Question about Sport & Outdoor - Others
I cant adjust the focus or change the power on my Redfield 15-45 Spotting Scope. I think it might be something simple like a loose set screw.
  • tlchris31 Apr 24, 2010
    I now have a place to get my Spotting Scope repaired. Thank You.
  • 2,335 Answers
If you are the original owner of your Redfield Spotting Scope, I know Redfield will repair or replace your problematic scope for free.
(I know there's a lifetime, no-questions policy for their riflescopes, but for the spotters, you do need to be the 'original owner'. Details online here.)
I hope the helps.
Posted on Apr 23, 2010
How to use a spotting scope for shooting?
A Spotting Scope is an essential element for hunters and shooters. This small device is technically a special type of telescope used for hunting, magnifying and watching an image or object more clearly. The methods use a shooting spotting scope does not involve much difficulty.
Here is the method:
Comfortable position
For a perfect shooting experience, you need a comfortable position. If your comfortable position is unable to help you fix the targeted area, you are likely to miss the hit or glance.
Attachment of the spotting scope with the tripod
Having an accurate view of the targeted area is important. Due to this reason, shooters need to position the spotting scope with a tripod so that they can see the targeted area very clearly and accurately.
Adjustment of the magnification level
The lens and magnification level should be adjusted so that you can get the appropriate view of the targeted area.
View of the targeted area
After fixing the targeted area, you have to adjust the magnification level with the lens to view the targeted area. At the time of using scopes, you will find some problems that magnification will present. If you fix the magnification and focus firstly, you may not find the target. You have to first view the target, and you have to adjust magnification level as required. Here, you should bear in mind you will have to go with the slow magnification process because the fast magnification process cannot give the accurate target.
Adjustment of the focus
You have to know how to reset the focus because you will need to do it again and again. It may sometimes harm your eyes with the magnification level being set to high.
Focusing on target is important for shooting and the spotting scope is also important for this purpose. For acquiring a specific target, it is important to use magnification level with the spotting scope.
You should follow all the methods of using explained above. There is no alternative way to learning how to use a spotting scope for shooting except these methods.
Apr 05, 2018 | Optics
What are the features of Barska spotting scope?
The BARSKA Spotting Scope is flexible to use and accurate for any outdoor activity. It's a so much useful for birding and hunting both.
Here are some of the features of Barska spotting scope:-
1 Powerful Spotting Scope
2 Flexible to Use
3 Focus and Optics
4 Durable
5 Fully Multi-Coated
6 Straight Eyepiece system
If you want more details you can also check The best Spotting Scope Review 2018 and make your own decision.
Dec 08, 2017 | The Optics
How many ft lb of torque for scope rings
A typical torque setting for scope bases (on a steel reciever) is 30 in/lbs. The rings (steel) need 15-20 in/lbs.
For a aluminum receiver and/or rings, 15-20 in lbs is about max. I use 10 in/lbs with blue Locktite for aluminum receivers and rings.
Apr 20, 2010 | Redfield Ring and Base Sets for Knight...
Screw missing in ring that adjust varible power - this screw is a knob that sticks up so you can turn it. i need to find this screw
Here's the info I found on Redfield's website:
Warranty InformationWhen Leupold purchased Redfield in April, 2008, Leupold did not assume the Redfield warranty. Because many Redfield customers have contacted Leupold with regard to the former Redfield warranty, Leupold is making this information available to Redfield optics owners.
At this time, three Redfield repair facilities are available should your Redfield product require service: Parson's Scope Service(513-867-0820), ABO USA Inc (305-859-2010) and Iron Sight Inc. (918-445-2001). The contacts provided are for information purposes only, as these companies are not affiliated with Leupold & Stevens. Please contact them for all information regarding repair, service, and associated charges.
As a courtesy we are now offering 20% off the price of a new Leupold scope, up to $100, in trade for any defective Redfield scope. If you would like to take us up on that offer you may call us at 1-800-LEUPOLD.
Jan 02, 2010 | Redfield Optics
I need to adjust the focus of my Redfield widefield scope, by focusing the ret field scope does it change the accuracy of the optics?
no it dont,,, it makes it even more accurate,, how can you see clearly if its out of focuse,,,,,
Nov 17, 2009 | Optics
I have a redfield 3x9 rifle scope and looking for tips on sightin
Yes thats about all there is to it, adjust in small steps and tap on the barrel of the scope with a screw driver handle (light taps) after each adjustment before firing the gun.
Nov 14, 2009 | Redfield See Thru Rifle Scope Mount Base...
Adjusting Range on Redfield Scope
There should be a set screw or screw that you can loosen to make that adjustment. Once you have it where you like it, just tighten it back up and enjoy you ability to make those quick adjustments when needed.
Mar 29, 2009 | Optics
Need to find a Redfield rifle scope repair shop-scope fogs up
iron sight inc.918-445-2001 4814 south elwood avenew tulsa oklahoma. 74107
Dec 11, 2008 | Redfield Ring and Base Sets for Knight...
Redfield Rifle Scope Manual
I own a Redfield spotting scope the model year is between the 70's to 80's and I need to find a manual for it. But I was Wondering if you could answer a question there is a crossair, then there is another one right above that, then there is a loop on the bottom right hand corner. There is also a yard marker that starts at 600 and goes down to 100. Do you know what it is and how to use it or what the purpose of it is if you could help me that would be great. Thank you for all your help..Joshua Gambler
Sep 18, 2008 | Redfield Ring and Base Sets for Knight...
Bausch & Lomb 60mm Spotting scope focus screw
Try here: Eagle Optics
2120 W. Greenview Dr.
Middleton, WI 53562
Jan 25, 2008 | Fujinon Super 60S
Sport & Outdoor - Others Logo
26 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
