Question about Maytag Atlantis MDG6400AW Gas Dryer
No heat in gas dryer..replaced the ignitor..worked..then when he pushed it back into place it quit heating..the ignitor is lighting up but it is now not getting gas...and we have gas in the tank
    President:
  • 949 Answers
If the ignitor glows then shuts off but does not lite (it will do this over and over) then the problem is one of the coils on the gas valve is not working. The coil kit is easy to replace the part number is 12001349 and should run about $30.00. They secure to the top of the gas valve just in front of the ignitor you replaced.
If the ignitor continues to glow and does not turn off then the part you need is the sensor part number Y303377 which mounts to the burner box real close to the ignitor and runs about $25.00
I hope this helps.
Posted on Apr 23, 2010
Dryer is not heating. where is the heat sensor on DLE5001W
On a gas dryer the gas assembly is simply powered up by a sensor on the blower housing. If heat is called for from upstairs the power flows through the bimetal mounted on the blower housing. Here is a simple bi-metal: themobilian_2460.jpg
See the 4 wires? 2 of them wires operate a small heater inside the control. when it gets heated it shuts down faster for permapress and knits. Next to the control is a fuse on most models as seen here:
That fuse blows if the air temp exceeds 350f. That control thermostat at its hottest setting of cotton shuts down at 160f. It ramps back up at 105f. and continues to send power to the gas assembly till it feels 160f and then it shuts down. SOOO.. if we have a good fuse and a good thermostat 120 volts should get to the gas assembly if heat is needed. The gas assembly has a flame sensor which detects the heat bouncing off the ignitor. An ignitor to light off the gas, and a pair of holding coils. The whole gas assembly is energized at one. But them coils will not supply gas until the ignitor drops out if the circuit. To do so the flame sensor bi metal must shut down the power to the ignitor and that frees up the power to charge them coils and yank open the valve. The gas hits the ignitor and whoosh we have fire in the hole. It takes literally no time for the temp to reach 160 in the blower housing and so the power is removed from the gas assembly and the dryer tumbles onward absorbing the heat till the temp drops down to 105f and that control once again powers up the gas assembly. If your flame sensor is working and shutting down the ignitor and the heat works once or twice but quits then them solenoids are getting hot and quitting because they are old and weak. Replace em and party on.
Jun 18, 2011 | Whirlpool LGQ8000JQ Gas Dryer
Just hooked up my gas dryer. worked great thru 5 loads and then quit heating,help!
What did you do move it from one place to another place? You may have shifted the lint around and cause a limit to get tripped.
Here is the manual and more
A gas dryer has a burner assembly consisting of an ignitor, 2 coils, and a flame sensor. The ignitor does 2 functions. It lights the fire and confirms the fire is on like a thermocouple. When it is heated it holds in the coil. If the glowbar is not lit then the coils will not open. The ignitor must be heated to allow that. So if the ignitor and flame sensor is fine and the dryer works when cool but stops heating when hot I would say you need to replace the solenoids.
Nov 17, 2010 | Frigidaire GLGR331A Gas Dryer
Replaced heating element for dryer.Dryer started heating for one load. Then quit heating,found wire disconnected-reattatched wire and dryer was working.Now one small load later , dryer quit drying-no hot...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Whirlpool gas dryer we have the ignitor comes on, gas lights, runs for a minute and shuts off. After about a minute the ignitor comes back on but the gas does not. thanks
heatman101
Aug 17, 2010 | Whirlpool LGR8648L Gas Dryer
Its a gas neptune with dryer top. It quit heating so I reset it to factory defaults using the technical manual and the heat came back on but only for one cycle, Top heat works fine. Bottom control panel...
heatman101
Jul 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won't dry
Well lets talk about it a minute. The ignitor is ok because it does glow. The flame sensor is ok because the ignitor is working. The only other thing in the circuit is the solenoids. So what goes wrong? Those coils get hot and quit with age.7ecd66c.jpg Replace them and the dryer will come back to life.5dc4e80.jpg
Jun 28, 2010 | Whirlpool WGD5500S Dryer
Dcvh515: dryer does not heat. Replaced the ignitor. Still no good
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 03, 2010 | GE DCVH515GF Gas Dryer
Gas dryer quit heating
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Nov 01, 2009 | Whirlpool GGQ8831L Gas Dryer
I have a Maytag MGD5800TW Gas Dryer. It does not heat up. What should I check?
First, Remove small plastic tab on front panel of dryer lower left corner. Start the dryer on regular cycle and observe what happens through hole. You need to know if ignitor glows orange. If you do not see the ignitor glow orange, replace the ignitor. If seeing full orange of the ignitor, do you hear a clicking and see the flame light?
Leave the dryer cycling while observing. When the dryer heats to temperature the flame will shut off. If the gas valve coils are bad the next thing to happen will be that the ignitor will glow orange again, the valve will click again but the flame won't light.
If the gas valve coils prove bad, based on the observations above, follow the procedure below to replace the coils. If NOT, come back with the results of your observations.
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 279834.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Disconnect Power. Remove lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dyer will be on right. Gas components will be on left. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
Reverse process to re-assemble.
Sep 20, 2009 | Maytag Dryers
Whrilepool gas dryer wont heat but runs.
First, Remove small plastic tab on front panel of dryer lower below the door on left. Start the dryer on regular cycle and observe what happens through hole. You need to know if ignitor glows orange. If you do not see the ignitor glow orange, replace the ignitor. If seeing full orange of the ignitor, do you hear a clicking and see the flame light?
Sep 20, 2009 | Whirlpool LGR5636L Gas Dryer
Maytag Atlantis MDG6400AW Gas Dryer Logo
183 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
