Question about Maytag Atlantis MDE7400AY Electric Dryer
Dryer started but then quit and it will not come back on. The timer is ticking, we have checked the door switch and the thermal fuse is good. The plug also looks to be in new condition. Is there anything else that would make the dryer not work. It does absolutely nothing. No turning or heating. Thanks!
  • Maytag Master
  • 43,501 Answers
A dryerDryer started but then quit and it will not come - 2_bing.gif may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 23, 2010
When the timer on an electric dryer fails to start the dryer. Should you still be able to hear it ticking, when the timer is turned on?
Of course. Correct diagnosis is the key to such things. All the items you swapped out were fine. There are checks you can make with all those components. The rotary type timer is just a clock timer like a wind-up alarm clock. When you turn them on, they tick. In normal circumstances, turning it on will start the machine, and not count down. You need to remove it and make sure you have continuity and also power to the timer. There is more to this than meets the eye. The other item that it may be, is the motor itself.
Nov 25, 2017 | Dryers
Have power everywhere but won't turn on
see this causes and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Oct 02, 2012 | Dryers
I have a RES7745RQ electric dryer. The timer
HI, check the following to address this issue.
The dryer will not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse, but if all is ok with the above stated areas, replace the start switch.
Aug 19, 2009 | Dryers
Kitchenaide dryer won't turn on. . .
3. Thermal fuse
4. Timer
Aug 06, 2009 | KitchenAid Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
My dryer will not start when button is pushed. There is a ticking sound in the back when I push the button to start it
Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicksand clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuseis an oblong white plastic piece with 2 wires attached.
May 08, 2009 | Kenmore 62602 Electric Dryer
Whirlpool dryer
Ticking is from timer.
Check the door switch and the thermal fuse located on the exhaust vent.
Feb 21, 2009 | Dryers
Maytag performa dryer quit working
Check your breaker first and then the wiring. Check power coming from the timer next. With a load and resistance that you had, you could have tripped one of the breakers.Since you have bypassed the thermal fuse, it probably is the timer switch.
Jan 26, 2009 | Maytag PYE2300AY Electric Dryer
Maytag electric dryer won't start
Hi!!! You have a bad thermal fuse.easy to replace just lift up open the top cover of the dryer and the thermal fuze is in the back next to the heating element.Its round and black with 2 wire going into it its around half and inch thick next to the heating element ..Good luck..
Jan 03, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
63 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
