printers claiming there was a paper jam, when there wasn't. As others have suggested, three hard slaps above the paper tray, and hey presto, it works.(This seems to be the resolution to all problems. It will probably refill the cartridge too ... hmmm)
Feb 16, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
Document Feeder jams
I got adventurous and removed the screws holding the document feeder. I then used a can of air and blew into the gears and then reassembled the feeder. It works perfectly.
Feb 05, 2009 | Brother MFC-7820N Laser Printer
Putting new paper roll in
It's difficult to see, but the feeder for the paper is on the back of the machine, just below where the roll of paper goes. You'll see a little slot above the opening for the batteries. Feed the paper in here and push the arrow up button above the ON/C button to get the paper feeding through the mechanism. It should pop out at the top!
Jul 29, 2008 | Canon P200-DHIII Calculator
CANON P23-DH V
There is a small slot below the removable ribbon cover. Cut the end of the paper so that you have a 45 degree angle.
Example:
/ l
/ l
/ l
/ l
/ l
l l
l l
It does not have to be so sharp of an angle, but it helps to get the end through the maze.
Insert the paper into the slot, and wiggle it through until you can grab the end of it. Pull the paper through, and slide it through the cover, and reinstall the ribbon cover.
When putting the paper on the roller make sure that the paper is heading straight into the slot.
Example: _O, not like this: /O
Jul 09, 2008 | Canon P23-DHV Calculator
Constant "load paper in tray" error even when paper is loaded.
Contacted HP CEO, office getting some interest now!
Re bad paper feeder Did not use main tray feeder until now!
Nov 30, 2007 | HP Photosmart 3310 Printer
Casio FR-2650A Calculator Logo
263 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
