Question about Vulcan Ovens
Wiring diagram for oven motor 419720 - Vulcan Ovens
  • 8 more comments
  • japit1 Apr 23, 2010
    The motor is for a vulcan convection oven SG-10-SME. The motor is a blower motor GE 419720. A repair man came out and installed the new motor, but cannot get the wiring right. On the line from the oven there are the following wires:
    2 Blue wires with the numbers tags 53, and 54 on them
    2 Red wires one with the number tag 98, and another with no number
    On the line from the Motor:
    1 orange
    2 red
    2 white
    1 black
    1 brown
    1 orange
    2 red
    2 white
    1 black
    1 brown
    See less
    The product is a Vulcan Convection oven Model # SG-10-SME, The motor is a GE Model # 419720-1 1/3hp 1725RPM, h56yFrame
    I need help connecting the wires from a blower motor to my Vulcan convection oven. The motor is for a vulcan convection oven SG-10-SME. The motor is a blower motor GE 419720-1. A repair man came out and installed the new motor, but cannot get the wiring right. On the line from the oven there are the following wires:\r\n
    1 orange
    2 red
    2 white
    1 black
    1 brown
    See less
    Apr 23, 2010 - The product is a Vulcan Convection oven Model # SG-10-SME, The motor is a GE Model # 419720-1 1/3hp 1725RPM, h56yFrame
    See less
    1 orange
    2 red
    2 white
    1 black
    1 brown
    See less
    See less
    1 orange
    2 red
    2 white
    1 black
    1 brown
    See less
    See less
    1 orange
    2 red
    2 white
    1 black
    1 brown
    See less
    See less
    1 orange
    2 red
    2 white
    1 black
    1 brown
    See less
    See less
    This site did not describe how to connect the wires to my convection oven. I already have the part, I need to connect it
    1 orange
    2 red
    2 white
    1 black
    1 brown
    See less
    See less
  • 10,865 Answers
Hello. Go to this site, and you will find exactly what you need
http://www.partselect.com/repair.aspx?appliance=help&part=5
Posted on Apr 23, 2010
  • 1,555 Answers
Many modern gas stoves, ovens, furnaces, and other similar appliances use an electronic ignition rather than a continuously burning pilot flame to ignite the fuel. These are actually simple high voltage pulse generators.
  • Where starting is manual (there is a 'start' position on the control(s), a set of switch contacts on the control(s) provides power to the ignition module.
    • A problem of no spark with only one control indicates that the fault is with it or its wiring.
    • A problem with continuous sparking even with all the controls off or in their normal positions indicates a short - either due to a defective switch in one of the controls or contamination bypassing the switch contacts.
  • Where starting is automatic, an electronic sensor, thermocouple, or bimetal switch provides power to the ignition module as needed.
The Harper-Wyman Model 6520 Kool Lite(tm) module is typical of those found in Jenne-Aire and similar cook-tops. Input is 115 VAC, 4 mA, 50/60 Hz AC. C1 and D1 form a half wave doubler resulting in 60 Hz pulses with a peak of about 300 V and at point A and charges C2 to about 300 V through D2. R2, C3, and DL1 form a relaxation oscillator triggering SCR1 to dump the charge built up on C2 into T1 with a repetition rate of about 2 Hz. C1 A D1 T1 o H o----||----------------+-------|>|-------+-------+ +-----o HVP+ .1 uF D2 1N4007 | 1N4007 | | o ::( 250 V +----|>|----+ | +--+ ::( | | | )::( +---/\/\----+ | #20 )::( 1:35 | R1 1M | C2 _|_ )::( | R2 / 1 uF --- +--+ ::( | 18M \ DL1 400 V | __|__ ::( | / NE-2 | _\_/_ +-----o HVP- | | +--+ | / | | +----|oo|----+---------' | SCR1 | C3 | +--+ | | | S316A | .047 uF _|_ R3 / | | 400 V | 250 V --- 180 \ | | 1 A | | / | | R4 2.7K | | | | | N o---/\/\---+-----------+------------+----+-------+
  • 4,924 Answers
Please specify the name and manufacturer of the product ..
  • 2,926 Answers
Do you have a model number for the oven and what make and model?
What does this "motor" do? Ventilation?
I need the wiring diagram for ge oven wb27t10069
Most have it on the appliance in a hidden location.
How to Obtain a Wiring Diagram or Schematic - Products - GE ...
products.geappliances.com/appliance/gea-support-search-content?contentId=19249
A wiring diagram (mini-manual) is included with each appliance. If you are in need of a replacement wiring diagram, you can determine where to find it on your appliance by visiting: Wiring Diagram Locations. If you cannot locate your wiring diagram, you can call the GE Appliances Answer Center with your complete model ... Missing: wb27t10069
Wiring Diagram - Location - GE Appliances
www.geappliances.ca/en/support/knowledgebase/wiring-diagram-location/ Mini-Manuals are located on all GE appliances. The most common ... Note: The icemaker wiring schematic is located on the inside front cover of the icemaker. Freezers: Near the ... LP Conversion Instructions: Packed with the mini-manual or screwed onto the back of the range right above the gas regulator. Wall Ovens: ...Missing: wb27t10069
Apr 30, 2018 | GE Ovens
Wiring diagram for a Kelvinator DeVille eye level oven Model B305, Serial no 3674
Request the wiring diagram directly from Kelvinator.
Jun 25, 2014 | Ovens
Fan motor is slowing down and not keeping the desired temperature
The circuit diagram for the standard control model shows the blower has a two-speed motor, connected directly to the power line in "Cool" mode, or connected to the temperature control in "Cook" mode. When the blower slows down during cooking, switch it temporarily to "Cool" mode. If it goes to normal speed, the problem is with the mode switch contacts or the wiring terminals between the fan mode switch and the temperature control board, or the control board itself.
If the speed does not change, check the wiring terminals at the speed switch common terminal (I assume your problem occurs in both low and high speeds). If you find tarnished, loose, or burned terminals, clean, repair or replace as needed. (In extreme cases, a loose terminal will cause the wire to overheat, damaging the insulation, oxidizing the terminal and causing a high-resistance condition that will reduce the voltage available to the motor.) If the connections are all good, the motor bearings are probably getting sticky at high temperatures. Let the oven get hot enough for the blower to slow down, then shut it off and check the blower bearings while wearing oven mitts.
May 12, 2014 | Southbend SLGS-22SC Gas Double Oven
Wiring oven diagram
should go to imperialrange.com you can find the wires diagram in it.
good luck
Jan 23, 2014 | Imperial Ovens
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
Oven wiring diagram or help?
I suggest you post this under Inglis to have a better chance of having an answer
Dec 31, 2009 | Stoves 720EF Electric Double Oven
I need a wiring diagram for the replacement ERCU on the JKP27WW1WW oven. Our oven is from 1994 and the new 'clock' module (ERC3) is slightly different where it connects to the 'bake' and 'broil' contacts....
I am not sure if this will help you but I did find a fellow that says he has the adaptable diagram for an updated part on this forum :
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/15496-wiring-diagram-oven-control.html
Oct 30, 2009 | GE JKP27 Electric Double Oven
Wiring diagram for jtp18
Call GE at 1-800-626-2005 to get a wiring diagram
Regards,
Powerman
Oct 26, 2008 | GE Profile JTP18 Electric Single Oven
Ovens Logo
583 people viewed this question
Top Vulcan Ovens Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
