Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
The wireless light is not lighting up. I am unable to connect to the Internet. I have rebooted the modem and router and still does not work.
    Problem Solver:
  • 11 Answers
ISSUE: No wireless light in the Belkin Router and not anle to go online
SOLUTION:(Wireless light will lit up if u connect any device to the network)
Step 1: First hard wire Modem>Router>Computer
Step 2: Open internet explorer and type in this (192.168.2.1) address in address bar
Step 3: You see Belkin Router Ste Up Page
Step 4: In top right corner you can find internet status it would say Connected or Not Connected
Step 5: In your for left left screeen you can find list of options in that click on "Restore Factory Default"
Step 6: It will ask you password leave it balnk and click "SUBMIT"
Step 7: Click on "Restore Defaults" Button and It will show you two warning messages click "OK" "OK"
Step 8: Then you can see the router will reboot once it is completed you will be back to the Home Page
Step 9: In your for left left screeen click on "MAC Address"
Step 10:It will ask you password leave it balnk and click "SUBMIT"
Step 11:You can see Clone computer's MAC address Button Click on It "CLONE"
Step 12:Then you can see the router will reboot once it is completed you will be back to the Home Page
Step 13:In top right corner you can find internet status it would say Connected if its not
Step 14:Unplug the Power Cord from MODEM and RUTER wait for 2 minutes
Step 15:Plug the Power cord to Modem first and wait for 2 miuntes
Step 16:Plug the Power cord to Router and wait for 2 miuntes
Step 17:You can see Modem light in router will lit up standerd Green
Step 18:In top right corner you can find internet status it would say Connected
Step 19:In your for left left screeen click on 'Channel & ssid'
Step 20:Set the Wireless channel to 6 and in SSID type in your New network name may type in your first name
Step 21:In your for left left screeen click on " Wifi Protected Setup"
Step 22:"Disable" the Wifi Protected Setup
step 23:In your for left left screeen click on "Security"
Step 24:In the Security mode select "64 bit wep"
Step 25:Select Key 1 option and in the Key1 type in any 10 digit nunmber's that gonna be Wireless network security key
Step 26:Now go head scan for your wireless network name from any wireless computer and access it
Step 27:Type in the 10 digit network security key
Step 28:Now you can connect to the netywork and you can go online wirelessly from your wireles computers
Step 29: Now you can see the Wireless light lit up in your wireless router
Now your Good to go.... Check you can go online..Good Luck...Budy
If you need any help ....Please P.M me..... I'M here to help you all....
Thanks&Regards,
Karthi.J
Posted on Apr 23, 2010
I dont know how to get wireless internet
Check the ADSL or cable modem status light. If it is solid green, it indicates that your ADSL/cable modem has a good connection. If the light is off, check modem's physical connection.
Verify that the Internet light on your wireless router is solid or blinking green. It indicates a good connection and correct wiring.
When done, log in to the web interface of your router device and check if it can obtain the IP address from your ISP or not.
If you see 0.0.0.0, the router is not obtaining the IP address. It can happen due to various reasons. Contact your ISP and ask for the details including username, password for PPPoE etc. and try to connect to the Internet again afterwards.
You may also need to configure the default gateway settings also. To configure your router device as the default gateway, reboot your PC. When done, open Command Prompt, type 'ipconfig/all' and hit Enter. Check Default Gateway
If you are still unable to browse the Internet, ping your router's connection to the PC.
The Request timed out error can occur due to two things: (1). incorrect physical connection between your router device and the PC or (2) incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the router device.
When done, check back if you can browse the Internet or not.
***If you need any kind of technical assistance you can contact support cell
Jan 21, 2013 | Computers & Internet
Was having problems w/ internet connection. Brighthouse tech just left. Replaced modem and fixed a loose wire at box outside. Still won't hook to wireless and says that it is probably my router
If you have a separate modem and router turn both off and reboot only modem till all lights up the reboot router till all lights up in that order sounds simple communication problem between router and modem. If router modem combo unit disconnect either dsl or cable from router/modem leave diconnected for a short time then reconnect and reboot till all lights up. Hope this helps.
Sep 01, 2012 | EnGenius ESR-1221 EXT Router
Router problem. unable to connect wirelessly
This is usually up address conflict. You will have to assign the wifi or lap top to different IP addresses. You have to refer to the modem manufacturers instructions or search on net / YouTube how to do this. It's too detailed to do it here I think.
Oct 17, 2017 | NetGear WGR614 Wireless Router
Solid yellow Internet light on D-Link DIR-825
Try a new working LAN cable between your internet modem and the router. Is your internet modem connected and working? You should be able to directly connect using a LAN cable to check the modem connection. Reboot your modem and router.
Nov 16, 2011 | D-Link DIR-615 Wireless Router
I am unable to get connect to internet with ADSL2+ for BSNL.
First of all, try rebooting. A simple restart, which you can do by unplugging the power supply and plugging it back in, can fix a lot of problems.
If a reboot doesn't work, grab your router manual and check what the lights at the front are trying to tell you. Almost every DSL router has lights that indicate whether there's a phone signal coming in, whether your settings are ok, etc.
Mar 11, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Router stopped working.
As long as the power light stays solid, then the router is fine. You need to reconfigure the router for it to receive internet connection from the modem.
May 17, 2010 | Linksys Wireless-G Broadband Router
The only light on my router is the router light. No other lights are coming on. I have tried rebooting.
When facing the router, Globe/Internet LED is on the right. Below are the LED indicators; Check the steps below:
Wireless Security - This light will only turn on if the wireless security is enabled.
Wireless-Computer Status - This light will turn on if a wireless computer is connected to the router.
Wired-computer Status - This light will turn on if a wired computer is connected to the router. Connect the wired computer to any gray port on the router. (There are 4 gray ports).
Router Status - Power light. Solid blue means the router is on and ready.
Modem Status - If this is off, it means the router is not connected to the modem. Make sure the cable is connected from the modem to the yellow port on the router.
Internet Status - This light will indicate if the router is connected to the internet.
If this is the first time you are installing the router, then what is important is to get the router, wired-computer and modem lights ON. Once they are on, you may insert the CD that came with the Belkin router to setup the internet connection and wireless settings.
Dec 07, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Router Wont COnnect To Internet
Reboot your modem, router, and computer. Power them all down (unplug the modem and router if necessary) then boot the Modem, then after a minute boot the router, then your PC and see if all is well, it should be.
Jul 24, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Wireless router not connecting to internet
Unhook all wires except for the power cable. Press and hold the little reset button on the back of the router for 30 seconds ( I know, most sites say 5 seconds is enough...)
After releasing the button the router should reboot itself. Sometimes after the reboot you have to press the reset button again for just a second and release it. The wireless should reset itself at this point, but this will also reset all of the router settings. You will have to log into the interface and reset your security and other settings. The user id & password should reset to admin & motorola, unless you have loaded aftermarket firmware.
Apr 09, 2008 | Arris Wireless G Broadband Router (wr850g)
No wifi connection
Verify which MAC Address U have Cloned. MAC Address of Your PC WiFi and Cloned One must not be same otherwise it will not work...
Feb 02, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
323 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
