Question about Juicers
Cleaning my juicer
Hi, I just bought a juicer that looks brand new Health Vita Deluxe
model NT-9214. I do not have the manual and need to know how to break it down to clean it.
  • Mslisa09s Mar 23, 2008
    I just made orange juice and I do not know how to break it down and clean it, help!!!!!!1
  • micandpatsy Oct 30, 2008
    kenmore jex328s
  • 6 Answers
Generally you will have good luck with this item - however after using it for a while here is the problem people are stating in other reviews. You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Here's the problem...There are 3 little captured balls on the basket that engage into holes into the juicer to hold it into place when you load it. The problem is that over time - the balls get juice in them. Then you store the thing with the basket locked into the juicer. Then from sitting in your cupboard - the juice dries and the balls are stuck. When they get very sticky they do not float in their cavity they are stuck. Then after you juice the next time - you cannot get basket off. basket is stuck and you will destroy the juicer if you try to pry it out with excessive force.
If you have this problem and you are lucky enough to be reading this - I have figured out the fix on my own...
You need to fill up a large tupperware, rubbermaid, whatever - bowl about 3 inches deep with hot water. Then take the juicer with the clear cover off and flip it upside down and into the hot water. Make sure the water is covering the entire basket area, but not so deep it goes into the motor area. I let it soak for about 3 hours, but I don't think you will need to do it for that long. When I took it out of the water I was able to pry the basket out with very little force. This is when I discovered this flawed design with the balls. Now I rinse the little ball bearings really good after using and dont store it connected. Then before connecting the basket to the juicer rinse the little bearings and push them in to make sure they are freed up before each use.
I used it probably for a year or so about 40 or 50 times without this issue, but let it sit for about 4 months - which is why I believe it caused these balls with juice in them to get so frozen I couldn't remove it.
Good luck. It worked for me.. this should work for you!
Tom
Posted on Apr 02, 2011
Hi I too got this same model NT 9214, got the mannual but err..the Filter and Grater just dont wanna detach even afetr following the mannual. It said `to remove the filter basket/grater, gently turn the basket 1/8 counter clockwise and pull it upwards. It just dont do. grrrrr
Posted on Feb 24, 2010
  • 3 Answers
Hi, google the manufacturer then contact them and ask them to send you the instruction manual for that model. I bought a Waring juicer on ebay that didn't include the manual either and I called waring and they sent me one free of charge.
Posted on Mar 24, 2008
Lost user manual need new one
Try going to the products web page. Sometimes you can download the user manual
Apr 27, 2016 | Juicers
I need a juice tiger deluxe manual only
Who makes this, the model number would be great as well. Here is a site which has a ton of online manuals for juicers and other products. Since I couldn't find yours as named, you may find it, if so -- let us know. Otherwise, give me more info on who made it and model number. I can usually find a pdf which i can email. Good care.
Jun 11, 2013 | Juicers
JUICE MASTER MODEL NT 9214/32597, HAS NEVER BEEN USED. I NEED INSTRUCION MANUEL.
I have this same juicer and its really difficult to take apart. The filter screen with the cutter on it needs to be removed first. Its really tight and hard to get leverage on, but you should be able to get your fingers under it and pull it off. Just pull hard, you wont break it. Once thats off, twist the top part like you were doing and it will come right off.
HTH
Sep 18, 2011 | Salton Jr. JM1 Juicer
Hi I was just using my Kenwood vita pro active JE810 juicer and putting through a small apple and it stopped working. I have changed the 13a fuse but it has made no difference. Any suggestions?
It is easier to solve the problem than it sounds. The solution is underneath of the machine located reset button called 'power overload'. Press it and here we have Vita working again. Have a nice glass of juice!
Alvydas
May 11, 2011 | Kenwood Juicers
Looking for downloadable juice extractor book
BOOK CALLED "JUICING FOR LIFE" AT AMAZON.
TRY 2 CARROTS, 1 APPLE, 2 CELERY STALKS
AND A HALF LEMON. ALSO IF JUICER BREAKS,
GO FOR SOMETHING BETTER LIKE AN ACME.
HAVE ONE SINCE 1990.
Nov 26, 2008 | Jack Lalanne KN2047 Juicer
Jack lalane juicer
All in the name of health I said a lot of bad words, except that I know I never toss out my owner's manuals. I finally went to find my juicer model number when I noticed that the box said that it came with a recipe book (!) so I ran to my recipe book cupboard and sure enough the owner's manual was with it. (Maybe yours is there..)
Anyway, the key is this "crescent wrench." Doesn't look like a normal crescent wrench at all, but the handle is shaped like a crescent moon. It has two little pegs that stick out and fit into the two holes in the top of the blade, Then it twisted counter-clock-wise, the blade **still screwed into the piece underneath it, then it easily comes out, as do the other parts inside. It was just that rotten little "wrench" piece WHICH, I might add, is unique to my model. If you download the other owner's manual that's online, it doesn't mention any such tool for their model. (sorry, I can't find a model # for mine. There is a "V3 52803" on the back of the manual if that's the model.) Good luck. Hope this helps you. Happy, and healthy juicing.
p.s. in the end...it's all about Jesus.
Oct 19, 2008 | Jack Lalanne Power Juicer 250 Watts
I tried to contact the manufacturer
This Juicer pulls apart with a 1/4 turn counter clockwise. I've had one for about an hour ;)
Mar 25, 2008 | Juicers
Need Power Juicer manual
Found online. They don't make finding the manual easy. Try this http://www.powerjuicer.com/pdf/classic.pdf
Nov 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Juicers Logo
767 people viewed this question
Top Juicers Experts
eyecam
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
