Question about Refrigerators
Door does not close the seal is not closing - Refrigerators
  • 712 Answers
First of all check whether something is jamming its way through, may be some utensils. If not, just look that a simple push to the door can fix the problem. If it not that check if the door has misaligned.
Posted on Apr 23, 2010
Why won't door on Samsung side-by-side refrigerator stay closed? Pops open after closing, like the seal isn't working.
The door isn't lining up right when it's closed. I suspect you have been putting heavy stuff on the door racks, like several 2 liter soda bottles or gallon jugs of milk. Over time the door will sag from the weight until it won't stay closed.
Nov 06, 2014 | Samsung RSG307AABP 30 cu. ft. Side by Side...
Replaced door seal now door is difficult to close.
Sometimes, it is hard to close door after fitting a new seal.
Make sure you have got it fitted correctly round the flange on the front of the cabinet, and that the retaining clamp is securely fastened.
Try smearing the door glass with washing up liquid, this can help to close the door more easily
Please rate my solution.
Thankyou.
Feb 13, 2010 | Ariston Technologies Washing Machines
Door won't close stay closed or seal
check gromets on hinges for wear. check weight on doors is it causing the door to droop? are the gaskets cracked? more information is needed if possible.
Feb 01, 2010 | Kenmore Freezers
Changed freezer seal,bottom half of door won't close tight
tough job there , you must get a hair dryer and carefully heat gasket until it seals properly. some gaskets take hours to get to seal right.
Phil
Jun 10, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Fridge door pops back open
The seal on your door may not be sealing properly, when you close the door the seal helps create a vacuum which keeps your door closed firmly, you might need to replace the door seal, you could also try leveling your fridge by putting shimmys underneath the feet, you might also want to check to make sure there is nothing sticking out of your fridge such as drawers or food racks that may keep the door from closing all the way. good luck.
Mar 16, 2009 | Refrigerators
Freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
How do you clean the interior, I have a gross mildew looking build up on the rubber seal?
you cant really clean the door seal it will need replacing why you get the mildew on the door seal is that when you finish washing you close the door but this is a mistake never close the door as this lets the rubber seal dry and the moisture that evaporates goes into the atmosphere if you close the door the moisture never drys which causes the mildew
Jun 11, 2008 | LG Washing Machines
Door not closing properly.
take door off and pack bottom hinge with washers. make sure hingebrackets on cabinet are tight. however, door hanging a bit should not really affect sealing. if seal is gapping, one solution is to warm with a hairdryer and pull outwards gently
Mar 31, 2007 | Hotpoint RLA80 Refrigerator
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
