Question about Maytag Neptune MDG5500AW Gas Dryer
Isn't heating up. takes forever to dry,
Especially takes longer on less than regular heat. What use to take less than 45 minutes now takes 65 and clothes still aren't dry.
  • 10,319 Answers
Disconnect the complete exhaust vent tubing and clean it out thorourghly. Then it will dry. There is a moister sensor in your dryer and when the lint builds up inside the vent tubing the sensor shuts off the burner to prevent fires from starting
Posted on Apr 23, 2010
Testimonial: "thank you. I'll try that. I'm a female trying to learn to do more for myself than having to depend on others or pay somebody."
Ny dryer spins and gets hot but there seems to a problem with the exhaust air flow. It only blows lightly and take hours to dry a load.
Posted on Jul 31, 2010
  • Maytag Master
  • 43,501 Answers
Your ignitor is going bad and the burner is taking too long to light up...
If you have a gas dryerisn't heating up.  takes forever to dry, - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
My dryer only damp dries. Cannot dry towels. seems to take forever to dry anything
Hello there and thank you for choosing fixya
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jun 29, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Whirlpool dryer....heats
You could have heating element going bad, or a plugged dryer vent. Start with dryer vent, make sure all lint is out of it, all the way through it, even if it goes to the roof, or out the wall. Also vacuum out back of dryer and inside vent tube. This should help with problem. If not then replace heating element its getting weak.
Jul 19, 2009 | Whirlpool LER4634J Electric Dryer
Dryer not drying due to lack of heat
Check the following text to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Jun 11, 2009 | Whirlpool GEW9250 Electric Dryer
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
1. Venting
2. Thermostat
3. Heating element
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
1. Venting
2. Thermostat
3. Heating element
Jun 03, 2009 | Kenmore Dryers
Not heating properly, many cycles to dry loads
1. Venting
2. Thermostat
3. Heating element
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Clothes won't dry
1. Venting
2. Thermostat
3. Heating element
Jun 01, 2009 | Whirlpool ET8CHEXSQ Dryer
Kenmore Electric dryer runs on cool down forever.
Call the mfr and ask them about it. This problem may be pretty complicated. There may be a problem with your board that tells it to go to cool down. Can you set the timer for 45-60 minutes and it stay on heat for that long?
Feb 11, 2009 | Kenmore Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
253 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
