Question about Singer 3116 Simple
I can't get my Singer Prelude sewing machine to sew. I took the bobbin out and the metal pieces that holds the bobbin in, but can't get the metal pieces back in correctly, so the machine keeps jamming and leaving lots of thread in between the bobbin and the upper needle area. HELP!
    Scholar:
  • 48 Answers
This one will take fidgetting. Basically, ensure that you can get those parts in right(there will really only be one way. Check your manual to make sure you've got them in right. Singer has most manuals available online for free for their machines.)
The problem will continue until you have those parts in correctly. Sorry!
Posted on Apr 23, 2010
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
How do i adjust bobbin tension on singer 4210
Open bobbin area and look at your bobbin carrier for a tiny metal screw that holds down a metal piece to the plastic carrier. Tighten the screw. Be careful though...the plastic can strip.
Sep 16, 2012 | Singer Inspiration 4210 Mechanical Sewing...
I cannot get the bobbin thread to catch and pull through the footer wen trying to thread the machine?
Make sure your bobbin is placed in correctly. Thread is counterclockwise as you place bobbin in the metal piece. Pull thread end through sliver in metal piece. Hold on to movable metal latch then lock the bobbin in place. Bobbin should not fall out but is able to rotate. Rotate the wheel on the furthest right of your Singer 1507 machine towards you to move the needle downward. The top thread should then be able to catch and pull up the bobbin thread.
Dec 02, 2010 | Singer 1507
Bobbin jumps out of place while I'm sewing and jumbles the thread. I took it to a repairman, it worked for about 3 weeks. Now, same old problem.
I had a similar problem but found it only happened when I used plastic bobbins. I've been using metal bobbins and haven't had the problem again. Hope this helps.
Jan 28, 2009 | White Sewing 2037 Mechanical Sewing...
Problem with singer prelude sewing machine!
Firstly make sure when you thread the machine you have the sewing foot in the up position or the thread will not sit in the tension and cause this problem. Also as it is a new machine it may have a small amount of oil from transport stopping the tension discs from separating. Try sliding the folded edge of a piece of fabric with the foot up through the tension unit it may clear the oil away.
Aug 25, 2008 | Singer Sewing Machines
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Jul 26, 2008 | Singer 8280 Mechanical Sewing Machine
Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Jun 20, 2008 | Sewing Machines
Bobbin thread getting caught
Check your Instruction manual - if you have taken the bobbin case apart to clean it, the shuttle must be reinserted with the little tab pressing against the piece you mention. It is under page 45 - "Caring for your machine" in my book. I missed it the first time I cleaned and oild mine.
Mar 21, 2008 | Singer 3962 Mechanical Sewing Machine
Singer 3116 Simple Logo
159 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
