Question about Video Cameras
Vivitar DVR 550
Hi camera was working fine went to charge it red light came on, left it for a while still wont turn on.....help.
  • Anonymous Oct 17, 2008
    Having problems getting camera to turn off/on and using features
Does anybody know where I can get a mains charger for vivitar dvr 550 as I have lost mine. Have searched everywhere cannot find one.
thanks
Posted on Jun 17, 2008
Hi, my vivitar 550 wont turn on, ive had it on charge and just a red light shows, can you help
Hi, My guess is that the battery is no good any more. It will not take a charge any more. Replace the battery with a new one. Good luck.
Jul 26, 2011 | Vivitar DVR-550 DV Camcorder
MY VIVITAR 550 DOES NOT CHARGE AND DOES NOT TURN ON. WHAT IS THE PROBLEM?
Most likely your Vivitar needs a new battery....if you've lost your a/c adapter-you can use a standard USB cable to charge your camera. Plug the smaller end into your Vivitar & the larger end into your turned on PC/laptop & it'll charge the battery.
Dec 31, 2009 | Vivitar DVR-550 DV Camcorder
Hi I,have a Vivitar DVR550,and need a new recharger for it. when I,but when I,put my model in the vivitar support page it does not have the model number in the list.There is nothing wrong with my camera...
Go here:
http://www.amazon.com/VIVITAR-DVR-545-DVR-550-DVR-550G-CAMCORDER/dp/B002RN6DO0/ref=sr_1_64?ie=UTF8&s=photo&qid=1260903217&sr=1-64
You can read the specs of exactly what type of charger is needed, or just purchase it.
Vivitar DVR 550 was a well known model in the UK. but the company Sakar bought the Vivitar comapany out. However, the Vivitar site still exists, but not much support for the DVR 550 is provided. I would recommend e-amiling them by visiting www.vivitar.com
Good Luck
Nov 26, 2009 | Vivitar DVR-550 DV Camcorder
Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
Nov 22, 2008 | Vivitar DVR 7300x Digital-8 Camcorder
Vivitar dvr550 battery charger
Try Sunny Technology Co Inc
Model SYS 1193 1005 W2
It appears to be a universal cell phone charger.
Hope this helps.
Jul 26, 2008 | Vivitar DVR-550 DV Camcorder
Vivitar DVR 545 - Is this going to work with my MacBook?
I have a VIvitar DVR 545 I can not find out how to recharge the rechargable battery
I just bought this camera and had the same problem.
How DO you charge the battery???!!!
Here goes:
Open the box the camera came in and you should find a little rectangualr black box and a 3-pin plug.
Ignore the other stuff unless you think you may need it (depends what country you're in and what your mains supply wall socket fittings are). Take a close look at the little rectangualr black box and you'll see a slot in it. That's where your battery goes! Remember the battery must be taken out of the camera and slotted into this box! Make sure you align the battery correctly to the litle pins inside the box.
The Vivitar DVR 545 uses a sort of mobile phone/cell phone battery.You must take the battery OUT of the camera. Now you have slotted the battery into the box you connect the 3-pin plug to the box and then insert the plug (attached to the box) into your wall mains supply socket. The box will light up and you'll see a red light. Once this light turns green your camera battery is charged!
RE-INSERT THE BATTERY INTO THE CAMERA.
The whole charging procedure for the DVR 545 is ridiculous but there it is! By the way one drawback about having to remove the battery from the camera to charge it is that you will lose all or most of your camera settings. remember to reset video and photo settings - resolution, flash etc., etc.
Also a word of caution:
The Vivitar DVR 550 is unusual in that the battery is charged using the USB port. If you also happen to have a DVR 550 do NOT attempt to charge the Vivitar 545 using the Vivitar DVR 550 USB charger cable!
You will destroy your DVR 545 in seconds!!!!
Jul 09, 2008 | Cameras
Vivitar DVR 550 5 in 1 camers/video recorder
I use my motorola cell phone charger....they're interchangable
Mar 19, 2008 | Vivitar DVR 530 Flash Media Camcorder
Vivitar DVR 550 camera not working.
I had the same problem and purchased a new battery to resolve the problem. I also purchased a 110v battery charger for the vivitar 550 camera and recharged to old battery.
Dec 30, 2007 | Vivitar DVR 530 Flash Media Camcorder
Video Cameras Logo
266 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
