Question about Car Audio & Video
Everytime I start the stereo and turn the volume up even just a tiny bit I hear a few beeps the geen light flashes goes to a pinkish red color then back to green then shuts itself off. What do I do to fix this?
  • 435 Answers
If the amplifier isnt burned out, there is a good chance that one of the speakers is improperly wired, causing a short circuit. The amplifier is tripping the fuse to protect itself. These fuses **** themselves every time you shut off the unit. At very low volumes, the amplifier doesn't detect the short.
Posted on Apr 23, 2010
55PW936317F appears to me to be to red
Turn the color off and or go to a black and white program--stand back and examine the screen--what color is screen with no color?
If red or pinkish you may be able to locate and slightly adjust the red screen control down to get rid of this.
It is not real easy on this set as the controls are inside the set and face the rear--two person job--one watches the screen and the other slowly turns (tiny bit at a time) the red screen down.
May 28, 2012 | Philips 55PP9401 55" Rear Projection...
I'll push the power button and the little green light flashes it beeps and the lense comes out just a tiny bit but then in stops goes back in and beeps twice and it's still off. Is there and...
First check the battery. Charge the battery to full condition or change with new battery and try to turn on your camera.
Or you can put off all batteries and memory card, wait for a moment, then put in again and turn on your camera.
Hope this help
Feb 09, 2011 | Casio EXILIM 10.1-Megapixel Digital Camera...
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
When i turn on my PS3 it as it starts up a yellow light comes on
The yellow light is also know as the yellow light of death casued by a hardware failure. It can be casued ny over heating a bluray drive failure, a hard drive failure or even a powersupply failure. You know you have it when you power up the yellow light flashes then you hear some beeps then the red llight flashes. I would suggest returning it if you have that option or getting it fixed somewhere else as a last option.
Apr 16, 2010 | Sony PlayStation 3 40GB System
Ps3 wont stay on
charge it red light turning of and beeping is meaning its dead
Mar 02, 2010 | Sony Playstation 3 (PS3) Console
Controller not working
I had the same problem, so I called customer service and had me do this:
1) with the USB cable plugged into the controller, power down the ps3 and turn the on/off switch in the back to "off".
2) hold your thumb down on the front button (where you normally can turn it on) while turning the switch on the back to "on" again. keep your thumb or finger on the front switch.
3) You will hear the normal "beep" that you usually hear when the PS3 boots up, but after a few seconds later, you will hear a secondary beep. Remove your thumb or finger after this second beep and the PS3 will reset itself after a few seconds. I have a projector connected to it, so I had to set the display screen back to HDMI afterwards, but when I disconnected the USB cable the controller worked wirelessly again. The customer service rep said that this allowed the controller to pair with the PS3 again. Note: You probably do not have to have the controller plugged into the USB cable at all while doing this. I just happened to have it plugged in. Hope this helps.
Mar 29, 2009 | Sony Wireless Controller for PS3
How do i disconnect my HBH PV703 Headset from a damaged phone and connect it to another Phone
Step 1 - To reset your Bluetooth headset:
  1. Press and hold down the volume keys "+" and "-" on your headset at the same time, until your hear a beep and the light flashes red and green alternately.
  2. Press and hold down the volume keys on your headset until it is turned off. The headset is now reset as it was when purchased.
Step 2 - To pair the headset with your phone:
  1. Make sure the headset is turned off.
  2. Turn on the Bluetooth function and Bluetooth visibility in your phone (This makes the phone visible to other Bluetooth devices).
  3. Place the phone within 20 cm (8 inches) from the headset.
  4. Press and hold down the call handling key on the headset until it beeps, shows a steady green light and then flashes red and green alternately. If the indicator light only flashes red or green, simultaneously press and hold down both volume keys until the headset beeps and flashes red and green alternately.
  5. If your phone supports auto pairing, press "Yes" when you are asked to add the headset to the phone. If not, check your phone User Guide on how to pair the Bluetooth device. If required, the headset passcode is 0000.
  6. The headset beeps and flashes green when successfully paired.
Jan 21, 2009 | Audio Players & Recorders
Jensen volume
turn the volume level to what you want, when you still see the yellow level on the screen, press and hold the volume button till you hear two fast beeps, this will be the level you deck will start of at every time you turn it on
Jul 24, 2008 | Jensen VM9510 Car DVD Player
Help
open it up then plug it in. when you press the power button see if one of the large white boxes (there are six in a row) lights up red.
Sep 29, 2006 | RCA RT2360 System
Car Audio & Video Logo
272 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
