Question about Dometic Rooftop RV Air Conditioner
Change from a 13500 to 15000
Dometic 13500 on my 5th wheel (duct system), can i simple unbolt one and bolt the 15000 in its place
  • Dometic Master
  • 6,674 Answers
Shouldn't be a problem.
Posted on Apr 23, 2010
What is the easiest way to remove a start from a
there is no easy way I included diagram of bolts, to remove that's easy, before that you must unbolt steering column there is 1 bolt right in front of starter ,before you unbolt it make sure that wheels are straight ahead and steering wheel locked in place, remove bolt and push or compress steering column and move to side, remove wires and note witch ones go where , drop starter down to remove.
I really hope this helped you if it did please let me know
Thanks Woody
Sep 24, 2014 | 2008 Dodge Charger
How to change front wheel hub on a mk4 astra
Most hub assy's are just bolt off bolt on. You will need to suport car on stands, remove wheel, unbolt brake calliper but not the brake hose & move to side, remove disc, unplug abs sensor, unbolt hub from rear (3 or 4 bolts) Normaly 3 torx bolts on astras (funny looking heads) then reverse the procedure
Jun 26, 2012 | Cars & Trucks
Replace turbocharcher on a pajero 1992 model
  • sorry having problem with curser. Will post this and continue in comments window. Hi John, You'll need to rremove the electrical conections to the intercooler and then remove the intercooler ducting before removing the unit from its mounting place. Unbolt the oil feed from top of the turbo and remove all ducting. Remove the bolts from the mounting on the exhaust
Nov 27, 2011 | Cars & Trucks
What are the procedures to employ to prevent problems from arising;=preventative maintenance??i have a dometic 15k ducted a.c on a 1997 airstream fifth wheel.
keep the unit clean of debri and dirt in condensing coil . to accomplish this a water hose will work in most cases remove the cover from atop the unit an gently spray the coil take care not to get water into the ducting system and into your coach.Dont do this with unit running disconnect power and dont put unit back into service until dry good luck
Jun 18, 2010 | Dometic Rooftop RV Air Conditioner
How to change the windshield wiper fluid bottle on 2001 chevy silverado or how to stop leaking of fluid without changing the bottle. Is there a product to plug up a leak?
Hello, I know of no product capable of a long lasting repair. You might be able to seal it on the outside with some sort of epoxy but a better fix would be to replace it with a new reservoir bottle. To remove it you need to unbolt that skinny brace above the battery and remove the battery and unbolt the top bolts of the washer reservoir. CAUTION, if you have the THEFTLOCK radio be sure to disable it before removing the battery cables. Set the parking brake and chock the rear wheels. Loosen the lug nuts on the driver's side wheel just enough to break them loose and jack up the driver's side and place a jack stand on a solid part of the frame, remove the driver's side wheel. Remove the inner wheel liner to give you access to the bottom reservoir bolts and pump, disconnect the electrical connector and unbolt the pump motor and washer reservoir, then slide it down and out, being careful of the small tube that carries the fluid to the wipers. Installation is the reverse, good luck and if you have any other questions don't hesitate to send a comment.
Mar 09, 2010 | 2001 Chevrolet Silverado 1500
Duo Therm RV air conditioner inadequate cooling
The rule of thumb is 20F difference (lower) than ambient temperature. Most manufacturers will tell you 20 F degress is about normal. In your case it does sound a little warm, but I need to ask, sorry. Was it working o.k. before in same basic temperatures? Have you cleaned coils & fins good on Evaporator & condenser recently? Have you removed filter inside & cleaned it as well, and looked to see if coils are frosting up by chance? Is this a ducted or non ducted system? I'm guessing on a 5th wheel, it is ducted, so make sure you have good discharge on all of those as well. Any blockage or restriction on the discharge side will also cause the problem. Keep me posted on what you find.
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
How to unbolt torque converter on a 1kzte engine and to remove engine
there is a cover at the bell housing of the gearbox! remove its bolt then access the thin fly wheel! there are bolts that attach it to the torque converter! remove all as you rotate the fly wheel! pretty simple!
Jun 16, 2009 | 1996 Toyota 4Runner
Dewinterized 5th wheel. Turned on Refrigerator.
good day,
hope this link below will solve your problem.
ref
May 09, 2009 | Dometic NDR 1292 Refrigerator
Dometic Rooftop RV Air Conditioner Logo
171 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
