Question about Whirlpool GU2400XTP Built-in Dishwasher
No power going to front panel on whirlpool dishwasher gu2455xtsso
  • 5,911 Answers
If the model number you listed this question under is correct, there is a thermal fuse (also known as a bi-metal) located inside the control panel of the dishwasher. The part number for the thermal fuse replacement is W10258275.
If you type in your model number you can utilize the exploded view parts diagrams at pcappliancerepair.com, appliancepartspros.com or searspartdirect.com to assist you in locating the part. The fuse is listed as item 6 under the "Control Panel Parts" section.
To replace the fuse, follow these steps:
1. Make sure the dishwasher is unplugged or the breaker is turned off.
2. Open the door and remove only the top screws directly behind the control panel.
3. Remove the protective cover from back of the control panel to expose the main control board.
The thermal fuse should be mounted to the control board. If you remove it and take a resistance check, it should read close to 0 ohms, if good. If bad, replace as necessary.
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Posted on Apr 23, 2010
Whirlpool dishwasher wont turn on
first thing to do is to check if u have power to washer. check to make sure the breaker in your main electric panel is not tripped. If it is ok then take front cover off kick panel make sure that the wires running to the washer are not loose. be sure to turn off the breaker first. IF they are tight then turn on braker and check wires at washer connection with volt meter to see if u have power.
Apr 11, 2014 | Whirlpool GU2300XTS 24 in Builtin...
No front panel lights Whirlpool GU2500XTPB1. Power to dishwash is good.
what most likely is going to be the problem is a blown thermal fuse that attaches to the control panel housing. gain access to the control panel and use should see the thermal fuse,the housing for the control board is grey and this part is white.Remove the wires to it and check for contininity on it (ZERO OHMS) using a ohm meter set to a low ohms setting. If it turns out to be good the next thing to check is the switch(s) on the latch asm using the same method to check them as the fuse.BEFORE CHECKING EITHER OF THOSE BE SURE TO DISCONNECT POWER TO THE DISHWASHER
Aug 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My whirlpool quiet partner II dishwasher stopped working no power...i just used it and went to do another load and no power. I checked the outlet and there is power. what part could be the cause of...
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 02, 2011 | Whirlpool Dishwashers
Whirlpool DU1055XTSS dishwasher is totally dead as if it were unplugged. No response from front lights. Only 3 years old. Another post for an different Whirlpool model says it's the thermal fuse, but I...
If you have power going to the dishwasher, meaning the breaker, switches, wiring and fuses in the home are okay, the most common cause for your symptoms is the thermal fuse.
The thermal fuse is a small disk shaped device that is behind the control panel on the right side it is snapped on to the electronic module. The part number for your model is W10258275
Jul 24, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Want to replace door panel at front how do you take old panel off.
It depends on your dishwasher. Some don't have "panels " on the front. There are dishwashers that have a frame around the front face of the door. If you have one of those, you unscrew the 2 screws on the side of the door and one side of the frame will come off allowing you to take the panel out and replace it. If your front door is one solid piece that wraps around the sides, you will have a much more difficult, and expensive, trying to find the exact replacement. To help save you time and money, go to www.applianceart.com, they have many options that go over your existing panel, or panel replacements depending on the dishwasher you have. They even have stainless options as well
Jun 03, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
No power or lights in the front panel
Check the fuse / circuit breaker inside washing machine. There may be a extra control circuit fuse normally on the control PCB.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Change front panel on a Whirlpool DU800CWD dishwasher
Turn off the electricity. Lower the door and remove various screws around the perimeter of the door. Reverse the procedure to install the new panel.
Feb 24, 2010 | Whirlpool 24 in. DU800CWD Built-in...
Front panel color
I have the use&care guide for this unit. It explains how to change the panels - I also notice in ebay that you can order generic stainless ones. I'm going to remove my white panel to install the stainless.
Jul 28, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool GU2400XTP Built-in Dishwasher Logo
312 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
