Question about Saeco Royal Exclusive 30153 Espresso Machine
Saeco Royal leaking from inside, and hisses
Saeco Royal Exclusive leaking from inside, and and hissing sound of steam after making a coffee. Does any one know if its a boiler leak? Secondly, how on earth do you dismantle everything? Is there a guide on how to remove the cover properly?
mirran
  • 515 Answers
SOURCE: Saeco Royal Exclusive 30153... FILL WATERTANK
Hi Marty,
Make sure the magnet in the water tank flow up when you fill the water tank with water.
Posted on Aug 07, 2008
mirran
  • 515 Answers
SOURCE: Looking for user's manual for Saeco Stratos Expresso Machine
I have a user instructions to this machine.
I will try to upload it to Royal exclusive 3053 page.
/Mirran
Posted on Aug 12, 2008
mirran
  • 515 Answers
SOURCE: Water leaks
I think you have to replace your bolier in the machine.
If it is the boiler and you replace it, make sure to descale your machine regulary.
Best regards
/Mirran
Posted on Sep 04, 2008
  • 1089 Answers
SOURCE: how to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Posted on Jun 14, 2010
  • 1089 Answers
SOURCE: the display on my Saeco
Hi
That means the pump needs to be primed by running water through the wand. Push the water button( the one with the drop or drops). You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed.
Posted on Aug 21, 2010
Espresso machine HISSING!
It sounds like you have the cup warmer turned on. But if that's not it there is a leak in a connection coming from the bolier. If you open it up it will be obvious where it's at. Don't wait too long because the moisture will effect the electronics.
Jun 30, 2013 | Coffee Makers & Espresso Machines
Mi saeco royal exclusive is leaking . how to fix it?
HI Well it depends on whats is leaking. If its just a hose, its not that hard. if its the boiler, that is a little harder.
Jul 25, 2010 | Saeco Royal Professional Espresso Machine
How to decalcify saeco royal exclusive coffee machine
Hi
Jun 13, 2010 | Saeco Royal Digital Plus Coffee...
Leak when making coffee
Hi
it could be an easy fix. it could be a seal (o-rings) that are old and just need to be replaced. Could be a hose that has cracked (unlikely). That machine has 2 boilers.
Mar 14, 2010 | Saeco Royal Professional Espresso Machine
/Mirran
Aug 12, 2008 | Saeco Royal Exclusive 30153 Espresso...
Saeco Royal Digital has steam coming out the vents and fogging the display when using the steam. How to fix this problem?
I think you have a pipe leakage.
Take of the top and see how it look inside, if you have a leak then it will go down to the power button and you will have a short circuit.
Jul 20, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Incanto not grinding
Hi Chris,
The leaking is your steam valve that has to be replaced, you can see this if you open the door and look up in the right corner there you will see water drip.
If not then you have a pipe or boiler leak.
How old is your machine?
How often do you descale the machine?
When you try to make a cup of coffee, starts the grinder for two seconds or is it dead?
Hope this will help you.
Jul 19, 2008 | Coffee Makers & Espresso Machines
After a move, the pump at rear makes constant noise (like pump is leaking) and ventilate is showing on screen
Contact Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Jan 26, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Exclusive 30153 Espresso Machine Logo
70 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
