Question about Epson Stylus C67 Photo Printer
I have an Epson C67, with the print set to "Black only" it still seems to be using the other colours. Is the Black a true Black or are other colours combined?
Soulvisitor
  • 1113 Answers
SOURCE: Epson STYLUS CX3900 Black colour not printing
Are you using gen. epson cart? If not then try that first.
Sounds like you have a block black print head there are many posts on that subject.
Posted on Nov 04, 2007
ohms
  • 1879 Answers
SOURCE: Epson 2400 printer prints dark and with slight colour cast
try these :
1. nozzle check
2. image set to RGB color (Photoshop)
3. check driver settings
4. try another file
5. try another application
6. ¨supported / recommended¨ epson paper & inks
7. another computer (to pin down where issue is happening)
8. all else fails - the printer needs service (better check your warranty status)
Posted on Jan 03, 2008
SOURCE: printer= Epson stylus Photo R200=will not print in black
I print in black ink only most of the time. Choose print from the menu, when the print dialog box opens, choose properties, advanced, black ink only (gray scale in Vista), then APPLY. You do have to have ink in the other cartridges but you only use them when you want to. Hope this helps!
Posted on Mar 27, 2008
worldvet
  • 859 Answers
SOURCE: epson stylus DX 7450 doesn't print black
Hello, This can be FIXED. I'm not trying to be helpful. I'm here to FIX your problem.
You want to make changes to the printer settings to once again print in Black and White or Grayscale mode by going to Start Menu, Control Panel, Printers. Right click your printer and select Properties. Now make the changes to everything prints Black and White or Grayscale. This will make the change effective system wide as opposed to what you did which was for a single print job in a program.
Now, unfortunately, you will still get an error message that your color cartridges are empty anyway because they are.
To disable the error message do this.
Press and Hold the Stop/Reset button for 6 full seconds and then release it? Use the one Mississippi method of counting.
This will disable the empty cartridge error on most Epson printers.
Let me know of your results as I am here to FIX your problem. I'm not here to be helpful. I will work with you until this is FIXED or is now FIXED. OK? Use the comment box below to let me know your results.
Regards,
Worldvet
Posted on Nov 09, 2008
SOURCE: Using colour ink without black ink in Epson CX5500
good
Posted on Nov 20, 2008
Cyan cartridge is empty. But it should be possible
If you print using the other colours, your colours will not be true.
your other option is to print in black only .
Mar 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson cx3200 wrong colour
It is possible that when the printer senses not enough black ink it will swap to using the colour tanks to try and make a BLACK.
It is also possible that you have mistakenly adjusted a setting in the epson printer program to use the colour tanks to print black and white photographs.
Either of those would certainly cause the problem you describe
Check ALL your printer settings both the windows ones AND your epson ones
If you found this information useful pleas click below
Aug 12, 2009 | Epson Office Equipment & Supplies
Bypass using any colour ink with Epson D120 printer? Possible?
Yup that's Epson for you. I had the same. bought the black one but to get it to work you must have ALL the ink cartridges full. no way around it.
Jun 10, 2009 | Epson Stylus DX6050 All-In-One InkJet...
I know the colours and black crtridge is not empty RX420 Epson
thats true because the capacity of ink of cardiges small refill it it will print. trust me.
Jun 04, 2009 | Epson Stylus C66 Inkjet Printer
ESPON Stylus Photo R200 Ink Status Problem
The epson like many other brands actually uses a small amount of the coloured ink in order to give the black print a more polished look.
You must use your printers properties page to set printing mode to Greyscale if you don't want it to use the colours.
To do this go into your control panel, open the printers icon, and select your printer, right-click on it and select Properties from the grey menu.
You will have to look through the pages and find the setting or check box for Grayscale. When you find it, select it, then click ok at the bottom of the page. This will stop the printer from using coloured inks to tone the black print.
Hope this helps FixYa,
Chris
Apr 30, 2009 | Epson Stylus Photo R200 InkJet Printer
Just want to print black !
hallow ,,,if your lookin to just print black and white so .while printing ,go the printing properties or prefrencies ,,in the colour option click just use black and white
Jan 10, 2009 | Office Equipment & Supplies
No true colours in Epson Stylus Photo 1400
Given that you are using a dye-sublimation ink I have to ask if you're basing the colours you're getting on the results on your substrate or on the finished product (after you've done the heat transfer).
Beyond that you should probably ask the supplier if they have a colour profile for their inks. If not you can look for one of the services available. I can't make any recommendations but communication with this company has been quite positive
Sep 01, 2008 | Epson Stylus Photo 1400 Printer
Black (no colour) printing setting Ebson Stylus CX4800
Ask to print,when printer screen comes up go to properties on the top right then advanced on the bottom right (it'll ask if you really want this --you do) then on the bottom left there is a box to mark for black and white only
Jul 31, 2008 | Epson Stylus C66 Photo InkJet Printer
Printing
Use an good photo editor to adjust before printing
Jul 23, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus C67 Photo Printer Logo
61 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
