Question about Symbol MC50 Pocket PC
How can I access the barcode reader input? I need to develop software to read barcodes.
  • 33 Answers
In windows os mobile it is easy , u develop apps with .net CE and install it in u r mobile and use the USB connection or blue tooth to acces it
Posted on Apr 23, 2010
Scanner won't scan library barcodes.
The barcode reader is something that the backup software typically uses to identify which tape it is dealing with.
So typically your backup software can already natively read the barcode and therefor you don't need any other software.
The linked barcode reader is probably for reading a barcode that was provided via a picture (from a scanner or camera). This has nothing to do with the barcode reader that can be part of a tape library. NET UPC Barcode Reader
Dec 14, 2012 | Datalogic QuickScan I QD2100 Wired Wand...
Can we determine the symbology of a barcode that the MC9090 just read?
This is application dependant. The Motorola Datawedge does have this function and so does some diagnostic software, but each application would need to have the functionality written for it.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jun 05, 2012 | Symbol MC9090 Barcode Scanner
Ls2208 Barcode Scanner program for .NET
here is the Barcode Scanner Program right now, it seems like being able to scan barcode with Symbol Ls2208 handheld device.
if it is not workiing, go to this barcode website to find more compatible software for Ls2208, i am sure you will find the proper one.
NET Barcode Reader Barcode Reader ASP NET Barcode Reader VB NET Barcode... Barcode Components NET Barcode Generator Reader Java Barcode Generator...
Jul 28, 2010 | Symbol LS2208 Handheld
Hello, i am new to using the barcode scanner can you please tell me how i can use it. I have it enabled but it seems like it is not working, because when i have any bar code in front of the scanner and...
The barcode reader can only be used by any application developed. To read barcodes for a program like notepad, excel, etc.., then there is a program that sends the reading of the scanner into the keyboard buffer. You can also read barcodes with the camera. The buttons are also programmable.
Oct 01, 2009 | Symbol MC70 Barcode Scanner
Could not active it the scanner on the MC9090
The link works for me DataWedge provides a convenient mechanism for non-scanning aware applications to receive data from embedded or connected data capture devices. It allows the user to capture data into any application that accepts keyboard input. It supports four types of Data Feeds: Barcode Scanners, RFID Tag Readers, MSR Readers and Serial Data Input. It provides user with text/hex data formatting and prefix/suffix facilities. Description
  1. New Test and Log Display.
  2. Improved DataWedge Startup Time for MSR and RFID
  3. Gen2 RFID Support
  4. Device enable/disable persistence over cold boot
  5. Virtual Key Support in Prefix/Suffix
  6. Performance improvements for MSR
  7. Enable Serial Interface on startup
  8. Support added for Event based Serial reading.
  9. Delays regarding RFID are fixed.
  10. Several Barcode character mapping issues fixed.
make sure some security software is not blocking your access
Jun 22, 2009 | Symbol MC9090 Barcode Scanner
Cannot get the datalogic qs6000 to scan 39 or 128 barcode
Sounds like you need an updated driver for your POS scanner.
Other than that, try checking the scanners setting your software and make sure it is set for 39 and 128 bar codes. There is usually a setting that will specify what codes the scanner is going to read.
You can always shoot an email over to the datalogic guys and see if they have any more input on the situation.
Jan 22, 2009 | Datalogic QuickScan QS6000 Plus Bar Code...
Ms9535 bt not reading barcodes.
I'm using the same Barcode reader, the Metrologic MS9535 VoyagerBT.
The brief humming noize is called a "Rasbery tone" in the manual. It means that the barcode reader is not configured to read that kind of barcode, a barcode Code if you will.
There are many types of barcodes so you have to go to the Metrologic Website and get the Barcode Configuration tool to configure your barcode reader to read the type of codes you will be using.
Alternatively there is a book with configuration barcodes you can scan to configure your barcode reader manually.
Sep 28, 2008 | Metrologic Instruments MS9535 VoyagerBT...
Configuring (changing) barcode reader suffix
Reset tbe scanner and again program the scanner for your required configuration.
Aug 15, 2008 | Datalogic Computers & Internet
Symbol LS 4007i
Barcode readers are autonomous (no computer interaction required for them to work) readers beep to confirm that the barcode is valid, unfortunately this does not confirm that it has made it to the computer, you need to ensure that the driver & capture software is installed properly, check that the device is showing correctly in device manager. Gareth
Jul 23, 2007 | Symbol (LS4005I-I090-0000Z) Handheld
Symbol MC50 Pocket PC Logo
165 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
