Question about Cadet Manufacturing C152 Com-Pak Plus Heater
I need a diagram for a parallel (?) 220 circuit using 10/3 wiring for 3 wall heaters and 3 different t-stats for 3 rooms
  • 1,070 Answers
Are you sure 10-3 wire is big enought to handle 3 heaters on one circuit? I would call that into question before going forward.
Posted on Apr 23, 2010
How to install two electric baseboard heats together?
Connecting the heaters in parallel means that essentially the two wires coming from the power source (the thermostat) go to the two ends of the first heater, and the same two wires then continue on and are connected to the two ends of the second heater as well. This means that each heater will receive the full 220 volts, and each one will draw the amperage it was designed to in order to reach its maximum temperature. As long as the sum of the two amperages is less than the size of the circuit breaker (20 amps in the case of baseboard heaters), then they both get what they need. If you put too many in parallel on the same circuit, you simply blow the circuit breaker and nothing warms up.
Jan 04, 2012 | Heating & Cooling
I have white, black and ground out of wall, i have red, black, white and ground from oven, how do i connect
Unfortunately you can't. Your wall outlet is a 110V circuit (B-110V; W- common) and your oven needs 220V circuit to operate. Red - 110V; Black - 110V; White - Common.
You will need to installed a 220V, 30 AMP (10-3/w ground) homerun from your circuit breaker panel to the oven
Jun 21, 2011 | Whirlpool RBS305PR Electric Single Oven
How do I wire a central heating room thermostat
You didn't mention if you had electric heat or gas heat. If you have electric heat you must move a wire on the thermostat to make the fan come on. Most all wall stats come ready for gas heat. No need to make a wire change for gas. Anyway I have a diagram of a typical central unit HERE
Nov 19, 2010 | Heating & Cooling
Connect my 24 milivolt gas (between the studs) wall furnace ( in my hall) to my thermostat that operates my electric heat central unit. problem: to sync both units to give home more balance ( hall is...
the first problem is you need a milli-volt t-stat and your central has a 24volt t-stat if you connect the 2 it will fry the controlls in the wall heater the second problem is t-stat location if the wall heater is near the central heats t-stat it will shut off the central to soon . maybe relocate wall unit to coldest room ?
Nov 16, 2010 | Honeywell Heating & Cooling
I just need a wiring diagram---with a thermostat-- for a cadet FX-152 , 240 volt ,1500 watt wall heater
grainger has them- home depot. wire is easy wire one side straight to 1 wire on in coming power the other side use your thermostat to break curcit ie wire into stat out of stat to voltage
Jan 15, 2010 | Cadet Manufacturing CADET SL Series Small...
I am trying to install a fahrenheat f2543 heater with a fta2a double pole thermostat. there is a 12/2 wire coming into where the heater is being installed. how do i connect the red and black to the white...
Hi, this is very easy for you to do.The 12/2 Romex wire coming in is the power which you know. What you do need to know, is the voltage coming in? Sometimes they will use 12/2 Romex with ground for 220, 240, operation. You need to know if the T-stat is Line voltage 220, or 240 volt. You have to have the same voltage for both for it to control. Reguardless of the voltage, lets say it is in the 220 and up range. You take one of the 12/2 wires, white or black and hook it to the black or red on the T-stat and the white to the other one, red or black. Thats it, you are done! If the T-stat is 2-pole I am sure it is a high, Line votage T-stat. Best of Luck,
Shastalaker7
Nov 09, 2009 | Fahrenheat Built-In Baseboard Thermostat...
I am trying to replace a electric baseboard heater that is 220 volts and I am unsure about the wiring. the heater has a red and black wire and there is a white and black wire coming out of the wall.How do...
if ur are replacing the heater and it was originally 220/240 ur wiring should b ok but to b sure trace the line wire back to breaker panel and look at breaker the white and the black should b hooked up to separate breakers if the white is hooked up to a ground bar usually on the inside side of the panel and the black hooked up to breaker ur line is 110/120 and will cause problems when hooked up. if the lines r 220/240 than red can hook up to white and black to black
Sep 25, 2009 | QMark FBE15002 electric baseboard heater...
I have 2-240V (4.2V) basebaord heaters, Need Wiring Diagram
you get 120V from any phase (black OR red) to neutral
you get 240V from phase to phase (between black and red) and in this scenario you don't need the white wire.
So for you, connect the black to 1 pole of the breaker and the red to the other pole, connect the green wire to the ground strip and you are done.
A white wire is NEVER connected to a circuit breaker anyway, it is a grounded wire, it would be like connecting a green wire to a black wire, bad idea.
the National electrical code specifies red and black wire color for 240VAC circuits.
As Ask Hank mentionned, nothing wrong with 10/3 wire.
Mar 22, 2009 | Fahrenheat Electric Hydronic Baseboard...
Thermostat not firing central heating
the stat works using a bi metalic strip so that click you here is making a contact and telling the boiler to call for heating so if you getting no click you need a new room stat. Replace with same model and note the wiring most stats only use 2/3 wires depending on system
Dec 08, 2008 | Dayton Electric Heater
Wiring a Drayton Room Stat into central heating system
9 TIMES OUT OF 10 THE COLORS ARE THE SAME. MATCH THEM UP. FIRST LABEL THE WIRES ON THE ORIGINAL STAT, AND PUT THEM IN THE CORRESPONDING PLACE ON NEW ONE.
Oct 26, 2008 | Water Heaters
Cadet Manufacturing C152 Com-Pak  Plus Heater Logo
251 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
