Question about Dell Dimension 3000 PC Desktop
I got a modem for DSL. I hooked up all the wires.
I got a modem for DSL. I hooked up all the wires. No internet. When I conacted TDS they said the NIC card is corrupt or missing. How do I tell? And where does the ethernet cable plug into the back of my computer ?
  • 258 Answers
If you can't plug in the ethernet cable to the back of the computer, then there is no ethernet card (NIC).
You'll need to buy an addo-on card, which doesn't cost a lot, plug it in and install the software which comes with it.
Posted on Apr 23, 2010
    Genius:
  • 1,354 Answers
I JUST BOUGHT THE D-LINK DIR-615 (N300) _ WIRELESS ROUTER, IT TELLS ME TO HOOK UP TO MY MODEM BUT I DO NOT HAVE A MODEM, I HAVE DSL BUT IT IS RUN FROM THE OUTSIDE BOX ALONG WITH MY TV AND PHONE, MY DSL...
The router needs to have a modem to run off from, Even DSL provides modems if you do not have a modem then your DSL ISP (Internet Service Provider) did not provide you with one. I would suggest to follow the ethernet cord and see where it plugs into. You will need a modem to use a router.
Feb 18, 2011 | D-Link DIR-615 Wireless Router
Tip
Internet Connection Basics
Modern high-speed internet connections are made using DSL or cable modems. In general, most DSL modems also act as routers, but not too many cable modems act like a router.
Some internet connection basics: Every device connected to the internet has an IP (Internet Protocol) address. The address consists of 4 groups of up to 3 numbers each. They would look like this: 123.111.36.145 (0 is the smallest number and 255 is the largest you will see). When you connect to the internet, you are assigned an IP address by your ISP (Internet Service Provider). When you hook up your computer
to the modem, the signal is passed through the device to your computer and the device's IP address becomes your address. This is not secure, as the "bad guys" could type your IP address into their machine and theoretically see your computer and access all your data.
Connecting with your modem: Modems come with a CD nowadays. Running the setup CD makes connecting quite easy. With a DSL modem, you normally have to provide a username and password to log on. Cable modems generally rely on the cable connection to your house to recognize who you are and when you run the setup CD, you are automatically connected.
The router: The purpose of this device is twofold--one is to take the signal you get from your ISP and send it to a number of computers in your home network. The second purpose is to take the IP address and send it to a different address on each computer. This acts as a "firewall" in that the IP address assigned to your computer is no longer the address of the computer. Those bad guys trying to hack into your system will have a much more difficult time.
Types of routers: There are wired routers capable only of hooking up computers with ethernet cable within a network. There are wireless routers--normally these have 4 wired ports and a set of antennas. These function will in a mixed environment of wired and wireless computers. Most people these days are using wireless routers.
In my next tip, I'll describe how you go about hooking up your new router to an existing internet connection.
on Aug 09, 2010 | Computers & Internet
Siemens Speedstream 4100 Modem. Much of the time the DSL light on the modem flashes red even when the computer is not even connected to the modem. Part of a page will load and then I get a notice that the...
The problem may be with the DSL connection, not the modem. Whenever my DSL connection starts dropping frequently it turns out to be something Verizon has to repair.
Apr 21, 2017 | Computers & Internet
D-Link DSL-2640-T. After power outage, I have a good wireless connection BUT no internet access. LAN line does not work either. Please suggest possible solutions.
chack your DSL settings may your not conacted with your sevice provider
chack your locale settings in modem try folowing setups
1. If you have a modem, connect the modem to the router(make sure modem should be connected to the port on which LAN, Internet, WAN is mentioned. It would be a separate one port on the router) and router to the computer.
2. Insert the disk that came with the router, inside the computer.
3. Follow the on screen instructions.
4.No, connect to the wireless
Apr 22, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a dlink dir628 router and can not get internet access but can find the access point i got throught the config. but can not get internet through the router wired or wireless but hooked up my old...
if you have one dsl modem & one router means you have to cofig dsl modem in bridge mode and router in dynamic mode.if you have any dout call me 9740575949
Feb 25, 2010 | Computers & Internet
I have hooked my di 524 from my DSL cable modem then hooked the two in line to my computer when I hooked up to the computer I have no connectivity why?
OK, if I understand:
telephone----DSL Modem--di 524--computer.
That is what you are supposed to do.
Has any configuration of these devices ever had any connectivity?
1. Is the DSL modem in "Bridge Mode"? That is the first thing I'd check.
2. Are you using the right wires and ports? There may be a DCE-DTE problem. Be sure you have used the wire that came with the DSL modem to hook it to the internet port on the DI-524.
3. What is the state of all the various lights? Do they show that you have valid connections?
4. Most of these devices can be configured with a browser. When you browse them, what do you see?
5. What is windows telling you?
Jan 09, 2010 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
Just connected router to clear network modem and VoIP (wireless phone service), now when the phone ring, it disconnects me from the internet and the connection is lost until the phone call is complete.
Is your modem a DSL or cable modem?
If it is a DSL modem do you have a DSL filter on each phone line to the phones in your house?
The DSL modem does not need a DSL filter on the phone line.
Nov 09, 2009 | NetGear WGR614 Wireless Router
I can't get on the internet
>> do i have to call my internet service provider to activate my modem?
Yes.
Each modem has a unique "address", and your I.S.P. uses that address to authorize each DSL-modem that tries to connect to their network.
Or, if the two of you live in the same house/apartment, you should just buy a "router". Then, both computers can connect to the router, and the router connects to the DSL modem, and both of you can "share" the monthly fee for the _one_ Internet connection.
May 27, 2009 | AT&T High Speed DSL Modem
Can't get a wireless router to work with a speedstream 4200
This may actually be an issue with your ISP. There is a good possiblity that your ISP has bound your connection to the MAC address of the network card on your computer. This is a common occurance which is why router manufacturers give you the option of having your router clone your computer's MAC address. Go into your router's management an perform the clone, sorry I cannot give you more details but I don't know the specific model of your Belkin router.
Jan 05, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Dell Dimension 3000 PC Desktop Logo
74 people viewed this question
Alun Cox
