Question about Xerox DocuPrint 203A Laser Printer
Drum light is flashing on my Xerox DocuPrint 203A. does this mean i need to replace drum
  • 1056 Answers
SOURCE: how to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Posted on Aug 28, 2008
Soulvisitor
  • 1113 Answers
SOURCE: Drum light
Drum light reset below
Open cover
Press and hold down Go button for about 4 seconds until all the LEDs light up. Once all 4 LEDs are lit, release the Go button
Close cover
link to MANUAL
Posted on Dec 12, 2007
  • 2072 Answers
SOURCE: Xerox Docuprint C1618 Colour Laser
Are you certain you have typed the right model number? I can't find a Xerox 1618 anywhere. I would love to help.
Posted on Mar 24, 2008
  • 3 Answers
SOURCE: Brother HL 2040 drum light flashing after drum replacement
Hello Pat ,
You might not need a new drum .
Try this as it resets the bios on the 2040 and you can get some decent life out of your drum ... Done it about 6 times on one printer and it still goes fine .
1. turn the printer off
2 . check that the front cover is open
3 press and hold the go button and while holding turn the printer on .
4.check that the toner/ drum/paper / leds are all on .
5 . release the Go button and check that all LED go out.
6 Press the go button twice .
7 Check the toner / drum/paper Led are now on
8 Press the go button six times
9 close the front cover .
You should now be away .
cheers and good luck .
Mike
Posted on Aug 10, 2009
SOURCE: Fuji xerox won't pick up paper for printing.
Managed to get it going ,pulled all the toner cartridge out and reset and all is sweet.....!
Posted on Aug 31, 2009
When i print using my docuprint 203A fuji xerox, the printout result paper was cover with black all over. what does this mean?
This is a rebadged Brother Printer.
Possible causes for a solid black output:
1 Corona failure
Is the corona wire dirty?
Clean the corona wire with the wire cleaner.
2 Corona wire broken?
Replace the drum unit
3 Are the charge electrodes between the printer body and
the drum unit dirty?
Clean both electrodes.
4 Harness connections?
Is the laser unit connected to the main PCB correctly?
Connect the harness between the laser unit and the main PCB
correctly.
5 High-voltage power supply PCB failure
Is the problem solved after replacing the high-voltage
power supply PCB?
Replace the highvoltage power supply PCB.
6 Main PCB failure
Is the problem solved after replacing the main PCB?
Replace the main PCB.
7 Laser unit failure
Is the problem solved after replacing the laser unit?
Replace the laser unit.
Good Luck!
May 12, 2010 | Fuji Xerox® DocuPrint C3055DX Laser...
My fuji xerox printer docuprint 203 A's drum lights/blinks when i turned on my printer to print. help.
Press the button until all the lights are on..then let go the button, this will reset your drum counter.
Feb 18, 2010 | Xerox DocuPrint 203A Laser Printer
My Fuji Xerox Printers DocuPrint 203 A got problem, after printing one paper, the LED turn to red and cannot print anymore.......i has check it but it's still the same problem. Can anyone help me to solve...
the drum or toner LED? if it's the drum, then just press the button until all the LED are ON then let go and this will reset the drum..
if it's toner, you need to take out the toner and on the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, re screw the whole cover and install back to the printer, this will reset your toner, make sure there is toner in the cart.
Feb 08, 2010 | Xerox DocuPrint 203A Laser Printer
Yellow light on Toner light on) Cannot print a thing
take out the toner.. at the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, this will reset your toner.
make sure the printer is on when you put back the toner.
Jan 18, 2010 | Xerox DocuPrint 203A Laser Printer
The red light is flashing on the printer. I cannot find any paper stuck in the printer.fuji xerox docuprint 203a
take out the drum unit and clean it, normally when the drum unit is dirty with toner, it will give you error.
Jan 17, 2010 | Xerox DocuPrint 203A Laser Printer
My drum light is coming on when using my 203a printer
That means that you're soon going to have to replace the drum in the printer
Sep 21, 2009 | Xerox DocuPrint 203A Laser Printer
How to reset drum counter for fuji xerox 203A
Aug 28, 2008 | Office Equipment & Supplies
Xerox DocuPrint 203A Laser Printer Logo
497 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
