Question about Fedders A6U14W7B U Chassis Through-the-Wall Room Air Conditioner w/ 14,000 Cooling BTUs & Electronic...
I have a 27 inch wall sleeve can a 26 inch friedrich unifit work?or do I need a 27 inch unit
  • 634 Answers
The a/c units keep getting smaller, when unit replacement is slightly smaller , the extra space can be filled with a piece of plywood or rigid foam insulation with a thin layer of plywood, any edges seen from inside can be covered with trim, make sure the wood covers entire bottom layer of sleeve to properly support. or just find the larger unit if you can. hope this helps.
Posted on Apr 23, 2010
Testimonial: "thank you so much. We have decided to choke and pay the extra for the a/c that fits. too bad we need two :("
Looking to replace a guasar wall aircondition that fits a sleeve the size of the aircondition was 26 3/4 by width is 25 1/4
Fredrich makes one which may work in sleeve or install a new unit with sleeve and put molding around hole in wall .
Oct 01, 2014 | Quasar HQ2051TH Air Conditioner
Thru the wall air conditioner is leaking droplets of water from between the frame and the body
Your unit should be pulled from the wall and cleaned. Also Check with a level that through the wall sleeve that the unit sits in has a slight lean towards the outside and not inside.
Jul 05, 2011 | Friedrich Heating & Cooling
Looking for a small 14" rough in...
not sure of over all lenght but a 14" rough is what we use to get at any real plumbing supply house
Aug 17, 2009 | Crane Plumbing Toilet To Go Tall...
AC Problems
1 and 2 there two type of motor 1 has lubricating acces this youshould lubicate the other no noacces. but commonly if you lubricate and still noisy you change the bearings qty2 or sleeves qty2
2- common cause of ice
- thermostat on min setting
- thermostat defective
-air filter is very dirty
-evaporator is cloged no air pass throu
- loss of freon ( a/c is leaking)
Apr 30, 2009 | Friedrich CP06C10 Wall/Window Air...
Friedrich air conditioner
Dear cmr 1,
As you have mentioned that it look like the fan hitting something, this is possible. This kind of problem can occur while transporting the machine. Some times the fan becomes loose because of viberation. So the fan has to be realign. Regarding the tilt it is okay to have 1/4 inch tilt backwards. Since the air-conditioner is brand new it is advisable to contact the company.
regards,
ramesh22
Jun 25, 2008 | Friedrich QuietMaster Deluxe RS12L10 Air...
Trru the Wall Oversized
Drop in a Frigidaire 25,000 btu, 230-volt Electronic Control Air Conditioner (Model #FAS256R2A). It is Way More Cooling than you need, but it is a very efficient unit and will provide quiet, nearly instantaneous room temprature reduction! Width 26-1/2... Height 18-5/8... Wall Sleeve Included... about $450.
Jun 23, 2008 | Frigidaire FAC124 wall/Window Air...
Through the wall vs. window installation
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Jun 12, 2008 | Heating & Cooling
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
Attaching 26 " lcd to stud wall
12 inches is the minimum for mounting the unit to the wall. I mounted a 42 inch LCD using a Sanus tilt (non-swivel) mount from Best Buy. We mounted it on wooden beams exactly 12 inches apart. Works great!
Mar 05, 2008 | Televison & Video
Fedders A6U14W7B U Chassis Through-the-Wall Room Air Conditioner w/ 14,000 Cooling BTUs & Electronic... Logo
333 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
