Question about Whirlpool Washing Machines
How do I go about putting back the cabinet on my whirlpool washer
  • 5,911 Answers
If you are referring to a Whirlpool TOP LOADER. The following link explains step-by-step how to remove and re-install the exterior cabinet:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If you run into difficulties, please post back and let me know. I hope this helps you.
Posted on Apr 23, 2010
Testimonial: "thankyou very much for sharing your knowledge with someone who had never fixed a washer in her life once again thankyou"
Remove cabinet
First and foremost, unplug the washer. Philips screw driver, look behind the control panel, far left and right. Unscrew those and flip up the panel. Unplug the panel from the cabinet. Next take a flat tip screw driver and remove the clips that hold the cabinet to the rear panel. Once you do that tip the rear of the cabinet towards you and there you go. the easy part is now done, When putting it back be patient with lining everything back up. A video to demonstrate these steps can be found online mentioned in several solutions here. I apologize the site escapes me. Good luck.
Sep 06, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
How do I replace the water intake valve on my whirlpool top loader.
Whirlpool, Kitchen Aid, Kenmore, Roper, Estate, after 1985
• The valve will be mounted to the back of the washer with two screws. However, you must remove the valve from inside the washing machine, and this requires you remove the entire washer cabinet, which consists of the top, front and sides.
• Remove the two screws in the lower corners of the control panel.
• Lift the control panel up high enough so it stays up and back.
• Disconnect the wire harness connector.
• Using a flathead screwdriver, snap out the two gold-colored spring clips at the top of the cabinet on the left and right sides.
• The cabinet will now lift up at the back. Pull the cabinet up 10-12 inches and then slide it forward 2 inches.
• Remove the cabinet completely and set it aside.
• The valve will be on the right side of the washer at the back. It’s the device to which the water fill hoses are attached.
• Label the wires from the valve and remove them.
• Remove the water feed tube(s) from the valve.
• Remove the screws holding the valve to the back panel.
• Install the new valve in the reverse order.
• Reinstall the cabinet. (Note: As you follow this procedure, do not force the cabinet in any way. When done properly, the cabinet will go back together very smoothly.) First, tilt the cabinet toward you 10-12 inches while you “walk” the cabinet back onto the lower frame of the washer. (This will be easier if you have the washer lid open so you can see inside the cabinet at the same time.) The front edge of the cabinet slides underneath the base frame, and the sides of the cabinet rest on top of the base frame.
• When the cabinet is resting on the frame squarely, check to be sure the back of the washer is aligned with the cabinet. There are two plastic strips attached to the back of the washer that must line up with the sides of the cabinet as you set the cabinet down.
• Reinstall the two spring clips at the top.
• Reattach the wire harness connector.
• Rotate the control panel back down and reinstall the two screws.
• Flush out the water fill hoses.
• Reattach the water lines.
• Turn on the water.
• Check for and correct any leaks.
• Restore power and test.
Hope this helped you and best wishes.
Jul 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool top load washer will not agitate or spin.
Hi, If the motor runs but the washer will not spin or agitate, you will need to change the coupler. Here are the instuctions
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them. Now the cabinet will lift off the frame and you can set it aside.
How to replace a coupler:
Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you will need to unplug the capacitor.
Now you will need to replace all three parts to the coupler. I use a ½” socket and a small hammer to force the coupler onto the motor and transmission shafts. Put the rubber part onto the coupler half on the transmission and then line up the post on the motor shaft with the holes on the rubber part and it should go on ok. Put the clips that hold the motor in place and plug in the harnesses.
Put the pump back on and the clips to hold it in place. Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
Vic
Jul 18, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool washer won't spin
Hi, It sounds like the coupler has broken. If the motor runs but doesn't do either of these things, here is how to Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you wil need to unplug the capacitor.
Please let me know if this helps you or if I can assist you further.
Vic
Jul 13, 2009 | Whirlpool LSR5132PQ Top Load Washer
Howdo i get the washer cover off a thintwin whirlpool washer tha
the timer box or the whole washing cabinet cover?
the timer box is removed via 2 screws in the rear of the plastic end caps and carefully wiggling it foward very gently then it should tip back...
if you want the cabinet removed under the timer box is 2 metal snaps that can be removed to take off the outter cabinet.. good luck
Feb 15, 2009 | Whirlpool LSB6200PQ Top Load Washer
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Water leak
remove the 2 screws holding the console in, they may have trim on them.flip it up and you will see 2 metal brackets on left and right. pop thos off taking note how they are on there, disconnect connector on the top of the cabinet(door switch wires)lean cabinet foward pull towards you.it is know free of the rest of the machine. put back reverse of these directions making sure the back lines up properly with the cabinet.
Oct 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer
hi thanks for the question. the cabinet has to come off.to do this. 2 screws 1 each corner of the console. remove. lift the console. 2 brass clips on top. remove. disconnect the wiring for lid switch. pull cabinet off. put washer on a block to raise it . its easier. . remove the clips that hold the pump on the motor. remove the motor. 2 screws 2 clips. replace coupling thanks the appliance doc
Oct 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Cabinet putting it back on
Got the problem taken care by located the tabs that lock the cabniet back together on the base. Everything then lined up prefectly. It is more than a 1 man job...lol
Sep 07, 2008 | Whirlpool LSB6200PQ Top Load Washer
WASHER
You have to remove the cabinet. Remove the screws on each end in back on the consol. The consol will then flip up. Remove the two snap springs holding the cabinet on. Unplug the lid switch. Now the whole cabinet will pull off. Check out the pics...Catriver...post back.
Jan 05, 2007 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal De
