Question about Mtd 22" Yard Machine Push Mower
My MTD lawnmower is always shut off when the grass is a little bit longer. It's as of not enough power. What's wrong with it?
  • nathan May 11, 2010
    does the mower run at normal speed as before? is there fresh gasoline in it? also is the blade excessively dull?
    Problem Solver:
  • 15 Answers
It may need a good tune up. New plug, air filter may need to be replaced. Also there may be water in the gas. drain gas add fresh gas. Also the carbs mixture may be off. Too much air or too much fuel. hope you get it going.
Posted on Apr 24, 2010
My lawnmower starts but has no power
Make sure the bolt holding the mower blade hasn't loosened and check to be sure the blade is properly centered on the crankshaft end plate.
Feb 24, 2012 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
I tried to mow the grass even though it rained this am. our grass was really high and i saw a little smoke come out of the lawnmower. is that because the grass was still a little wet or the grass was...
Nope. If the grass is too high, knock it down to size with a weedeater first. These electric mowers cannot handle the tall, high stuff. If you do, you will surely burn it up.
Aug 14, 2011 | Black & Decker 18", 6.5a Electric Mower
My MTD riding lawnmower is burning thru the new belts I just purchased.The new belts are 954-0371A which replaces 754-0371A. The old style belt lasted 5 years. Even before engaging the clutch, the belt...
My idea is not about the belts, but is about the deck. If the tensioning mechanism on the deck is getting stuck in an intermittant position than the belt may be just tight enough to turn blades while slipping through the pulleys, this may cause enough friction to start melting your belts. If this is the case you will have to remove your mower deck and see what is preventing the mechanism from functioning properly.
Jul 07, 2011 | MTD LAWN MOWER PART 1909404 BELT
I have a MTD Pro riding lawn mower that I
the only way to fix it is fit the right blades
they have fitted the wrong blade's to it,,,
the blades should overlap when cutting the grass they cannot crash into each other as there are (timed up) not to do that the new blades they fitted are to short so you have no over lap on the gutters that leaves a strip of grass left uncut between the blades,,
call them out to put this stupid mistake right,,,
Oct 25, 2009 | Garden
Mower won't start
How did you check the battery ?
It sounds like its a bit short of power to crank it over..
Try jumping it from a car battery..
Jul 24, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Briggs and stratton lawnmower 4horse power engine needegap specs on coil and points
That's easy man! You will always hear, "You sir, need to gap this or that at EXACTLY .00071542 inches per square meter".
The actual "poor boy fix"-
Put your magneto back on there, and stick a business card from your wallet in between it and the rotor. Let the magneto pull itself to it, you center it, and give it just a hair of breathing room (to slide the card back out). Tighten 'er down, and you got it.
1.- If you can't pull the card out, it is too tight.
2.- If you pull the card out easily, too loose.
3.- JUST enough to pull it out, and have it drag just a bit on the way out is JUST ENOUGH!
Remember, on 4-strokes, they ARE forgiving, and can do miracles even if you try your best to destroy them.
May 30, 2009 | Mtd 22" Yard Machine Push Mower
Lawnmower dosent bag grass correctly(leaves clumps of grass behind) also doesnt seem to have the power it once did.Not sure whats up.
there is a little do dad that fits in the hole that the grass is suppose to come out of called the rear mulching baffle that blocks the hole to the bag... remove it and shuld be ok
May 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Mtd 22" Yard Machine Push Mower Logo
155 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
