Question about Fisher and Paykel GWL11 Top Load Washer
The top loader will not dry fast enough - Fisher and Paykel GWL11 Top Load Washer
    Scholar:
  • 48 Answers
Check your heating element, they Do go bad over time. Chances are it is beginning to do so, as the first sign of such an issue is slow drying times, and still-moist clothing.
Posted on Apr 23, 2010
Whirlpool top loader agitates when filling up
Nothing, I'm not sure what the problem could be because it does not happen all the time and when it does, it usually fixes itself. M# WTW57ESVW1
your water supply perhaps it is too low pressure ....
so the machine isnt filling fast enough
so check at the machine side of the cold water filler hoze
in the machine end is a filter cone
you need to carefully pull it out with flat nose pliers and clean it
if this doesnt fix it then perhaps the inlet valve is bad...
Feb 07, 2015 | Whirlpool Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Top loader does not spin fast enough to spin dry.
possibly the clutch is slipping, i've heard you can take a #10 washer and put it in one end of your clutch spring caps and that would tighten it up
Mar 23, 2010 | Kenmore Washing Machines
Whirlpool not spinning fast enough. Not
We had same problem which got worse. I had to take the tub out as it wasn't engaging on spin. I feel a washer
was left out at factory as it wouldn't tighten down.
After a few attempts I finally found a washer that was
right ( elec dept ). You basically take the whole thing apart.
It works now but we bought extra washers
Feb 12, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Clothes are dripping wet after spin dry cycle
You may have a bad belt not spinning the drum fast enough or not enough tension on the belt due to worn motor springs.
Jan 02, 2010 | Maytag PAV2300 Top Load Washer
Washing machine spin cycle
chances are the pump may have something in it or the drain line is kinked a little front loader machines have a clean out on the pump that you can get to buy taking the lower front panel off.top loaders you have to pull access cover in the rear and pull hose off and check for blockage also check belt tension and quality of belt
Dec 16, 2007 | Maytag MAV7600 Top Load Washer
Washer continues to spin slow in the last spin cycle.
Red Ryder, the motor is 1 speed on this model. A couple of things to check; one would be the belt. Look for shavings, cracks or if it's shiney, could be worn. If your p number is p1118410ww, looks like you have 2 belts, agitate and spin and pump. Pump-R0606507, spin-R0606539. Check the pulley, make sure it is not binding, lube it up, and check the pump, something might be binding there. As long as you don't have a grinding, howling noise during spin the bearing should be good. Catriver..post back.
Feb 20, 2007 | Amana NAV5800A Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
32 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
