Question about Mtd Products Yard Machines 158CC Tiller
Mtd rear tines tiller won't engage tines. F and R
Mtd rear tines tiller won't engage tines. F and R work fine. Just can't get it to engage tines.
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Posted on May 27, 2010
  • mcclr1 Aug 14, 2011
    I too had one that would pop out of gear while tilling. You could hold the lever in but that would eventually bend the shifting fork in the transmission and it would then jump out of the groove in the shifting sleeve. I put new pins on the shifting fork and reinforced it so that it would not bend so easily. It worked fine for a few minutes and then jumped out of gear again. A friend led me to the real solution. The shifting fork is not supposed to hold the shifting sleeve in gear. It is only supposed to slide the shifting mechanism and the detent spring and ball are supposed to do the holding work. I once again repaired the shifting fork but this time ordered a new detent spring part number 932-0863 and a new detent ball part number 741-0862. They cost $4.40 and that was the solution to the problem. I would also order a new shifting fork if yours has been bent. The new ones are a different design that has more reinforcement. It is a lot of work to tear into these so buy the new parts the first time. I was getting adept at the process after doing it three times.
    Champion:
  • 221 Answers
It sounds like the shift shaft or something in the gearbox the shift shaft engages. I know you didn't want to hear this but it is not uncommon. Most operators don't use the clutch bail when starting, stopping, and shifting as they should.
I hate to say it but this may require a trip to your service center for repair.
Posted on Apr 30, 2010
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
My white tiller won't engage but grinds a little any ideas?
make sure the linkage is adjusted right
Apr 06, 2012 | Mtd Garden
Tiller works in reverce won't go in forward drive tines will engage but does not have power in forward .
Go to smalleng.com and watch vid on how to adjust valves. It's a great place to start. Good Luck...
Aug 16, 2011 | Mtd Troy-Bilt Bronco OHV Tiller
MY ROTOTILLER RUNS AND DRIVES BUT THE TINES WONT TURN
Make sure that the clutch doges as I call them are engaging properly. Also check rear tine gearbox for striped gears or sheared keys. To check some of these things it may be necessary to remove rear tine gearbox by removing the 4 bolts that hold it on to the main transmission. Hope this helps.
Sep 17, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
Mtd rear tine garden tiller . The wheeles will engage and turn forward and reverse but the tines will not engage. At first they would but would pop out of gear. Now they w9ont engage at all.
Could be the shifter inside the gearbox or it could be a stripped gear or broken chain. The bad news is you will have to remove the gearbox from the engine and then open the gearbox to see what is going on. This is quite time consuming but taking to a shop for this is very expensive due to the labor involved. You can do it yourself if you pay attention to how you take it apart. I hope this helps you out.
Apr 04, 2010 | Mtd Bronco Rear Tine Tiller
MTD series 410 rear tine tiller drive wheels slip
I have the same issue with one I am working on. It appears the keys in the drive shaft are not rotating far enough out on the drive gear side to fully engage in the gear. I have studied and studied this and so far I have been unable to determine why. If I find out I will let you know. I am also trying to figure out what is supposed to pull these keys out of the till engagement gear.
Mar 21, 2010 | Mtd Products Yard Machines 158CC Tiller
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Tines won't turn
Possible broken key where crankshaft meets gearbox.
May 15, 2009 | Mtd 21a 643b066 Bronco Rear Tine Tiller
Tines wont turn
Without really knowing what is broken it will be tough to give a firm idea of the cost. However, you can head over to www.partstree.com. They have a great detailed parts break down and costs associated with it. Looked up your part numer and can find at this link: http://www.partstree.com/parts/?lc=mtd&mn=210-031-000+%281990%29
Apr 16, 2009 | Mtd Bronco Rear Tine Tiller
Broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Apr 04, 2009 | Mtd Products Yard Machines 158CC Tiller
Mtd Products  Yard Machines  158CC Tiller Logo
3,206 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
