Question about Alphasonik PMA800DA Car Audio Amplifier
Turned on radio amp started smoking on the side where the bass boost goes still got power on amp and voltage meter still works but bass boost does not work thats where the smoke came from
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
I would get it looked at, you never know. when ever your stuff starts to smoke it might work for a lil while but sooner or later my opoin it will be just junk.
Posted on May 11, 2010
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
My brand new Kappa One amp is powering 2 brand new Kappa 100.9w subs at a 2 ohm load. The Ground an Power are both 4 gauge wire. The problem is my amp is just getting so hot that I can only touch it for a...
Sometimes these amps have been known to get hot very easily. That said, I would first confirm the resistance on your speakers at rest is 4 ohms each, so that your amp is seeing a 2 ohm load. Be sure that the smart switch on each sub is flipped to the 4 ohm mode, and measure each separately.
Be sure that you've properly set the filters, gain, and bass boost so that your amp is not being over driven. Your HP filter should be set no lower than 20Hz--most music is never going to go that low so there is no point. A narrower frequency band is always going to be healthier for your subwoofer. The LP filter should be set no higher than 90 to 100 Hz at the most, depending on how much midbass your speakers can handle, so that you don't have too much of a sonic gap between the subs and mids. As for the gain, a good place to start is with your radio set at it's highest comfortable, distortion free setting, minus 25%, then start with the amp's bass boost all the way down, and the gain set to the minimum level at which you can just begin to hear music. Choose a bass heavy track if you ever listen to bass heavy music, so we can prepare for the most stress that the amp will experience. Slowly turn up the gain until you start to hear distortion during heavy bass hits, and back off 20% - 25%. This should be the highest volume you ever push your amp to, and from here, you can ever so slightly turn up the bass boost if you absolutely must, but not to the point of any distortion, if you hear any, back it off a bit.
Jun 22, 2017 | Infinity kappa one Car Amp
I have a kicker 750.1 amplifier. I was playing it one day pretty loud and it cut out once the bass hit and started smoking.The gain was up about 1/4 and the bass boost was about half way. what could of...
I would say that your subwoofer Or speaker leads have shorted out...when the bass hits as you say it drives the amp hard but if it is trying to dump power onto a shorted speaker or speaker wires it will blow the output power transistors not to mention other vital components of the power amp...i suggest you test your speaker leads with a Multimeter on the ohm setting before connecting a repaires or another amp.. to make sure there is no short on the leads and that the resistance is around 4 ohms or so depending on how you have your drivers wired...but anything lower than 2 ohms will cook an amp! you can normally pick up a meter from anywhere for around $10..
Jan 14, 2010 | Kicker (ZX750.1) Car Audio Amplifier
What settings should i have my 760 watt pioneer amp set at for amp gain and bass boost in order to have the best sounding hit from the subs?
they want you to "level match" the amps head units voltage from the rcas .this is best done with the radio at 3/4 volume , turning the amps gain dial till music distorts then backing off till it sound s clear .if theres other units in the signal chain (eq,x overs, ) see if they too have gain /volume controls . it goes down the line if thats the case . .
Nov 23, 2009 | Pioneer Car Audio & Video
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
JL Audio 1000/1 hook up to alpine type x
it is all up to the user, you can start by turning the input up slightly, I would not go over halfway because it usually starts to distort, then the bass boost up till they distort a little then back down a quarter turn.
Mar 10, 2009 | Jl Audio 1000/1 Car Audio Amplifier
I turned my 15" L7 kicker and smoke started to come out the box
As stated before, knowing the impedance of your subwoofer would really help the situation. Either way the link I have provided is to your subwoofers manual (Incase you dont have it)
But since you have said it has smoked, if it still works I recommend turning the bass boost down (Bass boost causes alot of heat within the subwoofers voice coil and even within the amp itself and should never be maxed out.)
Here is a link to your manual for the subwoofer.
http://www.kicker.com/sites/default/files/SoloBaricL7Series.pdf
So as a solution to your issue, keep your bass boost turned down. You should almost never need it if you have tuned your amp correctly (You have a very serious subwoofer there)
Consider yourself lucky if your subwoofer is still working without issues.
Feb 09, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Hifonics Nemnsis powerin off.
need to charge you batteries up more bass cuts out because not enough power! i have the same issue! 2 amp slow charge is the best way to charge your batteries!
or caps!
Jan 27, 2009 | Hifonics HFR1 Amplifier Accessory - Remote...
Left side speaker and bass not working
Do you have a bass-boost switch on your unit? If so check that, go easy,but you can try to be a bit rough moving it back and forth up and down or so. If that wont work you can always try walling it!
Dec 27, 2008 | Bose Wave Radio
Need to know the right setting to apply for my subs
You need to match your amp's input voltage (the gain) to the output voltage supplied via your deck's preouts. Turn you radio up to normal listening level, and turn the amp's gain until you induce audible distortion then back it off slightly. Set the bass boost and crossovers to on and type (highpass for front/rear full range or lowpass for subs).
Apr 26, 2008 | Jl Audio 12W3 Car Subwoofer
Alphasonik PMA800DA Car Audio Amplifier Logo
132 people viewed this question
Top Alphasonik Car Audio & Video Experts
hoyzee1
Steve Sweetleaf
Steve Sweetleaf
brian williams
Are you an Alphasonik Car Audio and Video Expert? Answer questions, earn points and help others
