Onkyo TX-SR805 If I turn the volume up loud on my receiver, it shuts off, and the power light blinks red. If I put my hand on the top of it, I nearly burn my hand. I then noticed that neither of the fans, located on the sides of the receiver, ever turn on. I hate to be without the receiver, because everything I own is attached to it. Is making the fans turn on possibly a simple fix, or do I need to send off my receiver? Thanks, Jonny
  • ohjonny Mar 23, 2008
    Thanks Dan. I'll go have it serviced...and sadly not have a receiver for a week or so.
    PS: I have a fan blowing air into it.
  • 4,234 Answers
When you turn up the volume, the amp works harder and generates more heat. There is a small transistor attached to the heat sink that detects the excessive heat and shuts down the amp before there is damage. There is a circuit inside that should detect the increased volume and turn on the fans. Either this detection circuit is defective or the fan driver transistor is defective. This unit may need to see a servicer. In the meantime, you can provide additional air flow to keep the heatsinks working efficiently. Realize that this is a short term "fix" and you should really get this repaired ASAP to prevent permanent damage to the amp components.
Posted on Mar 23, 2008
Onkyo TX-SR805 Receiver power-on button not working, only the led red light indicator appears. Tried to reset by holding/press vcr/dvr & standby/on button, no result. Please help me solve this problem
Hello, Sorry, if the receiver does not turn on we can't do any troubleshooting. I suggest having your receiver serviced or traded in. Thank you, Onkyo USA
Feb 26, 2017 | Onkyo Audio Players & Recorders
Onkyo AV Receiver TX-SR503 While sleeping with earphones connected, the receiver shut down and the standby light blinked. I unplugged the power cord, reconnected power and the receiver shut down...
Have you provided adequate ventilation?
May be your receiver is running hot and when there is loud volume it is obviously getting overloaded. There are no fans inside 674, the only way to provide good ventilation is to keep the top of receiver clear for atleast 6 to 8 inches.
Hope that helps.....
Jul 03, 2008 | Onkyo Audio Players & Recorders
Trips and switches off
Hello Fixya customer,
Thank you for your question.
The best way to fully isolate the fault is to disconnect all the speaker wires, and verify that there are no strands of wire shorting between the speaker terminals on the rear of the unit.
Turn the volume all the way down, full CCW, and if it goes into shut down with the STBY light blinking then there is a fault in one of the amplifier's.
Thank you for using Fixya, and if I can be of further assistance please ask.
May 01, 2010 | Onkyo TX-SR706 Receiver
I have an onkyo tx-sr506 and the system shuts off as I turn up the volume. It doesn't get very loud (barely audible) before shutting off.
Check speakers for distorted or dead drivers . Disconnect and repair. receiver will blown if not disconnected.
Mar 15, 2010 | Onkyo TX-SR506 Receiver
My 605 turns off and red light blinks when volume goes past 58
Shorted speakers can cause the unit going on protection mode (the red light blinking) when a certain volume is reached.
Test with a set of replacement speakers.
If it is not the speakers, it is probably transistors in the amp final or something nearby. Test also input output board.
Apr 27, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SR705 shuts down suddenly
Onkyo receivers have a safety circuit in them to protect the Amplifier from blowing up:
If you listen closely when it shuts down ( after a loud scene ) there is likely a loud 'Relay Click'..
If this is what is happening you might be able to verify it by turning the volume all the way 'off' and waiting for the circuit ro reset ( releasing the safety relays & returning power to the internal Amplifier ) : you should hear another click, yhen you can bring the volume back up carefully and there will be sound again.
This safety circuit trips when then Onkyo receiver detects an 'Over Current' condition on the
' Power Supply ' that feeds the internal 'Audio Amplifier'..
Generally caused by:
Improper load presented to the Amp outputs ( FL, LR, RL, RR, SUB, CENTER )
If you can ( one at a time ) turn off the SUB, Center, Fronts and Rears: trying to re-create the failure each time while you have one part of your system disabled or having their level turned way down..
You can isolate where the problem is coming from.
- any or all of these speakers being the wrong Impedence ( I.E. 4 Ohms instead of 8 Ohms )
Unless the receiver manual or the sticker near the 'speaker connetor' specifies a range or another value, you should assume 8 Ohms. Your speakers should say on the back of them.
- any of the speakers being connected in parallel ( 2 speakers to a single one speaker output ) .. Two 8 Ohm speakers connected in parallel make a 4 Ohm load to the amplifier.
- If the Suwoofer is Passive ( Not having its own power cord and amplifer ) it has a
Passive Crossover : this crossover can have its own power rating or limitation.. If it is constructed with capacitors that have too low of a working voltage, then they can saturate and the crossover itself can present a load to the amplifier that will case this 'Over Current Shut-Down'..
You user manual should detail this.
Apr 09, 2009 | Onkyo TX-SR803 Receiver
Onkyo xsr502
Check the spekers first maybe one could be in bad conditions or the audio amplifier IC are about to get damaged.
Jun 17, 2008 | Onkyo TX-SR502 Receiver
Unit fails to power up
bad unit in power take it back if u just got it my fav is harmen kardon and kenwood 7.1 thx good prices too does everting way it should last forever
Jan 19, 2008 | Onkyo TX-SR605 Receiver
Onkyo HT-R501 7.1 reciever issues
i have the same problem with a onkyo tx ds494
Jan 05, 2008 | Onkyo TX-SR605 Receiver
214 people viewed this question
