Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
  • Fisher and P... Master
  • 2,651 Answers
There is a round pin on wither side of drawer front, when ithe drawer is opened, witha pair of needle nose pliers grab and remove both of them, the drawer front then will slide down and away.
Posted on Mar 23, 2008
My kitchen looks old and has lost its lustre, and I am in need of kitchen remodelling work done. Can anyone suggest a reputed home- finished carpenter?
I had was recently clueless and confused about hiring a professionally skilled team on contactors for lending me the best kitchen and bathroom remodeling Lynnfield MA services, until and unless I came across the popular carpenter named Paul's Carpentry of USA. I was speculating about its performance, and hence hired it after background research and called up the references given by the team. To my surprise, they served my home with the most satiating bathroom and kitchen remodeling Lynnfield MA experience, coupled with high quality and dedicated custom cabinets and installs Lynnfield MA works done. They charged reasonable price for the total finish carpentry Lynnfield MA package, and the contractors were trained, insured and licensed. Thus, if you are looking for a reliable home finished carpenter with 100 percent customer satisfaction ensured, choose Paul's Carpentry.
Mar 03, 2018 | Home Security
My ikea kitchen cabinets and drawera are out of alignment
You need to adjust the drawer runners by loosening them of slightly and re screwing them up by a couple of mm.
Apr 11, 2013 | Furniture
My Fisher Paykel DD603I top draw whines when it is first turned
The lid seal on the top drawer is faulty and needs replacement. It might be cut or damaged and is obstructing the drawer from closing. THis also may have caused the flood switch to trip as water can leak if drawer is not sealed.
Nov 29, 2012 | Fisher and Paykel Dishwashers
How to get bottom drawer out of fisher paykel dd6031
I wasn't able to find an exact match to your reported model (DD603I?), but all of the DD60xx models appear to have the same drawer removal process:
2_23_2012_6_18_56_am.jpgI actually took this from the installation guide for the KitchenAid dishdrawer (also made by F&P), since it had the clearest images.
Dec 24, 2011 | Fisher and Paykel 24 in. DD603H W Built-in...
F&P dishwasher (DD603i) has no power to top drawer
No power to the top drawer needs to be verified.
Are you saying the lights are blank and when you press the start buttion nothing happens?
One reason the controller can shut the power is that the heater overload protection thermal resistor has opened. Unfortunately the only way to fix this is to replace the entire heater plate at the bottom of the drawer.
To confirm if the controller is operational or not, press Keylock and Start/ Pause button together for 5 sec (press Keylock first) and see if the Lights light up. If nothing happens then either the power has shutoff as mentioned above or controller is faulty.
Depending on your familiarity with such equipment you could try to replace and fix. I am not quite sure what the new model you mention is. I believe all DD603 models have power to the 2 drawers coming from the base board.
Feb 06, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do I remove the bottom drawer of my F & P double drawer dishwasher for mounting into the cabinetry?
I am assuming you have an integrated double drawer unit DD603I.
The instructions for removal and refit of the drawers is available in the Installation Manual. I am able to locate one on the following site
You may also need instructions to prepare and fit the front panel of the cabinetry to the drawers which you can down load from
Hope this is what you are after.
Nov 18, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Kitchen drawer roller problem
phone or online look for custom cabnet shops more than likely have some or can still get from supplyer
Apr 14, 2009 | Hardware & Accessories
Fisher & Paykel dishwasher drawer won't run, beeps F2 error code
Craig, we had virtually the same situation.  The repair man  came and it took 2 minutes to fix.  The problem was that the bottom drawer had not been used for a couple of years and thus the impellor had jammed.  to fix it take out the basket, lift off the rotor arm and unscrew the knob.  Then just work the impellor around with your fingers until it frees.  It then worked perfectly.  We will use the bottom often from now on to prevent this happening again. By now the left over pumpkin pie will be a bit green!!
Nov 29, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
DD603I with custom front panels... leaking rinse agent dispenser
That's crazy! That dispenser is very easy to change, you just need a torx bit screwdiver.
Feb 19, 2008 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
243 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
