Question about Troy Bilt 5.5hp Self Propelled Mower
My riding mower will start by pull cord but not from ignition
My riding mower will start by pull cord but not from the ignition. The ignition is brand new and will turn the engine off when it is running (from pull starting), and will not start when is in off position (from pull starting). This makes me beleive the ignition is fine. The battery is brand new as well and i also replaced the fuse. It started fine last year before the ignition went bad on it so i replaced it but it's still not starting. Why won't it start fom the ignition?
  • 5 more comments
  • cbscott3 Apr 23, 2010
    It's a simple plug that can't be put on incorrectly..
    Already did that.. I traced the wires and they all seem to be fine, and the connections and battery terminals are fine too. Could it be a solenoid problem? If so is there a way to test that?
    They are tight and clean... I'm aware it's a pretty simple electrical and ignition system that's why this is so frustrating. Any other suggestions?
  • GetMeOttaHere May 11, 2010
    I realize this, but the connections on the battery have to be tight and clean, there is not much detail with the starting systems primary ignition system.
    Check the battery connections and make sure they are tight and not rusted.
    Seems like you have the ignition wires connected incorrectly.
  • 2,926 Answers
Jump the solinoid with a screw driver, it the engine starts, replace the solenoid.
Posted on Apr 23, 2010
I have same problem on Snapper,good battery,new solenoid, new key switch, starts with pull cord and not with key??
Posted on Jul 17, 2013
Brand new craftsman 190cc lawnmower pull cord will not pull out
New mowers some times comes with a safety block on the blade and this has to be removed before you can turn the blades
Jun 30, 2014 | Craftsman Garden
Pull cord pulls hard won't start
Remove the top engine flywheel & pull cord cover
Most likely dirty,as well as worn out. or the cord
is in the wrong place,you will see that,once apart
You can work on it some & down the road
get a new one if you have to
Jun 11, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
Mower will not start.
are the battery cables good jump them with jumper cables
Apr 23, 2012 | Garden
How to replace ignition switch on deere riding mower
is there a rubber boot where you put the key in remove the boot behind that is a nut
Apr 07, 2012 | Garden
I have a Troy-Bilt Briggs and Stratton 675 series lawn mower. The pull cord is stuck and will not move. I can lightly pull the cord repeatedly and the cord slowly allows me to pull more but if I release it...
Take the plug out and try to move the blade. If the motor won't rotate, the problem might be with the motor and the cord can't move because of it.
Gary
May 19, 2011 | Garden
Pull start won't pull, seems stuck.
When you pull the cord it will turn the blade. Therfore if the blade is stuck or clogged with clippings the starter cord will seem stuck. In addition, the throttle on the handgrip need to be fully depressed for the starter cord to work. Last, some mowers have a saftey which lock the starter if the wheels are engaged. Hope this helps. Bob
Apr 11, 2010 | Garden
Cant get my mountfield lawn mower started, it is petrol and i have primed it by pressing the pump button as per the instructions on the mower. there doesnt seem to be any resistance when i pull the start...
make sure there is a spark plug in. that would be 1 reason why there is no resistance when you pull the cord. if there is a spark plug in then check to see if there is a clunking sound when you pull the cord if this is the case then the engine has a broken conecting rod..good luck
Apr 07, 2010 | Briggs & Stratton Garden
How can you start a Ariens 824 snowblower
Ignition key on, throttle three quarters on, full choke, press primer 3 or 4 times, pull cord. Should cough, maybe start and run rough, then as it's chugging, turn choke to half, then quarter choke, let it warm up slightly, then choke off.
Dec 05, 2009 | Ariens Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
281 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
