Usb hub powering up mt pc fans??
Powered usb hub is setting fans on in my pc??? when i plug my hub in the back of my pc all my fans come on and cpu fan comes on when the pc is not powered up ?? it is switched so why is this happening julie
  • 75 Answers
The switching system of your mainboard is not working properly try to change the resistor and capasitor near the control panel. good luck
Posted on Apr 27, 2010
Usb mouse not working
Solution is to re-install USB Root HUB > Make sure you disconnect all USB devices before you follow these directions. Use a PCI mouse and/or Keyboard to do the following. You may try using a USB mouse, but often times you'll uninstall your mouse's USB Root HUB before you completely uninstall all the other USB Root HUBs making your mouse useless. Follow the steps in the link over and over until all USB Root Hubs are uninstalled. Restart your PC and then slowly add one USB device at a time.
Side notes: Keep in mind if you have way too many USB devices you will need a Powered USB HUB. You can buy them cheap, and they are worth it. Often times folks plug more USB devices than their motherboard/power supply can handle or they rotate like 40 devices on one PC. Rotating is OK, but you might want to follow these steps to make sure your PCs USB is working OK.
The link:
DriverFinder We Make Drivers Work for YouPC Driver Tips Tweaks to...
Jan 17, 2014 | ASUS G50 G50v G50v-x1 G50vt-x5 Series...
Continous beep sound from the mother board
make sure your cpu fan is runing and the psu fan is running if they are then it maybe your computer ram
Feb 28, 2013 | Dell OptiPlex 760 MT Desktop Computer
My computer suddenly lost power and now it won't even turn on.
replace the power supply of your cpu check if the blower fan is spinning during power on it means that your power supply is good if not replace the power supply with a new one
Sep 12, 2011 | Dell Inspiron 537 MT Desktop Computer
Continuous beep and the systems is not coming up {boot}
Hardware problem:
* dead RAM
* dead video-card
* RAM not fully "seated" in its slot(s)
* video-card not fully "seated"
* dead fan on top of the CPU/heatsink.
* failing power-supply.
Jul 12, 2011 | HP Compaq dc5100 Small Form Factor PC...
My computer don't see mt toshiba 500 GB external disk. I had Win XP with SP3 and my external disk is connected to a USB hub with 8 ports. I had a pen connected to that hub and the computer see it. But...
Your USB hub cannot provide enough power for your external hdd, you can try to plug it in directly to any free USB port for the mean time to check if its detected or not, if it has a power button ( which is not normal for regular USB powered EXT HDD) make sure that it is on, if its still not working try to use a different cable, a known good cable or plug it in to a different computer to check if its your USB port, or the usb cable or the ext hdd that is causing the issue
Hope this help.
Jul 10, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
Power indicator blinks red
According to the shop manual (found at http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00261093/c00261093.pdf), this indicates no memory. You should open the case, remove and reinstall the memory modules. You might want to use some compressed air to blow out the sockets prior to reinserting the memory modules). If this doesn't work, you'll need to replace the memory.
Dec 19, 2009 | HP (REFURB) HP DC5000 XPP C 2.8GHZ 40GB...
4 Port USB 2.0 Smart Hub Pro with Power Supply Part No. 42999
Slap a voltmeter on the Power Supply for the USB Hub and make sure it is still working. It really sounds like what happens when you connect a device to a unpowered hub that is not capable supplying enough power.
Feb 28, 2017 | Ultra Products 4-Port USB Hub
Black rectangle block will not go away on pc monitor[top right]
hi your problem is caused by heat and a faulty power switch board in front which is also connected to usb and front audio first the heat problem download program fan control I8kfanGUI this program is free fan control set you fan speed to max to cool cpu dell made bad design on cooling. net you have to set bios on pc to auto power on pc after power loss unplug pc do not power off by windows now disconnecgt the ribbon cable that connects to front power switch plug pc back in and it will auto boot.pc should have no more problems the little board in front is faulty and dell e510 all have this problem unfortunately you lose usb ports but you get system stable again.
Apr 14, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
My philips external harddrive (SDE3271) (250Gb)when we try and install the drive it keeps coming up with power surge on the USB hub port. It also keeps on beeping.
the power required by the DRIVE is not there,
so connect it directy to your cpu, or use a hub which also have a power option
Sep 30, 2008 | Computers & Internet
Downloading
Use the USB ports that are on the back f the PC, not the front ones or the one on the keyboard, these are low power USB ports. You can also purchase a powered hub that supplies its own power. The maximum draw on 1 USB port is 500ma, shared across all devicesattached to that port including non powered hubs. My USB PC-cam took 450 all by itself!
Feb 14, 2008 | Photography
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
