Question about Intel Computers & Internet
When I swith on the computer,sometimes it can't open,thesystem can run but no visuals.the moniter shows orange light.it is very slow also.
  • 781 Answers
The video (visuals) issue could be a video driver issue.
assuming that you do get something on the screen when you turn the computer on, try to to start your computer in safemode by pressing f8 severval times after you get the first screen, you should see advance startup options. select safe mode and attempt to install an updated video driver (which one depends on your video card manufacturer and model number).
if you don't get any video at all you video card may need to be replaced.
slowness
this is cause by memory wear out or (most likely) malware, now.. you need video and you need to be able to boot into your computer to run some tools that would clean up your system. slowness could also be caused by an old hard drive, if this is the case is better to first get all your data out into a removable hard drive, and replace the hard drive and resintall the operating system.
post back if you were able to get boot up if you have further questions.
Posted on Apr 23, 2010
I have vista sp 2 64 bit running on my vaoi laptop. My laptop is extremely slow despite having a 4 gb ram. Even if i swith off the updates it shows me updates being installed on start up and shuting down....
Steps to speed up your computer
Operating system : Vista
1. Run Disk cleanup ( location : start> all programs> Accessories> System tools> Disk CLeanup )
2. Run Disk Defragmenter ( location : start> all programs> Accessories> System tools>
Disk Defragmentation )
3. Reset Internet Settings ( Start> Run , type : inetcpl.cpl and click OK)
- You will see internet properties.
- In the General tab> Brower history> Check delete history and click on Delete
> You see another window, check all the boxes, except : password and Form data.
- In the Advance tab> Click on reset ( make sure you have closed all the IE pages)
4. Delete Temp, %temp% and prefetch file ( junk files )
5. Visual effects settings : Right click my computer> properties > Advanced system settings
> under performance option click settings> uncheck all the boxes except the last two and then
click APPLY and OK.
6. If it's still working slow, need to change same settings in Registry and Msconfig
7. Reply back for more trouble shooting
Dec 13, 2010 | Computers & Internet
Audio window comes on and off on its own
problem with moniter front panel MENU swithes.Replace all the swithes on the front panel.
If one swith is problem, automatically on or off will happen on its own.
This solution wil be the same even if brightness or contrast control will vary on its own!
Dec 10, 2010 | HP W19b LCD Monitor
My computer turns on but wont show up on my moniter all i did was swith the hard drives n now i tryed to put the origanl back in and its not showing up on my moniter all i need is a diagram of the inside...
there is only one small problem
this is the fact that your module is probably not in place properly or is covered with dust and as such cannot be properly utilized by the system. all you need to do is pull out the module and clean it(especially the golden panels) then make sure it is properly in place. this should solve your problem.
hope this helped you?
Nov 14, 2010 | Acer Aspire T135 PC Desktop
Wnen i start my computer my moniter is going to sleep and when i disconnect from cpu it get start and show the cable is disconneted what is the prblem can you give a answer for this particular problem
check whether the pc is running. when it swithes on hear for boot sound. problem can be because of: computer ram failed mother board failed. power supplied failed moniter cable losse connection
Sep 16, 2010 | Computers & Internet
My moniter display is not coming it alway show
You need to try this monitor on other PC to narrow down the problem, it can be the monitor, cable, PC. I f you try all the suggestions and it still does not work, then you need to open it up and see the pictures here: http://s807.photobucket.com/home/budm/allalbums
and check for shorted transistors or bad fuse.
Mar 11, 2010 | Dell E173FP 17" LCD Monitor
On button is orange and moniter wont come on
If the PC is on and running and the light is oragne it means your video card is bad or the cable is loose.
Power off your PC (gonna have to hold the button down on PC until it turns off) and then turn off the monitor.
Reseat cables on both ends from Monitor and PC then power back on again and see if that helps.
If it still doesn't work you have a bad video card.
Hope this helps
TankMurdock
Apr 24, 2009 | X2Gen MG19VT 19" LCD Monitor
Computer would not boot up, only showed red light
I'd say power supply first.
If you have an expansion slot filled with a video card, remove the video card (provided you have onboard video connector as well) then try to reboot. I just went through similar issues with an GForce video card, it went bad, but the machine appeared to boot althugh I couldn't see the screen. Removed the card & it came up using minimal VGA drivers provide with WinXP.
Obviously you cannot check the video driver if you're not booting up...and seeing the screen.
Find a buddy with a regular monitor and hook it up and try to boot. Dell monitors sometimes require their propietary drivers, so write down the model when you take your pc to a friend's place, and DL the driver and install it (provided you got it to boot up)
Brad
Feb 14, 2009 | ZT Group Cisnet PC Desktop
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Computers & Internet Logo
57 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
