Question about Fender Frontman 212R 100W 2x12 Guitar Combo Amplifier
I cant get good distortion out of my fender frontman 212R can sombody help me with the settings
  • Anonymous Mar 29, 2014
    what is the replacement fuse
    I need to buy a new fuse for my frontman 212r what fuse do I purchase
  • 57 Answers
Start with everything in the 12 o' clock position. Adjust one thing at a time until it sounds good to you.
Posted on Apr 24, 2010
Fender Frontman 212R crackling noise
After ruling out guitar wiring or bad cables...
Try the 2nd input on the amp
also
Is it on both channels, or just one?
Nov 01, 2013 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Can i go straight out of the pre out on my fender frontman into a powered mixer pa system
yes,, Pre means before powered or amplified ,, so yes you can do this to a powered mixer, just be sure that the power is off before making any connections,, without the ground of the rca cable touching , the blast to the speakers can invert the cone !!
Aug 26, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
Hello! I was recently playing and found out then whenever I play specific notes on any of my guitars, my Fender Frontman 212R will buzz. The notes that always buzz are drop C, drop C#, any A note, and...
There is something resonating with that note frquency. Often the grille or wiring inside will rattle at certain frequencies. You need a sustained source of these frequencies to find what is causing the noise.
Aug 25, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
I want to put 3 small metal screws (1/2" long at
I would be VERY concerned about hitting circuit boards, wiring, etc.
In addition, drilling would undoubtedly leave metal shavings which could cause shorts internally.
Open the unit and investigate... do NOT blindly drill into it.
Feb 10, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
I have a Fender Frontman 212r amp. The problem seems to be when I put the volume upto past 4/10 [40%] The amp gives out an awful crackling sound and power light etc flickers on and off. I have had the map...
When i turn on my 212R it turns on in drive channel. if footswith is plugged in, then it turns on in the clean channel, but after switching in drive it is impossible to switch it back in clean channel. What could be wrong? Swith position doesnt change anything and it seems like switch is OK.
Nov 27, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
Everytime I play on my Fender Frontman 212R the amp switches betweeen the overdrive and clean channels. I can't even switch between the channels on my own. It does it itself. I need help fixing this...
You don't say if you are using a footswitch or not... If you are, the switch, cables and connectors are suspect.
If you are NOT using the controller, the switch contacts on the footswitch jack in the 212 are suspect as being intermittent contacts.
If the contact is not making, the OD switch on the unit will NOT work either.
These jacks, and their contacts are JUNK and often cause problems.
Open the unit and increse the tension of the contact springs.
Jul 27, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
Open Questions:
See all Fender Frontman 212R 100W 2x12 Guitar Combo Questions
Fender Frontman 212R 100W 2x12 Guitar Combo Amplifier Logo
281 people viewed this question
Top Fender Music Experts
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
