Question about Philips MMS171 Computer Speakers
NO SOUND FROM SPEAKERS
Speakers have been plugged in a playing since OCT.2009. 2 days ago i tried to listen to PROJECTPLAYLIST where i have several personal playlists and no sound. i tried to troubleshoot but nothing. when i go to CONTROL PANEL>SOUND&AUDIO DEVICES>under volume i see that is is on LOW>but there is no option or anyway to drag volume but to HIGH.
The problem that I found with the mms 171 is the sound control function knob. When I took the component apart and took a closer look it appears the unit may have over heated a bit, I found some discoloration on the circuit board. When after I played with the reluctor wheel a bit it started to work again. I'm thinking what is going on is the unit heats up and warps the metal brush and it doesn't make contact any more. A simple fix is to take apart the knob a gently push the brush back down on to the circuit board (see picture)"><a rel='nofollow' href="http://s1088.photobucket.com/albums/i325/porkchopz28/?action=view&amp;current=DSCN1604.jpg" target="_blank"><img src="http://i1088.photobucket.com/albums/i325/porkchopz28/DSCN1604.jpg" border="0" alt="NO SOUND FROM SPEAKERS - Photobucket"></a>
Posted on Jan 27, 2011
No sounds coming from speaker
maybe when you plugged the cord into the speakers two days ago maybe you pressed to hard in the hole so maybe you broke it
Mar 29, 2017 | The Audio Players & Recorders
Suddenly no sound from speakers
First, we must determine if the problem is with the speakers themselves, or with hardware or software of the computer. Try plugging a set of headphones into the audio out jack of your system (often times, this will be a green colored jack). Play sound on the computer while listening to the headphones, can you hear the sound? If so, the problem is with the speakers, otherwise, you need to troubleshoot software/hardware of the system. Another method would be to try plugging these speakers into the headphone jack on an mp3 player, mobile cd player, stereo, or similar device. Aside from the system not putting out sound, the speakers could be plugged into the incorrect jack on the system (not audio out, OR not audio out on the correct device), or turned all the way down.
Sep 18, 2011 | Dell A215 Computer Speakers
I'm not getting any sound. Speakers are plugged in but no sound. Was working a few days ago. It's as if the sound programing has been deleted.
Could you specify if it's a computer you're plugging into or a device like an ipod or stereo? If the computer isn't giving you any sound, try the speakers with an ipod or something and then you can narrow down the problem to your sound settings / sound card...
Nov 28, 2010 | Harman Kardon HK206 Computer Speakers
I am problem with my external speakers. The
Must first make sure that the definition of the original sound exist if the sound comes out of the device at the other speakers if the computer does not have a problem, you must review the connections if the speaker did not come out audio of the device Make sure to place cable entry
Apr 17, 2010 | Dell Vostro 1500 Notebook
Recently, I purchased a used set of Bose 901 VI speakers. They are crackling when base sounds play. What is the problem? Was I duped? Is it the speakers or the amp or the volume. Can I repair?
It is likely that the speakers were damaged by someone playing the system at way too high a level.
If the noise sounds like a scraping, then it is the speakers themselves.
If the noise sounds like a breaking sound then it is likely the amplifier.
Another possibility is that if you are not useing a Bose amplifier, then your amp may not be capable of properly powering the speakers.
Jan 18, 2010 | Bose 901 VI Main / Stereo Speaker
Internal speakers don't work, external do
Um, in control panel, look for devices. Configure your hardware and sound.
Jan 10, 2010 | Compaq Presario Notebook
Sound will not play through headphones
Try here:http://www.computing.net/answers/windows- xp/headphones-amp-speakers-switching/55486.html Also:http://www.vistaheads.com/forums/microsoft-public-windows-vista-music-pictures-video/133605-sound-doesnt-switch-automatically-headphones-when-plugged.html Also:http://www.vistax64.com/sound-audio/198039-sound-doesnt-switch-speakers-headphones.html scroll down the page for the discussion.
Oct 18, 2009 | Philips (33-01-031) Headphones
Both speakers have sound, but some of it will not play.
You have connector problems- probably bad/bent/worn "jacks" in the speakers or they may be dirty (oxidation, etc) or fatigued. If you can get to the Jack on the inside of the speaker make sure it is making good contact with the plug. Clean the surfaces using alcohol on a Q tip or cloth. Many of these type speakers are not serviceable.
Mar 08, 2009 | JBL CREATURE II Computer Speakers
My computers sound not working.
try new sound drivers for your model pc ok
Feb 07, 2008 | Dell A215 Computer Speakers
My iPod stopped playing through speakers- but only at work...
Esmurfette
First things First!
1) check on other speakers to see if your iPod work fine
2) check connector for loosing electric connectivity.
3) check with your headphones to see if your iPod play music well.
4) Check, power on the computer spk. you got. or the input that is working right.
Good Luck
Jan 29, 2008 | Apple Logitech Inc MM50 Portable Speakers...
Philips MMS171 Computer Speakers Logo
173 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
