Question about Garden
DeVilbiss Pressure WAsher EXH2425 Honda engine GC160qha pump DAPC axcial cam. When using washer sprayer both the engine and pump seem to operate normally. As soon as I let off the trigger of sprayer the engine dies. Help?
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly
Take a look at your engine parts manual here:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/GC160AQHA/gc160%20qha_1.pdf
Watch item 22 and 4 (pdf file page 5) as the engine unloads to see if it is rocking. If it is stuck in one position it will do exactly what you describe.
Also check the 2 springs items 4 and 5 (pdf file page 7.) If one of them is broken it can cause the problem.
What I really think is happening is that the throttle linkage is moving too far and striking the kill switch on the control lever (pdf file page 7) item 14. Watch to see if the linkage is moving and striking the engine stop switch.
Your engine also has an engine fuel pump. Item 1 of pdf file page 19. This pump is operated by the difference in crankcase and carb throat pressure. If any of the hoses are leaking it can cause the fuel pump not to work at low engine speeds and result in engine fuel starvation.
This particular engine is really fussy when the lines get old, crack, or harden. Take a long look at the condition of all of the vacuum, fuel and breather lines.
I can't say that it is the ___ line / hose is causing the problem because there are too many and any one of them can give you fits.
Download the manual... look at the linkages and hoses. I am sure your going to find the cause if you give it a good look over.
Thanks for using FixYa,
Kelly
Posted on Apr 23, 2010
  • 1 more comment
  • BubbaDoo2 Apr 18, 2011
    It's probably the unloader valve on the pump sticking and causing the engine to stall because of too much pressure. This happened to mine - doing the same thing. Good luck finding a new one!
  • trogan77 May 17, 2011
    Yeah.. seriously.. good luck finding that unloader valve. I was actually able to rebuild mine by disassembling it, cleaning everything up and replacing the o-rings. ...I found most of the o-rings at Home Depot, surprisingly. Worked well after that.
    I actually need another identical unloader valve for an EXH2425, so if anyone has - even a crusty one - let me know.. I'll give you ten bucks for it.
  • BubbaDoo2 May 18, 2011
    I was able to rebuild mine too. Didn't even need new o-rings, just cleaned up the spring and piston and everything. It was very corroded. Works like brand new now.
Do you use 4 cycle oil or 2 cycle oil for pressure washer EXH2425?
For your model pressure washer you should not be using 2 or 4 cycle oil. You need to use the following:
Model # EXH2425 P 2400PSI 2.5GPM 5.0HP HO
PUMP TYPE OIL TYPE OIL CAPACITY
**Annovi Reverberi (XMV) 30W non detergent 13.5 oz.
**Annovi Reverberi (RKV) 30W non detergent 18.54 oz.
Aug 15, 2011 | Garden
We think oil for the engine of our Devap 2600 PSI 50 Gas-Powered Pressure Washer #DVH2600, Honda 5.0 EXH2425 was put in the wrong spot... in the unlabeled orange-cap opening, not the small grey...
To evacuated the oil from what I believe is the gas cap area, you are going to need some type of a siphon pump to remove the oil. A total engine tear down might be needed depending on where all the oil is. Remove the spark plug, and turn the engine over, if you are getting oil coming out the spark plug hole, then you are going to have to either tear down the engine, or leave the engine sitting in a way that you can drain all of the oil out of the system.If no oil comes out of the spark plug hole, then you should be good to go once you siphon out all the oil
Jul 06, 2011 | Devilbliss DeVILBISS Devap DVH2600...
Does my Honda 5.0 EXH2425 take mixed gas?
No it is a 4 cycle engine and does not use mixed gasoline.
Jun 01, 2011 | Devilbliss DeVILBISS Devap DVH2600...
Need part that regulates the engine speed on Devilbiss pressure washer
If you are talking about the idle down assembly on the devilbuss pressure washer they are no long available
Sep 30, 2010 | DeVilbiss Pressure Washer Hose 25' 38" Id...
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
I have a DeVilbiss pressure washer, Serial# 2251136878, Model# WVRH2421, Radial Pump# D28703, with a 5.5hp honda motor. It has no pressure. If the pump can't be fixed, is there another brand of pump that...
THE PUMP FITS THE MOTOR and the pump i always use is a ROYALPUMP made in Italy and they are long lasting and easily serviced ,any of the Italian pumps are good
Sep 10, 2009 | Garden
What kind of oil do i use in pump for devilbiss exwgc3240-1 pressure whasher
Dear jim_5,
Most domestic pressure washers use normal multi-grade engine oil. 15/50 wil be good. Industrial and high pressure washers usualy use gear oil (90 sae).
Regards,
fulltech.
Apr 11, 2009 | Honda Garden
Garden Logo
1,641 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
