Question about Lexmark X75 All-In-One InkJet Printer
Cannot print envelopes on the Lexmark x75 - Lexmark X75 All-In-One InkJet Printer
Garfunkel01
  • 56 Answers
SOURCE: Lexmark X75 no color
even though you have ink coming out of the cartridge, if it's more than a few months since it's pumped any ink, it can be clogged internally, blotting with paper doesnt always work. Try a new cartridge, or buy a new printer, it's usually cheaper now to get a whole new printer than it is to replace a set of cartridges. consider it's a few years old now
Posted on Aug 16, 2007
Sandy4u
  • 107 Answers
SOURCE: my lexmark x75 only print black and white
Please check color cartridge is ok or not
if it is ok then check your printer configuration in Your pc it should be a gray scale printing ....
Posted on May 23, 2008
Arius
  • 446 Answers
SOURCE: LEXMARK X75 SCANNER
reset your whole system and use a different application program
Posted on Aug 08, 2008
  • 27 Answers
SOURCE: My lexmark will print page, business cards, labels, pics, etc. But it will not print envelopes. Looks, sounds, and acts like its printing. But when it spits out the envelope nothing is printed on it.
There must be an issue with the size of the envelope the printer is expecting. If you're using Microsoft Word, check under "Letters and Mailings" and then "Evevolopes and Labels" to check the size you have set the envelope to. Perhaps its also a setting in File and Page Setup or in the printers own settings under Control Panel and Printers. Sorry for not being of more help but if its not jamming or giving an error then its probably just set to the wrong envelope size.
Posted on May 17, 2009
Roop1980
  • 228 Answers
SOURCE: Lexmark z705 printing blank envelopes soft ware ok
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white."
2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab.
2. Select "Clean to fix horizontal strips."
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridge back into the printer.
7. On your computer, select "Old Cartridge installed."
8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
Posted on Oct 01, 2009
Testimonial: "Thank you. I was on the phone with Lexmark a whole hour last night and they couldn't fix it. This corrected the problem immediately! You are a Wiz"
Printer has stopped printing blue
Make sure that you are inserting only genuine Lexmark cartridges in your printer. Removing then re-inserting the color cartridge into the printer is a quick to minor cartridge communication issues.
Make sure that your color cartridge still has substantial ink level for printing using the Lexmark Solution Center software on your computer.
Click Start > Programs > Lexmark X74-X75 > Lexmark X74-X75 Solution Center. Check the ink levels.
If color ink level is still good, then it probably just needs some cleaning. Print quality issues can be due to dirty or clogged print cartridge nozzles. From the Maintenance tab in the Lexmark X74-X75 Solution Center, click Clean print nozzles to fix horizontal streaks. Your printer will then print a test page. Try to print a color page again to verify that the problem with the blue color is fixed.
If the problem continues, try to insert a different known working color cartridge to identify if it's a faulty cartridge issue.
Oct 26, 2011 | Lexmark X75 All-In-One InkJet Printer
I have a new Dell Inspiron560 computer which will not accept my Lexmark X75 printer
Access the manufacturer's web-site: http://support.lexmark.com
Enter 'X75' and do a search for device-drivers for your new Operating System (Windows 7?)
Download the device-driver.
Install it.
Print a test-page.
Feb 17, 2011 | Lexmark X75 All-In-One InkJet Printer
Is is not printing right. The printing comes out
Go to start->all programs->Lexmark X74-X75->Lexmark X74-X75 Solution centre
Then click on the maintenance tab in the far left corner. then, under Select a Maintenance Tool:,
select "align to fix blurry edges. that should fix it.
Jul 15, 2009 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75 won't print in colour anymore
When you print a color document do you get any color output ?. You may want to try to print a test color document, consisting of say Red, Green and Blue color blocks. If any of the blocks is missing you may want to replace your color cartridge.
Jun 01, 2009 | Lexmark X75 All-In-One InkJet Printer
Can't get my lexmark x75 to print on mac os10.4
Here is the link for the 10.2 and 10.4 driver you need. Download the correct driver and install it.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Feb 27, 2009 | Lexmark X75 All-In-One InkJet Printer
My Lexmark X75 will print but not copy. When I
I have an X75 at home and I remember the computer has to be on to copy, so it's really just doing a scan and then an immediate print. Are you copying from the button on the X75 or from the All-In-One Center software on the computer? If the button, try it from the software.
Feb 24, 2009 | Lexmark X75 All-In-One InkJet Printer
LEXMARK X75 SCANNER
Aug 08, 2008 | Lexmark X75 MF All-In-One InkJet Printer
Lexmark x75
I DONT HAVE CD PROGRAM THE MY LEXMARK X75 PRINTER
Jul 11, 2008 | Lexmark X75 All-In-One InkJet Printer
Printer jams
Page 11 of the manual does not list envelopes. It was not designed for printing envelopes.
Jan 10, 2008 | Lexmark X75 All-In-One InkJet Printer
Driver problem
Hi more than likely the drivers that came with your printer are not compatible with Windows Vista, below is a link for the X3350 but at present they don't seem to have the X75 Vista drivers listed. If you email their support your should be able to request the driver.
Have link but it won't let me post it
Let me know how you go
SeaJade
Dec 04, 2007 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75 All-In-One InkJet Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
