Question about Kenmore 34613 Bagged Upright Vacuum
I have a new brush to install but cant figure how to remove old, what is the trick?
    Scholar:
  • 48 Answers
On most vaccuums, there should be a single panel going across one side of the brush wheel. If not, the entire panel should come off. In 90% of cases, this will basically allow the brush wheel to fall free, and the new one to be slotted into the old slot. Ensure the belt is connected, and reattach the panel.
Posted on Apr 23, 2010
Brush not turning and there is a smell
Your belt has most likely burned in half, this happens from an object getting caught in the brush roll, a brush roll that does not shin freely i.e. debris under the end caps or usually and old stretched out belt that has been slipping; belts can stretch out in 6 months whether you use the vacuum or not.
Remove the brush roll and old belt, inspect for damage, clean out the area and instal an new belt or the same brand and type. It should be good as new.
Oct 30, 2013 | Vacuums
Vax 2300
If the roller brush cannot be rotated easily by hand, it is likely that debris is jammed inside the end caps.Make note of the direction arrows on the end caps as you remove the roller brush. You will need to know this for reinstallation. The end caps are fastened with stop nuts. Removal of one will allow the inner shaft to be extracted for examination and cleaning. An old toothbrush is a good cleaning tool. Reinstall the inner shaft and stop nut. Check for free rotation of the brush roller. Place a new belt over the brush roller and reinstall the brush roller, being careful to observe the position of the arrows on the end caps. Inspect the motor shaft and remove any old belt residue before installing the new belt on the shaft.
Jun 30, 2013 | Vacuums
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
I have a eureka bravo upright model 9600. I have removed the hood . I need to remove the brushe roller to install a new belt. I cannot figure out how to remove the brush roller.
Check out this URL:
http://www.svcvacuum.com/beltrep2.html
looks like it has just what you are looking for. Would appreciate a thumbs up on this if you find it beneficial. Paul
Oct 04, 2010 | Eureka Vacuums
Beater bar belt needs replacedon a dyson DC14 animal
Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
Its in the instruction book
Mar 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
How to replace Riccar Roller Brush Bristles.
On the belt end, there is a clip #59 to remove then you can take the brush roll apart, replace the brush strips and put it back together.
Jan 02, 2009 | Riccar 8850 Vacuum
Hoover Upright...OLD vacuum, broken belt
The rod must be your brush roll. it should just pull out, Have you removed the cover over the brush roll? When you do get the brush roll out, turnb the ends and make sure they turn freely, if nit, replace it also.
Sep 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
I have no idea how to put the belt back on
Take the nozzle of, remove the brush roll, put the a new belt over the brush roll, re-install and put the bottom plate on, making sure that the belt is in the middle of the brush roll. Turn the big knob on the front until it locks, when it grabs the belt it will be hard to turn. Re-install the nozzle on the machine and lock it down. Turn the knob again all of the way, this will release the belt unto the pulley.
Jul 13, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Replacing Belt
On the front of the power head is a knob with the KIRBY name on it. Rotate this knob in a counter clockwise direction and it will "lift" the belt off the motor spindle. Release the head lever, only one direction it will turn and remove the head. Turn the head over on its back, turn the KIRBY knob to release the old belt. Remove the brush guard by turning the two release fixtures. Remove the guard. Pry the brush out of the head. Remove the old belt. While the brush is out remove any build up of hair and lint off the ends that's where the bearings are. put a few drops of 3 in One oil on the ends. Put the new belt over the brush and re-install the brush into the head. the brush will go in only one way. With your finger pull the belt into the housing and rotate the KIRBY knob until the pawl inside grabs the belt. Re-install the brush guard by engaging the two metal pieces into the front of the head and pull down backwards over the head and rotate the holding clips back horizontal. re-install the powerhead on the machine, lock it in place and rotate the KIRBY knob clockwise. You should be all set!
Aug 23, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Cannot get new belt on
no need to remove motor shaft which is integral with motor. slip belt on motor shaft first, then on roller then pull roller back to correct position. needs a little force
Jun 06, 2007 | Hoover U8145-900 Savvy Bagless Upright...
Kenmore 34613 Bagged Upright Vacuum Logo
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
