Question about Black & Decker Garden
Elect mower blade replacement
I have a B&D mm850 electric mower and took the blade off to sharpen but I can't remember how it goes back on. There are 2 plates, one plastic and one metal--do they got next to mower or on top of blade?
Mower, then blade, then plastic part, then metal square washer, then nut
Posted on May 08, 2010
Craftsman 6.75hp 22 mower starts for a few seconds and concks out
If the carbeurator is pitted or corroded in any way you need a new carbeurator
Steve's Small engine repair & Blade sharpening
Jacksonville. Fl
Feb 08, 2012 | Craftsman Garden
I have a used Cub Cadet Model #144-664-100 that I purchased last year and used half of the summer and ran great but towards the end it wasn't cutting very cleanly. So I took off a mower blade, which was...
Have you tried running it with the blade back on? It may be ok as there is a braking system built into the pto clutch that makes the blades hard to turn by hand. Regards Phil
Apr 15, 2011 | Cub Cadet Lawn Mower Deck Drive Belt...
Black & decker mm850 can not get blade off so can replace how do I get off tried loosen clockwise and counterclockwise plates move will not loosen up
The nut is counterclockwise but will most likely take an impact wrench to remove the blade because the impact will not need the blade or spindle to be held in order to remove the nut.
Thanks,
Chad
Mar 23, 2011 | Garden
How do I get my lawn mower ready for spring time use?
This is what a "General service" looks like at www.arcolawn.com
  • (Mower 2 cycle GS)
GENERAL SERVICE:
1. SHARPENED & BALANCED BLADE
2. REMOVED BLOWER HOUSING & CLEANED COOLING FINS
3. REPLACED SPARK PLUG
4. FLUSHED FUEL SYSTEM
5. CLEANED CARBURETOR HOUSING
6. LUBED CABLES
7. CHECKED OIL SEALS
8. SERVICED AIR FILTER
9. CLEANED EXHAUST PORTS
10. TESTRAN & ADJUSTED.
  • (Mower 4 cycle gs)
GENERAL SERVICE 1. SHARPENED & BALANCED BLADE 2. REMOVED BLOWER HOUSING & CLEANED COOLING FINS 3. REPLACED SPARK PLUG 4. CHANGED OIL 5. FLUSHED FUEL SYSTEM 6. CLEANED CARBURETOR 7. LUBED CABLES 8. CHECKED OIL SEALS 9. SERVICED AIR FILTER 10. TEST RAN & ADJUSTED.
  • (rider tuneup)
Tune up
1.TIGHTENED ENGINE MOUNTING BOLTS
2. INSPECTED BOTTOMOIL SEAL.
3.TEST GOVERNOR OPERATION & ADJUSTEDRPM'S.
4.CHECK SHAFT BEARING.
5.REMOVED BLOWER HOUSING &CLEANED COOLING SYSTEM.
6. REPLACED SPARK PLUG
7.CHANGED OIL.
8.REPLACED OR CLEANED AIR FILTER.
9.ADJUST FUEL/AIR MIXTURE & SPEED LIMIT SCREWS.
10.REPLACED FUEL FILTERS AS REQUIRED.
11.CHECK FUELLINES, VALVES, & CLAMPS.
12.INSTALL FRESH FUEL IN GASTANK.
13.SHARPEN BLADE(S) & CLEAN UNDER BLADE COVER.
14.CHECK DECK, EXAMINE BELTS, PULLEYS.
15. EXAMINETRANSMISSION/DIFFERENTIAL FLUID LEVELS,
16.CHECKGREASE FITTINGS, WHEELS, WHEEL BEARINGS, HEIGHTADJUSTER.
17. CHECK CABLES & CONTROLS ADJUST BRAKE &CLUTCH.
18. CHARGE & TEST BATTERY. (IF EQUIPPED).
19. TESTSAFETY SYSTEMS.
20.REMOVED CYLINDER HEAD & CHECKEDCYLINDER FOR WEAR/DAMAGE. CHECKED ROD BEARINGPLAY. 21.CHECKED VALVES FOR PITTING, WARPING, CARBONBUILDUP & SEATING.
22.CHECKED VALVE STEM CLEARANCESFOR EXCESSIVE WEAR.
23.CLEANED CARBON BUILDUP FROMCOMBUSTION CHAMBER.
24.MACHINED HEAD FLAT.
25.CHECKEDTIMING KEY FOR DAMAGE.
26.CLEANED OR REPLACED POINTSAND CONDENSER (AS NEEDED).
27. SET TIMING. ADJUSTEDMAGNETO AIR GAP.
28.CHECKED THROTTLE SHAFT FOREXCESSIVE WEAR & REPLACED IF NEEDED.
29.DISASSEMBLED& CLEANED CARBURETOR. REPLACED DIAPHRAGM, NEEDLE &SEAT, NEEDLE VALVES ETC. AS NEEDED.(see carburetor section)
I hope this helps! get parts for the service at a dealer like www.arcolawn.com
Feb 14, 2011 | Garden
Can i sharpen my electic trimmers using sandpaper
Things You'll Need: Three-sided blade sharpener (coarse, medium, fine) Small flat head screwdriver step 1 Using the flat head screwdriver, unscrew the trimmer blades and remove them carefully. Wipe off any oil, grime or dirt that has built up on them as this may make it more difficult to handle and keep them in place during the manual portion of the sharpening process. Step 2 Separate the blades and re-apply only the moving blade to the tension spring. Then apply the moving blade to sharpener surface and turn the clippers or trimmers on. Hold the moving blade on the surface of the sharpener and apply light pressure while moving the blade back and forth for one to two minutes. You can also lay the blade on the sharpener first, then put the trimmer tension spring directly on the blade. Step 3 Turn off the clippers and remove the moving blade. It should look shiny and feel sharper. Step 4 Remove the guide from the guide blade by unscrewing it using the flat head screwdriver. Place the guide blade on the sharpening surface and manually run it back and forth for about one or two minutes or until it's been sharpened to your satisfaction. Screw the guide back onto the guide blade while being careful to readjust it before you tighten the screws. Step 5 Screw all the blades back on the trimmers and power them on to make sure they've been fitted correctly. Test them on your own hair to make sure they've been sharpened correctly and are set to the desired depth. Ads by Google Best Knife Sharpener Sharpen like the pros. Complete kit w/ 1x30 belt sander. Only $189.00 www.theedgemasters.com Braun® BodyGrooming Tools Try the Braun® bodycruZer? with Gillette® Fusion Razor Technology. www.Braun.com/BodyGrooming Oster ® Clipper Blades Oster ® Full Line Clipper Blades, Animal & Human Oster ® Blades. www.HouseholdAppliance.com STIHL Electric Trimmers Buy it. Plug it in. Trim it up. Depend on STIHL Electric Trimmers. www.STIHLdealers.com Tips & Warnings Which surface you choose, whether coarse, medium or fine, depends on how dull your blades are and how sharp you want to make them. If they are very dull, you will want to start with the coarse or medium side of the sharpener. If they just need a small amount of sharpening, use the fine side. If you've never sharpened electric trimmers before, you may want to visually observe and feel the sharpness of the blades with your fingers before you start to sharpen it. It may be hard to tell if the blades are sharp enough if you don't feel them just before you apply them to the sharpening surface.
May 02, 2010 | Andis T-Outliner Hair Trimmer
I have a Honda push mower with a twin blade. I
The more slinder blade goes on second. I just looked at mine and it was second or closest to the ground when on all 4 wheels.
Good Luck
May 02, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Black & Decker MM850 switch and arm pivot failure
The "wedge" of the plastic lever wears, so you need to replace the lever or build up that section of the lever. Some cyanoacrylate (Super Glue / Krazy Glue) and a piece of a zip tie will work.
Sep 15, 2009 | Black & Decker 19" Electric Lawnhog...
Lawnmower blade turns but does not cut
You have either bent the blade and its to high to cut or you need to sharpen the blade with a grinder.
Aug 01, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Blade lock for mm850
Use a 2x4 at least 1-3' long. Clear the grass chute so you have unobstructed passage from the back of the mower and into the blades. Wedge the 2x4 longways in through the chute and up against the blade. The other end can be **** up against something sturdy i.e. a concrete block, a wall, etc... (in my case I used my leg). Take your wrench and crank like hell.
Apr 10, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
238 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
