Question about Kenmore Elite 45986 Front Load Washer
I just have an F flashing and then an H-- washer starts to run and then stops after filling
    Scholar:
  • 126 Answers
CODE FH
If after 30 seconds the control does not detect water entering machine,
the valves will be turned off and the error code will be displayed. Or If
the control has turned the water valves on and after 8 minutes the flow
sensor has detected 10.5 gallons of water passing through it, but has
not detected the pressure switch trip, the valves will be turned off and
the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
_ If there is no water in the unit:
Make sure that both valves at the water source(s) are turned on all
the way.
Check for plugged or kinked inlet hoses or plugged screens in the
inlet valves.
Verify inlet valve operation.
_ If there is water in the unit:
Verify Drain pump operation.
Verify that the Pressure Switch Hose is in good condition and
properly connected to Tub and Pressure switch.
_ Verify there is not a siphon problem.
_ Verify wire harness connections to; Inlet Valves, Pressure Switch,
Drain Pump, Flow Meter, and Central Control Unit (CCU).
_ Check all hoses for possible leaks.
_ Verify pressure switch operation.
_ Verify flow meter operation.
_ Verify CCU operation.
Posted on Apr 24, 2010
What does a steady flashing wash light mean?
pump all the water out and stop the wash cycle your on
open the door
then disconnect the mains supply for 10-15 mins
then turn it back on and hope the software fixes itself
otherwise there is an issue its detecting
like the door interlock is being detected as bad.,..
if the motor isnt running perhaps the motor brushes need replaced and this is the cause of the flashing wash light
and motor not running
i would check out the brushes have atleat 3/4 " on them
if not replace them
Dec 20, 2014 | Hotpoint WD440 Aquarius Washer/Dryer Combo
Machine started filling with water - then stopped and flashed F
I have the f51 code filled up with water and stopped. They are coming today to fix it. Called whirlpool and they are fixing this at their expense. I have the extended warrenty they said they are fixing codes f1 and f51
Oct 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore serie 80.does not stop filling water in and does not star
Yeah I've seen that happen a many of times. Take the back of the control panel off and where your load size selector is you'll find a little hose that's suppoed to be attached to the side of it. just reattach it and you'll be back up and running.
Almost all washing machines use a pressure tube that tells the washer when to stop filling with water. If the tube comes off for some reason the washer will never stop filling and that's an instant flood if you don't notice it quick enough. Also a hole or puncture of any kind can be causing ti to never stop filling as well.
Hope this helps
Jason
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Code pf came up and the washer does nothing
PF Power failure "PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost.
OR
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Apr 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore HE4T washer won't rinse. Valves open to
An HF Code is a Water Inlet Problem- No or Insufficient Water Supply.
Press Pause/Cancel twice to cancel the cycle. Then, unplug the washer.
Run down the list again:
Make sure faucets are completely turned on.
Make sure the fill vavles (screens where water enter machine) aren't clogged.
Make sure the hoses aren't kinked, etc.
Plug the machine back in. Try another cycle. If the problem still occurs, You may need to replace your Water Fill Valve. Let me know if you need any further assistance.
Feb 23, 2009 | Kenmore Elite 45986 Front Load Washer
Water will not stop filling washer
cut power to washer ..does it stop filling? suspect water level control or small hose to it is off ..keeps running in? shut off water to washer and change fill valve where hoses attach..just won't fill to top and start? raise level of drain hose up and be sure it is not too tight in drain pipe to prevent siphoning
Jul 15, 2008 | Whirlpool Washing Machines
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
