Question about Lexmark X5070 ALL-IN-ONE InkJet Printer
Scanner will not scan into my computer, it will scaqn before faxes
  • 1,555 Answers
Kindly be a bit descriptive and let me know the version of driver installed and the media through which connecting to computer. The software through which you are trying to scan. Does your printer copies if direct command from the printer itself is given to it.
Here's a link for your latest driver if the problem is only through computer and rest all are working fine through printer. Just reload the printers driver on your computer and restart your pc.
http://drivers.softpedia.com/get/PRINTER/LEXMARK/Lexmark-X5070-Printer-Driver-1023.shtml
Posted on Apr 23, 2010
How do I scan document to my pc
To scan using Windows Fax and Scan
  1. Place a document on the scanner, or, if the scanner has a document feeder, place one or more pages in the feeder. ...
  2. Click the Start button , click All Programs, and then click Windows Fax and Scan.
  3. To use Scan view, at the bottom of the left pane, click Scan
More Help:
How to Scan from Printer to Computer
How to Scan Document in Windows 7
Use your computer to print scan and fax
Mar 02, 2015 | Samsung SCX 4623F - multifunction fax /...
Tip
Can I send and receive faxes from my computer ?
Yes. You can. You will need a telephone line, a modem and a scanner, along with your computer. And before you can send and receive faxes from your computer, you will need to install the fax component. This fax component is not installed in Windows XP by default.
How to install the Fax Component:
Go to Start Button -> Control Panel -> Add/Remove programs ->Click on Add/Remove Windows Components ->Click in the Fax Services check box and click Next. Now you will see a Windows Component Wizard, which will setup the Fax service in your computer. Make sure the modem and telephone line are connected to your computer, along with the Scanner.
Now you have to configure the Fax component in your computer. In order to do that, you have to go to the Fax Console which is located at
Start Button ->All Programs->Accessories->Communications->Fax ->Fax Console
fax_xp.gif In the Fax console, click on the Tools Menu and select Configure Fax - this will start the Fax configuration wizard. Click Next to start configuring the fax service in your computer.
Enter your Name, Your Company's name and your fax (Telephone) number on the Sender Information page.
Your modem will be selected under Select Device for Sending or Receiving Faxes - if you have more than one modem, you will have to select the correct device to send and receive faxes in your computer. You will also have to specify if the send and receive options - whether you will manually answer incoming faxes or if you want your computer to automatically answer them for you.
Remember to Enter your Company's Name and Fax Number under Transmitting Subscriber Identification(TSID) and Caller Subscriber Identification (CSID). These fields are very important.
Now, under Routing Options, you will need to specify where incoming faxes are going to be stored in your computer. You can specify a local folder or just let it go to the default location, which is the Fax Console.
You can change these settings anytime you want by running the Fax Configuration Wizard again from Tools -> Configure Fax.
Sending Faxes from Your Computer
You can fax any document that is stored in your computer. You can also scan a document and fax it by sending it to the Fax Printer in your computer.
To fax a document from your computer, Click on the File Menu of the document and select Print. Then under print (or Print Setup), select Fax in the Printer Name box. This will open the Send Fax Wizard. You can also use the option called Send To and select Fax Recepient if you are using MS Office.
As soon as you hear your computer dialing, the Fax Monitor (as shown in the image below) will start up
fax_monitor_xp.gif How to Fax Scanned documents:
Another way to send a fax from your computer is to scan documents and then fax it through your Fax Printer. This can be made possible by using your scanner software. You can also fax from a scanner using the tools provided by Windows XP.
For this, go to the Control Panel and click on Printers and Other Hardware, then select Scanners and Cameras and then, double-click on the icon for your scanner to start the Scanner and Camera Wizard.
Then, on the Choose Scanning Preferences page, click Grayscale Picture and then click Preview to start the scanner.
Provide a name and location for the scanned document.
Now, go to the saved image which you scanned just now and right-click on it and select print - This will start the Photo Printing Wizard.
Click on the check box for the image to be faxed and select Fax as the printer you want to use.
When you finish the Photo Printing Wizard, the Send Fax Wizard opens and you proceed as described in the procedure for sending a fax from your computer.
Faxing from MS Outlook:
You can also fax from MS Outlook by adding the Fax Transport Service as an email account.
Receiving faxes on your computer.
Remember, you have already specified where the incoming faxes should be located and also how you wanted the incoming fax calls to be answered -manually or automatically. The Fax Monitor opens up automatically when the modem detects an incoming fax.
To view an incoming fax, go to the Fax Console and click on Inbox. Double-click on the fax entry you have just received and it will open up in the Windows Picture and Fax Viewer. Fax files are images in TIFF format so they cannot be edited. But u can print it out or email it to anybody else as an attachment.
on Jul 06, 2010 | Computers & Internet
Why am I getting the message "the system cannot find the path specified" when trying to scan?
Hi Tania,
You receive this notice when the drive and folder the scanner is configured to save the scan is missing. You can correct this by telling the computer where to save the scan. follow this simple steps.
  • On your computer desktop, click Start - open Devices and Printers -
  • Right-click on the printer/ scanner icon and select scan options. Assign a destination folder for saving your new scans.
Please rate me if this helps.
Oct 08, 2014 | Canon PIXMA MX452 Wireless Inkjet...
Can you also Fax with this One Touch 8900 ?
This is only a scanner. To Fax, you will need a separate fax machine or fax modem. If both the scanner and fax machine are connected to your computer, you will be able to scan the document and then fax it from the computer. (Depending on your OS/software, this could be easy or take several steps. For Windows Vista and Windows 7, you can use Windows Fax and Scan to do both steps. (However, the program doesn't scan to PDFs.) Paperport will also send a scanned document to an installed fax option. PaperPort is part of the third-party software that came on the CD with the scanner.)
Documentation for the Visioneer OneTouch 8900 is available here: http://support.visioneer.com/products/8900/default.asp .
I hope this helps.
(There are some email-to-fax and web-to-fax options but I have not reviewed them.)
Jul 14, 2011 | Visioneer OneTouch 8900 Flatbed Scanner
I bought a new hp computer with Windows 7 OS. My hp Officejet 7310 now will not scan. The HP Solution Center that was downloaded with the HP Officejet All-in-One series Windows 7 driver disc (new, just...
A full feature software and driver package for Windows 7 is not available for your product. However, the Windows 7 operating system installed on your computer contains a basic driver solution for your product. With the basic driver, some of the advanced product features are not available. You can print from a software program, and import and view images on a memory card, if your product has a memory card slot. With this basic driver, the buttons on the product do not function and some of the advanced product features are not available. How to Scan a Document in Windows 7 By Greg Harvey The Windows Fax and Scan utility enables you to scan documents and pictures. Before you can scan documents and pictures, you must have a scanner installed on your computer. Your scanner must be listed in the Devices section of the Devices and Printers Control Panel window.
To check to see if your scanner is properly installed, open the Device Stage. Choose Start?Devices and Printers. If Windows doesn't automatically find your scanner, you can manually add it in the Devices and Printers window by clicking the Add a Device button in the toolbar and following the wizard's commands.
  1. Choose Start?All Programs?Windows Fax and Scan.
    Windows 7 opens the Windows Fax and Scan window.
  2. Click the Scan button in the Navigation pane, then click the New Scan button on the toolbar.
    The New Scan dialog box for your scanner opens.
  3. Use the settings on the right to describe your scan.
    By letting the computer know what you're scanning, its color profile, and the type of file you plan to create, you enable Windows Fax and Scan to create the highest quality scan.
  4. Click the Preview button to see what your document will look like.
    Make any last minute changes.
  5. If you're happy with the preview, click the Scan button.
    Windows scans the document and presents you with an image of your document.
  6. Click the Save As button and complete the necessary information.
    Enter the filename, the type of graphics file you want saved, and then click the Save button.
To automatically forward the document you've just scanned as an attachment to a new fax message, click the Forward as Fax button.
The scan feature in the Windows Fax and Scan utility is set primarily to scan text documents. If you want to scan a photograph or other graphic, you're better off doing that directly within the Windows Live Photo Gallery.
Read more: http://www.dummies.com/how-to/content/how-to-scan-a-document-in-windows-7.html#ixzz15JFYWJQ1
Nov 15, 2010 | Computers & Internet
The scanner won't scan to the computer, but when I test it in scanners & cameras it says it is working.
This is my solution :
1st step : Turn on your *HP Deskjet F4185*.
2nd step : Click the Start menu.
3rd step : Click Devices and printers. A new window will appear.
4th step : Then, click the "Fax button ".The window Fax and Scan window will appear.
5th step : On the lower left corner , click "Scan" below the "Fax" button.Scanned documents (if there's any) will appear.
6th step : Click "New scan" button below the "File" button. And your printer will start! Glad to help..
Mar 29, 2010 | HP DeskJet F380 All-In-One Printer
When i want to scan a picture, it asks me to start the scan from the computer, how do i do this?
You may do this by using windows fax and scanner. Just hit new scan. Windows fax and scanner is a free software with all windows Operating System. It may also be done with the software which came with your scanner. the procedure is also most the same with any scanner software.
start---programs (or all programs)--windows fax and scanner.
Oct 01, 2009 | HP Deskjet F340 All-In-One Printer
Cannon MP530 scanner won't scan document it shows error code
hello ! reinstall the machine fax and scanner program cd's may be the installation was not completed or is the machine having issues .
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
Lexmark X5070 ALL-IN-ONE InkJet Printer Logo
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
