Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
\WHAT IS THE NAME OF THE PART THAT HOLDS THE MOWER
WHAT IS THE NAME OF THE PART THAT HOLDS THE MOWER BLADE.
  • 634 Answers
Spindle assembly, or mower deck spindle
Posted on Apr 23, 2010
Blade will not disengage on Craftsman GCV160 lawn mower.
that type mower the blade always turns when running .
May 07, 2015 | Craftsman Garden
Why won't my ride on mower start makes winding noise ?
Check the blade on the mower. Make sure it is tight and that the shear pin has not been broken. There is a shear pin on the crankshaft that keeps the blade from turning along with the nut that holds the blade on. designed to break off if you hit something with the blade. That is so it doesn't bend the crankshaft. Also make sure that the starter works and that the gear that turns the flywheel has not broken off a tooth.
Aug 08, 2014 | Briggs & Stratton Garden
Cub Cadet Wont Start.
Is the blade engage off? On my riding mower, I shut if off and the blade was still engaged. Drove me nuts for 3 days and all of a sudden, I got lucky.
Oct 03, 2012 | Garden
How to hold shaft when replacing blade
You should hold the blade while loosening the bolt that holds the blade.
Jim
Aug 05, 2011 | Black & Decker Black and Decker Mm575 18"...
What holds mulching blade to lawnmower?
A nut.
Unplug the spark plug.Lift the mower.Under the mower you will see the blade.It is held on buy the nut in the center of the blade.Wear a leather glove(or something similar)to hold the blade and turn the wrench(socket&ratchet)with the other hand.
Jul 12, 2011 | Arnold Corporation Arnold 21-Inch...
How do I change the drive belt on a 7021r mower? The drive will move the mower on pavement but not on the grass
First, you need to make sure you have the right tools for the job. You'll need a wrench, work gloves, mower blade clamp, drain pan and fresh fuel. Check your owner's manual for the correct belt to your specific lawn mower. Belts that are not specifically designed for your mower will not fit properly and may wear down prematurely. Next, remove the spark plug wire. This is a safety precaution to prevent the mower from accidentally starting.
Now you can remove the screws that secure the drive cover to the mower deck. Once you've taken off the drive cover, loosen the screw that holds the belt tension spring to the transmission. As the screw is loosened, tension on the belt is released allowing you to remove the belt off of the front transmission pulley.
At this point you'll need to turn your mower on its side to take off the mower blade. Be sure to use a work glove to protect your hand when removing the mower blade. You can use a lawn mower blade clamp over the blade to secure it. Unscrew the bolt to remove the blade and then the engine baffle. Once the pulley unit is exposed, you can remove the entire drive belt. Insert the new drive belt and place one end on the rear pulley and re-attach the engine baffle. Then, place the mower blade back (making sure it's facing the correct way with bottom of the blade facing the ground) and tighten the bolt. Remove the clamp and return the mower to its upright position so you can place the other end of the belt to the front pulley. Remember to tighten the screw to the tension spring.
Put the front drive cover back on, tighten the screw that secures the cover to the deck and reconnect the spark plug wire. Add new fuel to your mower and you're done!
May 14, 2011 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Lawn mower sounds like it is running fast and vibrating.
Sounds like a bent shaft, or bent blade.
Also sounds like the part that holds the blade to the shaft is sheared, and allowing the motor to run faster than it would if it is turning the blade properly.
Hope this helped,
Please rate me
May 25, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Need manual to see what size bolt is that holds on
Hi and welcome to FixYa. I am Kelly,
It appears your model number is 74370 There are 3 bolts one for each blade and the part number is 26-0671 or 260671 for the blade mount.
Part look up:
http://www.jackssmallengines.com
then enter part number 260671 $6.31 ea.
You can not use just any bolt for this. They are hardened bolts with an NF thread. If you use a non hardened bolt the blade will fly off when the bolt shears.
This bolt is available at most all Lawn Mower Parts Supply sources. Toro uses the same bolt on most all of their mowers.
If you do not have a Lawnmower Parts Supply near by, you might be able to go to an Autoparts supply source with yet one of the other blade bolts in hand and have them match the markings on the bolt head with yours so that you have the exact replacement bolt.
Any other parts for your mower can be found here:
http://www.jackssmallengines.com/help.cfm
Use the Search model window. each line below is a drop down window
Toro
Riding
74370 <- there are numerous models up to 74704
enter your model number if different.
Thanks for using FixYa.
Kelly
Apr 27, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
217 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
