Marantz AV550 problem
My marantz av550 pre amp keeps cutting out and when I turn it back on it buzzes loudly inside the pre amp and through the speakers.
  • ssryan2 Jan 28, 2009
    After the buzzing stops the audio goes on and off repeatedly at a very low level. I have to turn it way up to hear anything.
    I don't see any loose wires or bad solder. It is a really loud noise that starts when i power it up and lasts about 3 seconds. there is the initial click, then the buzz and then nothing. there should be another click i think.
    any help is appreciated.
  • 10,594 Answers
How old is this amplifier and pre-amp?
Posted on Feb 12, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The only possible source of the buzzing sound in a pre-amp would be relay(s). Since there are no high power components, this could either be a faulty relay trigger transistor or leaky capacitor either in the power supply circuit of the pre-amp or mainboard. It is also possible that other connectors could be loose and/or cold solder issues. Best approach would be to open the unit up for a look & see.
Good luck and thank you for using FixYa.
Posted on Jan 28, 2009
  • 11,896 Answers
Check you fuse resistance with an ohmeter. Also check for any loose or broken wires and solder pieces. It is possble you could have positive and negative wires on backwords in your speakers? I would check speaker wiring as well
  • Nate Stansfield
    Nate Stansfield Jan 28, 2009
    sounds like one of your resistors or transforemers have burnt out.
  • Nate Stansfield
    the powersupply could be bad. when they start to go they usually send a higher voltage than they were designed to
    Sergeant:
    Novelist:
  • 326 Answers
I find it some internal connections problem.just check is there any short tracking inside .
Posted on Jan 27, 2009
  • 50 Answers
Strip it andclean it with a old toothbrush and put it back 2 gether again
  • Claire Mc Cauley Jan 27, 2009
    strip it andclean it with a old toothbrush and put it back 2 gether again
Mod 2245 marantz no sound right or left.
Do you hear the relay click when you turn the unit on? If not you have a issue with one or both amps. If you do get a relay click, check your pre-amp out/main amp in connections on the back. You may want to also play with your controls, dirty controls can cause this condition as well. If you would like to have the unit serviced, check out my website, I have a lot of experience with the vintage Marantz units.
Thanks
Willie
www.back2lifeelectronics.com
Jan 25, 2016 | Marantz Audio Players & Recorders
I have a Marantz Digital Integrated Amplifier PM75 and experiencing with LP's and CD's that I get a loud popping sound , thereafter no sound until after several minutes when it comes back on.
If the sound is common to both channels plus on different functions, it is either a part that is common to both channels or is in the power supply. It will be either in the main pre-amp or power amp, or power supply. If you can turn the bad sound down, it's before the volume control and it's unlikely to be in the power amp section. If you can't turn the bad sound down, it will be in the power amp section.
Remember stereo amps are two mono amps joined together. So the two channels have separate parts for each channel. However some use IC's that have both channels running in them, they can be suspects in this case.
Jan 11, 2016 | Marantz Audio Players & Recorders
How do you connect a proton d540 amplifier to a Marantz sr45 ?
Why? The Marantz receiver already has an amp and the Proton is an integrated amp. But if you want to use the Proton as a preamp with the Maranyz you could remove the jumpers on the back of the Proton then connect RCA cables from the Proton's Pre Out to the Marantz's Tape In but I really don't see why.
Sep 18, 2015 | Audio Players & Recorders
How to hook up a Marantz AV 8003 pre amp to a carver TFM 45 amplifier
Marantz preamp out, to Carver amp(or line in). Have you tried this and had problems?
Jan 08, 2015 | Marantz Audio Players & Recorders
How to hook up a Marantz AZ8003 pre amp to a carver TFM 35 a.m.
Please see my last few comments on the same issue. If you can't find it, please let me know. BTW, Marantz does not show the AZ8003 to be a valid model.
Dec 21, 2014 | Marantz Audio Players & Recorders
I have a marantz av550 pre amp/tuner. One of the audio outputs is not working. It had been cutting in and out for a while and now no output. It is not the cable, the amp or the speaker. Is this so
It sounds like the output transistors went bad What I would do is check all output transistors in the unit they are usually the large transsistors on heat sink that an ohm meter and check each transistor while unit is off and no power go base to collector then emmiter to base if you get o or continuity on those legs on any one they are bad .
Dec 07, 2012 | Marantz Audio Players & Recorders
How do I connect Marantz AV7005 to Marantz SR9600
Remove the little black jumpers on the 9600 that link the pre amp section to the main amplifier inputs. They are the top row of rca inputs on the back. Using single rca cables from the pre out of the 7005 into the main amplifier of the 9600 connect all the channels you have wired speakers for, L,R,C, SL,SR, etc up to 7. Connect all your sources to the 7005 with whatever cables you have it doesn't matter. Turn off the 9600 volume and use only the 7005 to control the volume. It works perfectly giving an awesome amp a new lease on life. Good luck!
Oct 17, 2011 | Marantz Audio Players & Recorders
Hi, i have a marantz pm720 amp, when i switch it on, straight away it starts to make loud cracks through the speakers like spikes,then it will cut sound all together for a few seconds then back on, when i...
Hi Paul;
There are one or more transistors failed in the output circuit
I would have tech look at the amp and see what the power supply is doing without spkrs connected
Aug 20, 2010 | Marantz PM7200 2-Channel Amplifier
Marantz sr7200
most likely the audio pre amp & volume control chip
Sep 27, 2008 | Marantz SR-7200 Receiver
Marantz PM4000 amp keeps cutting out
There is a fairly simple fix to this problem here: http://www.audiotoolers.com/ubbt/ubbthreads.php/topics/5316/Problems_with_Marantz_PM4000_A.html
Apr 22, 2007 | Marantz ZS5300 6-Channel Amplifier
63 people viewed this question
 Grubhead
Grubhead
