Question about Sanyo DP26746 26 in. LCD Television
I have a red line that just appeared on my sanyo 37" lcd tv. How do I fix it?
  • 1,606 Answers
If the line is there all the time then this is a problem with either the display generator section on the main board or the lcd itself. Either of those require a repair shop to fix.
Posted on Apr 23, 2010
Sanyo 37 LCD ce37ld33-b
Sounds like display panel fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Sanyo Televison & Video
Vertical line 4"-6" distorting the picture appearing on the bottom of the screen on my Sanyo 37" LCD television
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 04, 2014 | Televison & Video
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
I have a Sanyo DP37647, the red color seams to have disappeared. We've adjusted manually, but can't get the red color back to the screen. Red's are now showing as black.
Tries the broadcasting incomming signal cable,with another tv connected to see,if can get the red color,if no than,the imcomming the broadcasting cable it the problems.If yes,ur tv have a Tuner board problems,it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Oct 25, 2010 | Sanyo DP37647 37 in. LCD TV
My sanyo L.C.D tv has a constant flashing red stand by light and will not come on
most likly the main power board has failed will need to be replaced
Sep 16, 2010 | Sanyo DP37647 37 in. LCD TV
A line, red, vertical line extends from the top to the bottom
you must reset the system of you TV.Open the back cover of your TV reach for the main board.there is a small button on the main board just press it and the error of your TV will be ok...
please rate me..
Jun 06, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
Sanyo dp37647 reds are turning very red.cannot adjust
Turn down ur colors,still have same problem.Ur backlight video board is dead.Must replaced.
Dec 30, 2009 | Sanyo DP37647 37 in. LCD TV
The TV has red and green lines, I touched the
you willl need an LCD panel replaced the buzzing sound you hear is the broken floresent bulbs arching
Nov 30, 2009 | Vizio VW37L 37 in. LCD TV
There is a vertical red line that runs down the screen on our Sanyo TV. It is just a thin line but it is annoying because you know it is there. Any suggestions?
thin lines are associated with the connection of the pixels on the screen in the grid. If its under warranty get it fixed before expiry as its not a cheap fix.
Red lines are not convergence problems they are component problems so you cant adjust it out
Sep 13, 2009 | Sanyo DP26746 26 in. LCD Television
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Sanyo DP26746 26 in. LCD Television Logo
138 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
